Question about Garmin Golf Logix GPS
Garmin Golflogix GPS-8 New unit, new batteries, unit won't turn on after hold power switch.
  • 3 more comments
  • Balzell Mar 19, 2009
    I just loaded the latest software and now my unit will not POWER on.
  • failten46 Mar 19, 2009
    New unit, downloaded new version software, unit powered down after load, would not power-up.
  • Anonymous Apr 14, 2009
    Upgraded the software........unit is now kaput.
  • Anonymous Apr 23, 2009
    Updated SW , now it's dead, no one answers and no one returns emails. Shopping for another brand and will sell this.
  • Anonymous Apr 27, 2009
    Installed lastest software now unit will not power on...
If you downloaded the new software on a mac it doesn't work. You call the company and will receive a new device, then send the bad one back. They take care of shipping.
Posted on Mar 30, 2009
Sent unit back to manufacture for inspection and repair under warranty.
Posted on Feb 19, 2009
4 Suggested Answers
  • 6 Answers
SOURCE: Garmin HCx GPS unit
The Vista HCx has an electronic compass. You don't need to be moving for it to work, but you do need to calibrate it. To calibrate the compass:
  1. Go to the Main Menu
  2. Select Setup
  3. Select Calibration
  4. You will be asked "Which Sensor Would You Like To Calibrate", select Compass
  5. You will see a page that says "To Calibrate Compass: Slowly Turn Two Full Circles In The Same Direction While Holding The Unit Level", select Enter and do this.
You need to hold the unit level for the Magnetic Compass to work correctly. The specs for a properly calibrated compass are +/- 5°
Posted on Jun 24, 2008
SOURCE: Garmin Nuvi 760
Sounds like you both have a battery problem. I experienced a similar problem when trying to charge via the USB-cable connected to my computer.
Ended up buying an original charger (expensive) and the charging went smooth.
The car charger should in any case work fine, so probably your battery is not very healthy.
Try holding your finger on the battery symbol for about 10 sec. The unit will then switch to a technical page. There you can observe the battery and charging voltage. When I plug in my computer USB-cable, I read around 4,4V and that is not sufficient for charging my battery.
When connected to the original charger, this voltage rises to about 5V which gives a nice charge. When unplugging charger, the unit displays the battery capacity. If the charging voltage is OK, but battery capacity drops quickly after you unplug charger cable, the battery is probably bad. (Of course you have to charge is for some time) I think around 4V battery voltage give 100% capacity. 3,9V gives about 90% capacity.
This will not solve your problem, but can give you an idea about what is wrong.
Good luck.
Posted on Nov 17, 2008
SOURCE: Garmin c330 gps will not turn on
try this just worked for mine
1.Under the face plate by the Garmin Logo.Use your thumbnail to remove the plate.
2.Press the reset button.
Information located on page 28 of the owners manual if you need a diagram.
Posted on Jan 28, 2009
I need a replacement back for Golflogix GPS-8 The button fixing on the back has failed
a small amount of JB weld will let you reinsert the screw . let it cure good before putting screw in it
Sep 07, 2016 | Garmin GolfLogix GPS-8
My gps8 garwin golf gps just stopped working no power its not batteries and ideas wont power up at all
Open the unit up and remove the mother board. Place the board on a cookie sheet propped/supported by a small wad of paper at each corner. Do not let the board touch the cookie sheet. Preheat oven to 170 degrees and bake the board for 10 minutes.
I did the same for the board in my Cuisinart coffee maker. Read it on a fix it site for Cuisinart when my coffee maker would not come on. Both my coffee maker and GOLFLOGIX GPS8 are working fine.
May 07, 2011 | Garmin GolfLogix GPS-8
GolfLogix GPS Receiver: I have a golflogix 8 and I can not get beyond the ...
The cable can be a pain. It has to be slid all the way down to the very bottom of the socket on the gps, even when its tight, it might not be connected all the way. I usually wiggle it left and right while pushing it down.
May 17, 2010 | Garmin GolfLogix GPS Receiver
The Unit is stuck at the Initial Screen and won't go into any menus.
Hello. Here is the contact info for Garmin
http://www.golflogix.com/WebSite/GarminHome.aspx
Contact them and ask if they can talk you through a factory reset. Otherwise, find out how to send it to them for repair. J.
Mar 22, 2010 | Garmin GolfLogix GPS-8
Spring for battery contact broke.need a battery clip similar to other batter clips in the gps8 .. where to find such an item
Its not replaceable unfortunately, give GolfLogix a call, see if your still in warranty. 877-977-0162
Jan 02, 2010 | Garmin GolfLogix GPS-8
My Golf Logix does not work, it keeps freezing up from hole to hole. Can you help or do I need to send it in for repair?
click on help in the course manager software, then click on "How Do I restore my golflogix unit". connect it and turn it on. when it tells you its restored, turn it off and on, and load your courses again. FORE!
Nov 09, 2009 | Garmin GolfLogix GPS-8
Unit will not power up (with new batteries)
call golflogix at 8779770162. BE SURE TO TELL THEM THAT IT HAPPENED WHEN YOU LOADED THE SOFTWARE UPDATE! otherwise, they might not warranty it.
Aug 03, 2009 | Garmin Golf Logix GPS
I uploaded the latest software from Golflogix and now the unit will NOT turn back on. Any ideas? Is there a full system reset on the unit?
there is a restore, but it requires the gps turning on. Call customer service at 877 977 0162 to see if you fall under warranty. make sure to tell them that it happened when you loaded software.
Jul 17, 2009 | Garmin GolfLogix GPS-8
Golglogix locking up
Make sure to wait until you press okay on your computer when loading courses before you unplug the unit. I was jumping the gun, unplugging it right when it turned off, and causing that issue myself with mine.
Jun 22, 2009 | Garmin GolfLogix GPS-8
MY GOLF LOGIX HAS WORKED FOR OVER 2 YEARS . NOW IT WILL NOT AQUIRE SATELLITES. OTHER GOLF LOGIX IN MY **** WORK FINE
The GolfLogix 7 had a problem that if you did a reset to factory defaults it wiped out the Almanac in the GPS. This is the Table of where the satelites are. Put in a fresh set of battery's....turn it on and put it out in the open sky for 4 to 8 hours. Sometimes this will work. If not contact Golflogix Tech Support. They ill probable ship you a replacement unit.
Apr 07, 2009 | Garmin Golf Logix GPS
Garmin Golf Logix GPS Logo
549 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
