Time on program goes up
Got a five yr parts warranty on my washine machine during all the programs the time display goes up, say you have a wash cycle for 1.30 when it reaches about 57 mins left it jumps up to 1.06. this happens a couple of times so adds about 12min extra to the wash. i contacted hotpoint about this and was told that if an engineer was to call it would cost over £100 just to have a look. it maybe something simple any ideas. i have tried altering the drain outlet as this i was told could alter the program slightly
  • 15,935 Answers
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 13, 2010
LG washer drains withour washing!!!!
Call LG customer service. The unit is probably still in warranty. If not contact a certified LG repair shop and have them come examine and if possible repair the machine.
Apr 09, 2015 | LG WFT1071TP Top Load Washer
Dirt like substance coming out from the washine during wash cycle
Possible that there is dirt in the drum that comes up when the drum revolves. This can be due to dirt that had accumulated within and needs to be removed. Please try to watch this link and get some tips to clean the drum.
click on : cleaning the drain
Jan 01, 2013 | Washing Machines
Ariston ar6f105 washin machine not working
Machine start normally but after some time it display H20 and stop. When i switch off the power it restart but again after few minutes it is same. Kindly help.
Aug 18, 2012 | Ariston Technologies Washing Machines
Bosch SHE44C07UC/22 - FD8606 : pump does not run during wash cycle, but does run during empty cycle. timer works. fill works. empty works. relays are heard about 2 minutes into fill cycle. may be...
Hi 2ipnelson,
Very difficult to know for sure which part is not working.
It is best to run the dishwasher in testing / service mode to ascertain which component is not working.
I found a .pdf document that explains the whole process, it should also work for your SHE model.
The link: LINK - CLICK HERE
Follow the steps, and the culprit part should be diagnosed.
Hope this helps :-)
* If this solution helped you, please accept it
Jul 26, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
My whirlpool gold dishwasher makes a loud humming sound the entire loooong time it runs
possibly a bad bearing in the pump motor assembly,, most had a five yr parts warranty of out of warranty the parts usually run 100-300 dollars
Feb 03, 2010 | GE Washing Machines
Machine started making a quick tapping noise during wash after it had been almost silent since installation. Then noticed it appear the machine is not putting out spray or the spray amount decreased over a...
The vario motor may be at fault.
The motor switcher the spray from top to bottom.
It is part of the sump assy.
You can tell if it is working if you start the unit and when it is in the wash cycle you can hear the water spraying change from top to bottom every few minutes.
D/W has a full 1 yr warranty and most have a 5 yr part warranty on the sump.
Check your owners guide.
Jan 13, 2010 | LG LDF6810 Built-in Dishwasher
Machine wont complete a cycle, it clicks once then stops
try to preceed manually to next program and if this problem repeat then the timer has problem chang it my advice donot try to select program during electricity connected to timer thank you
Jun 07, 2009 | Whirlpool AWM5145/2 Front Load Washer
My washine machine keeps stopping through the cycle and flashing f14 what does this mean
The F14 error is an EEPROM error for the central control unit. It's likely you'll need a new CCU board. Check your owners manual, some models have up to a 5 yr. parts warranty on the CCU.
Apr 19, 2009 | Home
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
26 people viewed this question
Top Washing Machines Experts
