Question about Duracell Camping, Backpacking & Hiking
Warranty on corrosion of battery & damage to light
Corrosion warranty
  • byfs Feb 20, 2009
    I Think Your Full Of **** All I Was Looking For
    Was A Phone For Warranty Not ********* To Buy
    Thank ********* Much Paul
If this all the info i can i will
just through the damm light in the garbage
have a nice day thank you
Posted on Feb 19, 2009
Battery light turns on then turns off, checked battery algood.
The battery light also comes on when the altenator belt slips or the charging circuit has a fault Check the connectors on the altenator for corrosion then the wires out for damage
Feb 28, 2016 | Cars & Trucks
I have a 2004 Chrysler 300M and I have had a finder binder on the passenger side now my car will not start but the interior lights work.
check to be sure your 'Fender bender' didn't break the electrical connections to your starter, or any other wiring under the hood. be thorough
Oct 19, 2014 | 2004 Chrysler 300M
How to repair a wet ipod touch
there is no actual repair best thing you can do is to let it dry with the battery removed and a fan blowing on it for a few days. but since its an ipod you cant remove the battery which pretty much means something will be blown unless by fate it wasnt effected. if it doesnt work after that time then you have to determine exactly what is not working. But it would just be best to go to a store and see if it can be repaired under warranty however they do not cover water damage in the warranty.
Aug 17, 2010 | Apple iPod touch
Some Urine got on the back of my Sony Bravia KDL-26L5000 26 in. HDTV LCD TV and now it will turn on and work for maybe 20 mins at a time and shut off for a few seconds and turn back on. is there something...
Sounds like you may have corrosion or water damage within your television. When electronics come in contact with any fluid it is best to leave them completely off/unplugged/battery-less for at least 24 to allow time to dry.
However, urine is corrosive by nature and could have permanently damaged your TV's internal components.
If your warranty covers accidental spills then you should be able to have the TV repaired or replaced at no charge (except for perhaps shipping if Sony asks you to send it to their warehouse or distribution center).
If not, you could always pull the excuse card. I believe, however, that Sony does warranty tests on all major products, so this most likely will not fly.
Best of luck.
Mar 21, 2010 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
The battery is charged, but when I turn the camera
First try cleaning the battery contacts inside the camera. If corrosion is not visible or appears to be very light, rub the contacts lightly with a clean dry cloth. Heavy corrosion may require cleaning with a wire brush or sandpaper. Wipe both ends of the batteries with a cloth, reinsert them and try the camera.
If the above doesn't work, try powering the camera OFF, and then turn it back ON while holding the zoom button. This sometimes shocks the camera in working again.
If neither of these DIY fixes works, you may have lens mechanism damage or another problem that will require professional repair. You can take it to a Pentax dealer (NOT the camera department in a chain store) or contact Pentax customer service via their web site. Be sure to get a firm price, not just an estimate, before you commit to any repair. The cost of a fix can approach the price of a new camera, and repairs typically only carry a 30-day warranty.
Bill B
Mar 10, 2010 | Pentax Optio A10 Digital Camera
Hi, my Samsung nv10 camera, when switching on, only the auto focus light comes on. The lens does not pop out or open. The only way to switch off the aoto focus light is then to remove the battery. Any...
If you have recently dropped the camera you may have damaged the lens tube (housing). This damage will prevent the lens from moving properly and will cause the camera to shut itself off after a few seconds. If the lens is damaged the camera will require professional repair. If the lens is not damaged, the problem may be battery related. Make sure that you have the correct battery type installed, and that the batteries are fresh/fully charged. If the problem persists, you may have corrosion on the battery contacts inside that camera that is preventing full battery power from flowing to the camera. Remove the batteries and wipe the inside camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sand paper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and reinstall them in the camera. This cleaning solves the problem about 90% of the time, and I hope it works for you.
Sep 14, 2009 | Samsung NV10 Digital Camera
My TI-89 Calculator will not turn on. I have changed the batteries with no result. The calculator was damaged while it was in the possession of my brother, thus I do not know what is wrong with it. When I...
The damage was battery corrosion. If you CAREFULLY take a damp(not dripping wet) rag and wipe the contacts of the corrosion you may have luck. The batteries just leaked, Very common especially for cheap "Heavy Duty" batteries. Alkalines seem to hold up better in a discharged condition. I hope this helps.Do wash your hands after the cleaning. A q-tip may also be of help. Just wet it and squeeze most of the water from it.
Aug 26, 2009 | Texas Instruments TI-89 Calculator
My friend left her nearly new Samsung s1070 camera at my house in working condition. Now she has asked for it back and for some reason it just wont turn on. It hasn't been used since I've had it (so I cant...
Sitting for that long may have resulted in a corrosion buildup on the battery contacts inside the camera. Remove the batteries and wipe the inside contacts with a clean dry cloth (heavy corrosion may require cleaning with a fine wire brush, steel wool, or fine sandpaper). Remove any specks of corrosion that may have fallen into the battery compartment during the cleaning, then clean and reinsert the batteries.
Also, make sure that the rechargeable batteries that you put in are the correct type. Ni Cd batteries will not work properly if the camera calls for Ni-MH.
This clear about 90% of power-up problems, and I hope it works for you.
Aug 19, 2009 | Cameras
Won't charge
You have taken the appropriate steps. Now you have determined that the problem is not battery, it is the phone.
Most likely causes are:
  • Bad connection between battery and phone due to damage
  • water damage to the phone or corrosion
  • leads from the battery to the phone are broken.
Either way the phone will require warranty work or replacement.
Jun 23, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Camera will not power on
It is possible that the batteries have corroded the camera's battery contacts or worse. Using a bright light, if necessary, closely examine the contacts where the batteries connect. If there is any sign of corrosion use an eraser to clean the contacts. A regular pencil eraser should work if it is light corrosion. Do not store batteries in anything for long periods. Beyond that I would send it back/take it back before the warranty expires.
Feb 13, 2008 | HP Photosmart M517 Digital Camera
Camping, Backpacking & Hiking Logo
201 people viewed this question
Top Duracell Camping, Backpacking & Hiking Experts
Sandy Troupe
Sandy Troupe
Level 1 Expert
Andrew Taylor
Andrew Taylor
Bill Wilson
Bill Wilson
Are you a Duracell Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
