Question about Sharp Actius AL27 Notebook
My Sharp PC-AL27 goes to a blue screen
When i turn my lap-top on, it goes to the black screen that comes up when you accidentally turn your computer of the wrong way.Then i either click start windows normally or I click last known good configuration. After i click on either one, it goes to a blue screen that says,"A problem has been detected and windows has been shut down to prevent damage to your computer.
Technical Information:
***STOP:0x000000ED(0x85318620, 0xC0000006,0x00000000,0x00000000)".
Lap top on but screen is black
You might have accidentally hit the external monitor key. Locate the Fn key, should be bottom left of the keyboard. Next look along the top row of keys and find the one for external monitor, it should have a rectangular screen looking icon on it. While holding down the Fn key, press that key and see if it comes back for you. If not then it's time to troubleshoot the display or GPU.
Sep 15, 2012 | Computers & Internet
My problem started out pretty confusing. One day I turned my lap top on and the screen, after about five to ten seconds of being on, went black. I could see things loading up sort of but the screen was too...
Darkened screen as you describe indicates a failing inverter. You can test this easily by plugging the laptop into an external monitor, if this works ok, then the inverter needs replaced, If it does not work, the problem is with the graphics chip / motherboard
Jan 18, 2011 | Dell Inspiron 8000 Notebook
When I connect my monitor to my lab top the green power light comes on then turns orange and I get "no signal" message on the monitor
you may need to tell the lap top to display from that screen the new screen has no image or signal so goes to sleep to save power.on your lap top try the (FN) key on your laptop then select a blue picture on the keyboad of to squears one black one blue this will alter the display.OR in windows look at Start>controal pannel>display
Jun 03, 2010 | Sharp LL-173C-B (Black) 17" LCD Monitor
Monitor goes to sleeep on lap top
Hello, you can try this... Connect your laptop with an desktop monitor throughVGA cable.... then Click on start>> goto control panel>> Double click on Power Option>> Under Power Scheme it should be Poratble /Laptop >> Select Never under System Standbye, Trun off Monitor and Turn off Hard Disk.
Thank you for contacting Fixya support, please rate if that helps!!
Sep 06, 2009 | Relisys RLT1720 17" LCD Monitor
Acer AL1916W pluged into lap top but can't get both to run.
Have you used the Fn button on your laptop and changed the video display Icon on the Blue Function keys. You need to change the display wait a few seconds for it to take affect. There are several modes try them all so you know how to use them.
Mar 20, 2009 | Acer AL1916W 19" LCD Monitor
Lap top wont boot up past the windows screen
This generally indicates that a sector in the hard drive has failed, and the hard drive will need to be replaced. With a bad sector the drive reads to the point of the bad sector and past the bad sector, but can't put the info together, so it tries to boot, but can't. Unfortunately, your only option is replacing the hard drive.
Aug 01, 2008 | HP Computers & Internet
Lap top screen
welcome to fixya
i would try this first goto device manger in your computer and find the video card in the list and see if it needs updated if this does not work it might be that the video card might be bad but it sounds like a video card update driver is needed
i hope this helps you out have a good day;:)
Jul 11, 2008 | Computers & Internet
Go to the BIOS menu and select the Main Tab... see if the computer sees your drive. If not send it to the manufacturer or look to see if you can get to the HD without cracking open the main case to the laptop
if you can... check the connection from the HD to the connectors to the motherboard
Apr 08, 2008 | Computers & Internet
Sharp Actius AL27 Notebook Logo
115 people viewed this question
Top Sharp Computers & Internet Experts
Jason Harris
Jason Harris
Ricky Ostrom
Ricky Ostrom
Are you a Sharp Computer and Internet Expert? Answer questions, earn points and help others
