Question about Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer
Wet towels & blankets stacked on working dryer
I work at an animal clinic and we do laundry all day long. Wet towels & blankets are taken out of the washer and stacked on the dryer so the next wash load can be started. The dryer is on while the stack of heavy towels and blankets are on it. How does this affect the drying time and most importantly, what can happen to the dryer?
    President:
  • 2,992 Answers
This won't affect drying time unless the load is so heavy it causes the cabinet to warp and disturb the door seal. If you haven't had any problem with this so far you can probably keep doing it. (The machine is designed to support the weight of a wet load in the drum, and should have some safety margin. But why not invest in a roll-around laundry cart like you find at laundromats and keep the wet load there until the dryer is clear?) You might need to be more concerned about rust starting on the top of the cabinet if the enamel is scratched, since it's not usually subjected to wet loads being piled there. You should also check your vent pipe frequently to make sure it stays clear with all the drying you do. Clogged lint screens and vent pipes will definitely lengthen drying time.
Posted on Feb 18, 2009
Washer Dryer Stacked Combo won't start and didn't drain properly.
Hello Joshua, thank you for your post!
From my understanding your Frigidaire laundry center is not starting and did not drain properly. It is possible that this could be a miscommunication within the laundry center and a reset may help clear that out for you. In order to reset your laundry center you would need to disconnect power from it for at least ten minutes. If that does not help your laundry center you may need to seek assistance from a professional technician for proper repairs. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Apr 11, 2016 | Frigidaire Washing Machines
Lion Brank Nature's Choice Organic cotton sheds like crazy. What do I do? Made a beautiful baby blanket and afraid to give to the mommy, baby will end up with a mouthful of cotton.
You may want to soak the (finish product) of the blanket in a warm soapy water (bar/bath soap is prefer). Let it stay for about 20 minutes or so. Do not wring or dry it in the machine. Use a fresh towel. Lay the towel on flat surface. Put the wet blanket on top of towel. Roll the towel together with the blanket and add a little pressure to the roll to get the excess water out of the blanket. If still need it take another fresh towel and do it the same way. Then, lay flat to dry. Warm water and soap usually will make the fiber to be less sheds. Good luck!
Aug 02, 2010 | Lion Cotton Yarn
Washer not draining properly.
your pup is not working properly it may have somethig inside or draining house coud be that problem too good luck
Nov 05, 2009 | Maytag Neptune MLG2000A Front Load Stacked...
Dryer stopped heating
this is likley to be the heat seconsers or its the heater/s burnd out if one of the elements have died on you it will only partly dry the washing,, not a hard job to fix but still a bit pricy,
Oct 24, 2009 | Kenmore 88732 Top Load Stacked Washer /...
I am trying to figure out the capacity on my Kitchen Aid dryer, model KEYS677EQ1.
dear customer the capacity for a dryer is mostly comen sense for example if you dry blankets they are farly heavy you can put as much as you like in your dryer but dont forget that wet cloth is heavy on your dryer or wet jeans it will work no problem but on the long run your dryer will wear out faster because of the weight normal clothe what goes in the washing machine goes in the dryer thankyou have a great day from gilles
Mar 15, 2009 | Dryers
Whirlpool LTG6234DQ Stopped Now Won't do anything
a sink stopper will not damage your unit its to big,,it cant get though your wash basket...check your outlet,,or use another out rated 15 amps or more..
Nov 23, 2008 | Whirlpool LTE5243D Top Load Stacked...
Frigidaire FLEB8200DS Top Load Stacked Washer / Dryer Logo
176 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
