Question about Canon PIXMA MP530 All-In-One InkJet Printer
Connot send fax
Dials and gets fax tone but cuts line half way through.
Error Tx report: NG #018
Please help
  • 544 Answers
Thank you for using Fixya.com.
please try to log it off and check carefully the plug if it is connected properly. like the connection to line and unit.
try to switch on again..
thanks,
Posted on Feb 18, 2009
  • Mark Milan silaran
    Mark Milan silaran Feb 18, 2009
    thank you for using Fixya.com.
    thanks,
    Guru:
  • 832 Answers
Hi there!
thanks for using Fixya.com!
I suggest you try to call first the receiver and ask, perhaps they are having with their lines or fax machine. From your side, pls check with your Telephone provider for assistance.
In addition, pls check your cables, and connections.
Regards!
Pls. don't forget to mark!
    Problem Solver:
  • 11 Answers
Hi.. TX error is transmit error... can you lower the baud rate / transmission rate... this should solve the problem...
What does transmission report cdoe NG290000 mean on a Sharp MXM363n MFP When trying to send a fax?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Jun 12, 2014 | Sharp Mx-M363n Copier, Printer & Scanner...
How to send fax? activity report shows MODE:tx g3 and resust shows:ng00ff
The result NG 00FF means that the machine has tried to send a fax and gone through it's 3 redials and ended up failing to transmit. You do not say if you can receive faxes?
1. Make sure the telephone line you are connected to will make an outgoing and an incoming call. try this with a good working telephone.
2. Make sure you are using the genuine canon telephone line lead.
3. Make sure the line lead is plugged into the LINE socket and NOT the TEL socket.
4. Press the HOOK button on the fax and you should hear the dial tone through the speaker.
If all the above works and is correct then the machiine has a problem but i doubt it as you are getting 00FF and if the machine was at fault you would get a different error.
I reckon the above should cure your problem.
Good luck.
Jul 09, 2011 | Canon imageCLASS MF4150 All-In-One Laser...
Unable to send faxes Error code NG #018 appears
You need to apply Canon's firware update at http://www.canon.com and search for fumx310swin1040en.exe if you have Windows or for an iMac the file is MX310 series Firmware Upgrade Utility Ver. 1.040 (Mac OS X) with a file name of fumx310sosx1040en.dmg
Mar 07, 2011 | Canon PIXMA MP830 All-In-One InkJet...
Trying to fax with pixma mx7600. Plugged phone
You probably want to plug the phone line (the line from the wall) into the port marked "L" for line on the back of the Fax machine. The jack with the picture of the telephone handset is for your optional voice phone to share the same line with the fax machine.
Apr 29, 2010 | Canon PIXMA MX7600 All-In-One InkJet...
Every fax we try to send it comes up with a error tx report of "NG". What does "NG" mean and how can we fix it?
Hello.
NG means: Some or no pages sent.
Check the paper feeder to see if the page is pulling through.
Listen to see if the fax line "sounds"like it is working or if you hear dialing or not.
Hope this helps.
Mar 22, 2010 | Canon FAXPHONE L80 Laser
Getting Error TX Report: Result 'NG' - what does this mean???
It means No Good or Not Good, fax was never received for a number of reasons.
Oct 07, 2009 | Canon FaxPhone L75 Plain Paper Laser
Faxes won't complete transmission
those noises you hear are line noises via your phone line, not machine related but they wreak havoc on faxing. first you need to replace the actual line connecting the fax machine to the wall. If this doesn't fix the problem then have your phone lines tested. also make sure your machine is set for digital or analog service, depending on which you have. Good Luck.
Sep 20, 2008 | Canon PIXMA MP830 All-In-One InkJet...
Canon fax mp780 says 'ERROR TX REPORT' 'result NG', what do I have to do to to snd the document? The manual has no translation of error codes!
If you go into the fax tx settings and turn off ECM setting, the fax should send (at least it did for me when I had the same problem).
Jun 28, 2008 | Office Equipment & Supplies
MP830 Canon Faxing problem
Display the fax menu and then select Print Report\List and print the Users Data List. Check the setting of the ECM TX setting. If this is ON turn it OFF. This is the Error Correction Mode setting, probability is the fax you are sending to is not ECM compatible. The MP830 is suppose to automatically send in standard mode if receiving machine is not ECM compatible however I am not sure how well this works. Turn the ECM setting off by displaying the Fax Menu and then select Maintenance\Settings, Device Settings, Fax Settings, TX settings, ECM TX.
Feb 25, 2008 | Canon PIXMA MP830 All-In-One InkJet...
I bought philips faxjet 335, tx error
sounds like your communication board is out or your phone line is not working when you unplug your line and put a phone on it can you get a dial tone? then your fax machine is probably broke
Dec 14, 2007 | Philips FaxJet 375 Plain Paper Inkjet
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
784 people viewed this question
old marine
old marine
Corne Viljoen
