Question about LG WM2487H Front Load Washer
Water is not draining out
My washing machine model WP-9240 semi auto, water is not draining out inspite of Drain switch is operated what is the problem
  • LG Master
  • 19,396 Answers
Check that the drain hose is not clogged.
Access to the drain pump and check the drain pump intake, that is probably filled with debris.
Ensure that the drain pump is working, the pump should be energized directly by a technician to test it.
If the drain pump is fine , and you already tested water level switch, then it is either a bad control board, or a lose contact on the drain pump wiring harness to control.
Posted on Feb 18, 2009
LG Semi Automatic WP 9220 washing machine water is not draining out what to do
Enter your model number into the self help section of repairclinic.com, you will receive specific trouble shooting info for you appliance.
May 11, 2015 | LG Washing Machines
Error F-H scrolling?
F/H:
Condition
No water detected entering machine or Pressure switch trip not detected.
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation
mainly caused by low water pressure into the water from the customers water supply, or clogged inlet water valve screens.
Make sure you don't have any duct tape or something around your drain pipe, it needs that air gap to prevent siphoning.
Oct 22, 2007 | Kenmore 44932 Front Load Washer
How do I fix water not staying in the wash tub of Twin tub, LG WP 750R?
If your drain is not high enough the water will siphon out while filling. Check your owner's manual for correct height, usually about 39 inches from ground
Jun 20, 2014 | LG Washing Machines
Why does my washing machine does not drain the water inspite of replacing with a new drain pump
Good Morning Friend,
I understand that your Frigidaire washer, model# GLWS1339CS, will not drain the water even if you program it to just drain. I also see that you just replaced the drain pump in your appliance. I suggest checking the drain hose to make sure it is not kinked or clogged. I would also check your home's drain system to make sure that it is not clogged either. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 21, 2014 | Frigidaire GLWS1339CS Top Load Washer
Water gets drain cannot remain in the tub for wash ...type of my washing machine is LG WP 9031 top loading semi automatic..
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Sep 14, 2010 | Washing Machines
My washing machine model 8204 semi-auto is having problem of water leakage through the drainage at very low pace taking 2-4 hrs . what to do? plz suggest.
You need to raise the drain pipe up about 250mm to stop the water siphoning out. When it is high, the flow will stop untill the pump tells it to come out.
Sep 01, 2010 | Samsung Washing Machines
My lg washing machine is a semi automatic model 6.2 kg . water is not getting drained don't know why?
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Apr 09, 2010 | LG Washing Machines
Washing machine will not spin or drain
if your machin is semi automatic, check for the following thing. there is belt thye thread connecting the drain controller and the drain switch. this should have worn out. open the cabinet and check it out. the spin also wont work unless the drain switch is good and clear.
May 26, 2009 | Electrolux Washing Machines
Whirlpool calypso washing machine
WP HAS HAD A ON GOING ISSUE WITH THIS THAT IS THE REASON WHY THEY REDIGNED THE DRAIN PUMP. YOU NEED TO 1ST DRAIN OUT AS MUCH WATER MANUALLY AS YOU CAN THEN DISCONNECT ALL YOUR HOSES FROM WALL TAKE THE WM OUTSIDE TO DRAIN THE OTHER 3 GALLONS OF WATER YOU CANNOT SEE. TURN THE MACHINE ON ITS BACK THEN USING A 5/16 NUT DRIVER REMOVE 4 SCREWS ON THE BOTTOM PANEL. REMOVE PANEL AND YOUR DRAIN MTR IN ASSESSIBLE. THE PART CAN BE ORDERED AT WWW.REPAIRCLINIC.COM
May 30, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
LG WM2487H Front Load Washer Logo
888 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
