Question about Dell Dimension 8200 PC Desktop
Showing message out of range
Just the message out of range on monitor.
  • Dan rogers
    Dan rogers May 11, 2010
    What settings did you change when you got this message?
    Sounds like your moitor cannot handle the image your computer is putting out. Try starting the computer in safe mode and turn the resolution down and make sure the screen refresh rate is 60hz for an LCD monitor
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there
    Does the PC turn on?
    Problem Solver:
  • 6 Answers
"Out Of Range" is more than just resolution. It means your video adapter is set to a resolution/refresh rate setting that is outside the range of supported signals.
Go into your Video Adapter's settings, look at resolution then the refresh rate (Hertz), and compare to those supported by the monitor.
When I had a similar problem, I noticed that somehow, the refresh rate was set at 59HZ which is unsupported. After changing to 60HZ (which is supported) the problem went away.
Posted on Nov 01, 2014
    Problem Solver:
  • 11 Answers
Your monitor settings within windows are set too high for the monitor to display... When computer first boots.. be ready and press the F8 key...
Enter safe mode.. Reset the display properties in control panel to 800 by 600 for a start. Setting the resolution too high past the monitors ability will give you that message.. Most monitors are able to display 1024 by 768 just fine.. Out of range.. means the display settings within windows are out of the monitors range of ability to display the screen resolution you have set... Good luck!!
Posted on Feb 18, 2009
My computer monitor shows a message "out of range". I can't get rid of the message or show anything from my computer.
The resolution your computer is sending is greater than the maximum support resolution of your monitor that isn't working or is a resolution not supported. Connect one of the monitors that works and turn down the resolution to something small (800x600 or 1024,768) and then switch to the original monitor back, you should see a picture and can adjust the resolution to something larger that the monitor supports.
Aug 08, 2014 | Westinghouse L1928NV Monitor
DELL E153FPf doesn't show the image
OSD Warning Messages A warning message may appear on the screen indicating that the monitor is out of sync range.
Cannot Display This Video Mode
This means that the monitor cannot synchronize with the signal that it is receiving from the computer. Either the signal is too high or too low for the monitor to use. See Specifications for the Horizontal and Vertical frequency ranges addressable by this monitor. Recommended mode is 1024x768 @ 60Hz.
Occasionally, no warning message appears, but the screen is blank. This could also indicate that the monitor is not synchronizing with the computer or the monitor is in a power save mode.
Jan 18, 2010 | Dell E153FPf 15" TFT LCD Flat Panel...
Frequency out of range 11khz/ 119khz message
The PC is sending out the resolution that is too high for the monitor to handle, you need to set the resolution of the PC to be the native resolution of the monitor and set the refesh rate to be at 60Hz.
Jan 12, 2010 | Envision H191W Monitor
I have aoc monitor the problem is out of range
Describe your AOC S7M51, 17 in. CRT Monitor Problem. with external TV Tuner card connected, Message shows "Warning, Not Support, Out of range" and with CPU connected, the same message shows from the booting... ??? are AOC monitors trusted for the efficiency ?
Dec 04, 2009 | AOC CT720G 17" CRT Monitor
Hi I get a "signal out of range" message until windows xp starts. This means I can't get into safe mode or see start up messages. Any ideas please?
You see "Signal Out of Range" does not mean you cannot go to Safe mode or see startup messages. It shows up when you dont have a display. The refresh rate of your monitor is a little slow. So when you wana go to safe mode, press the Power button and start pressing F8 option and you will get the safe mode option and you will see startup messages when you will get one. Your computer is perfect. :)
All the best.
Regards,
Shrey
Oct 09, 2009 | HP L1955 19" LCD Monitor
Over range message on monitor
switch on the computer then press F8 F8 contineusly then highlight on safe mode press enter then display will see if you want to work on high resolution then attatch external display card and best will be AGP card then you can watch movie much clear also 3D games
Nov 25, 2008 | Proview PL926WBi 19" LCD Monitor
What does out of range mean on my asus lcd monitor i am trying to hook up my ps3 through my vga port
Out of range is comes when the monitor is not working with the cpu. May be you are not connected it well . and you can see the message out of range when the operating system is shut down.If it shows message when the cpu running please connect the vga cable into the graphics card port.
Apr 29, 2008 | Computers & Internet
Monitor out of range
Most commonly, this problem is caused by an incorrect refresh rate setting. LCD monitors typically DO NOT support refresh rates higher than 60hz - and this is no exception. Try running the game in "safe mode" if it has one. Adjusting the in-game video settings should solve the problem, just look for a screen refresh rate or any video-related setting with a number followed by "hz". Set it to 60, everything should be fine.
It could also be that at some point the game changes resolution (this frequently occurs if there is an in-game movie or cut-scene). In this case the resolution settings for the in-game movie might be at fault, check them if you can.
Sep 23, 2007 | Computers & Internet
Dell Dimension 8200 PC Desktop Logo
356 people viewed this question
Alun Cox
