Question about HP PSC 2410 All-In-One InkJet Printer
Will not find home position after switching on makes clicking noise screen 's got egg timmer showing after afew minutes it stops clicking but remains with egg timmer showing help?
  • 4 more comments
  • pdcoup Feb 27, 2009
    Same problem clicking sound and thinking timer in viewer window will not print any thing even retried resetting but it does not help.
  • Anonymous Feb 28, 2009
    clicking n keep just making weird noises , hellp no printing !!
  • Anonymous Mar 03, 2009
    Makes clicking noises from scanner and wont print. Scanner can't find its neurtral position on the right side.
    I curently have the exact same problem it is in the scanner light carriage not the printer cartridge carriage I have experienced several times before and power down and wait until the unit wants to work again very seldom does this occur however only when you have an immediate need for its use.
    come on firestorm 500 help us out why does the scanner bulb carriage not sense it is in the idle position or park possition? is it easy to remove glass to push into park or idle possition?
  • Anonymous Mar 09, 2009
    AUUGGGHHHH!!!!! Stupid Thing!
    I too have the same problem... and the print cartridge is all the way to the right... I think it also has to do with the scanner bulb in some way. (Which I don't need to print!)
    Help!
    Problem Solver:
  • 16 Answers
The carraige is moved by a toothed rubber belt and plastic gears. Unplug the machine, open the front cover, and manually relocate the print carraige to the far right. Close the cover and plug machine back in. Hope this helps.
Posted on Mar 01, 2009
My home security light is flashing how do i turn it off
you need to enter the code and press reset
then the alarm condiction is reset
Dec 04, 2014 | Home Security
I have an HP PSC 2510 that has a permanent hourglass busy symbol showing. When turned off and on there is a grinding noise from the scanner transport mechanism which ceases after about 1 minute but the...
Looks like a faulty gear mechanism in your scanner. It is not able to return to the home position. You could try a hard reset: Unplug from power source and PC, wait about 5 minutes and try again. If the issue recurs, then you will need to take it in for servicing..
Jul 04, 2008 | Office Equipment & Supplies
1991 nissan maxima squealing clicking noise behind the dash
while clicking is happening place your hand on the heater blower motor and you will feel it coming from there. change the blower fan.
Apr 07, 2017 | 1991 Nissan Maxima
My Kenmore he front load washer stopped at the rinse and spin cycle. I don't know the model but it only a few years old. It made a load noise before stopping. I attempted to get it going again wit
Kenmore front loader. stopped at rinse. First ck to see if you washer works at different settings if so its very possible its your timmer or what called the wig wag or solonoid this switches the machine to spin & rinse. A basic service call should resolve your problem.
Jan 30, 2012 | Washing Machines
My mitsubishi tv wont come on and green timmer light blinks fast
Try the blinking light repair kit from http://www.tvrepairkits.com/xcart/home.php?cat=2658 . This kit has fuses and capacitors that are designed for your TV.
I hope this helps.
Apr 24, 2010 | Televison & Video
Epson SX100 Scanner makes a loud clicking noise!
On the back of the Epson Perfection 1660 Photo there is a lever that shows a lock and a unlock by where you plug in the wire to the computer. It must be in the unlocked position otherwise it will make that loud clicking noise and not work. Hope this helps.
Apr 07, 2010 | Epson Office Equipment & Supplies
LFX25970 Bottom Freezer Refrigerator This morning it began to make a clicking noise coming from the ice/water dispenser and cold air was coming down from the opening. I pushed the lever for ice and it...
You may have an issue with one or more of the following:
* icemaker
* dispenser actuator
* ice chute door assembly
* ice dispenser solenoid (if the solenoid is stuck in an open position, the ice chute door/flap would remain open allowing cold air to escape).
Contact an appliance service company.
Feb 16, 2010 | LG Refrigerators
Coil is freezing, stops cooling, no water at despencer. turn timer knob manualy and it does shut off and back on again. defrost timer or heater?
depends on the brand, most likely the defrost thermostat.
heaters rarely go bad, timers usually will not advance causing the coil to frost over.
if you turn the timer to the "defrost" position and wait for 20 minutes. after a couple of minutes it should have the heater get hot and then frost should drip onto the heater and make a "hissing" or "sizzling" sound. if it does make these sound, then replace the timer.
Dec 31, 2009 | Refrigerators
After clossing door properly and inserting coins starting the machine by pressing start switch machine timmer, water valves drain pump every part is working except motor it remains idal while it is new....
If the motor is making a loud humming noise, look for (and replace) a 'start' capacitor which should be mounted on the motor or nearby. If it makes no noise at all, then it is not receiving power from the machine. Look for a defective relay or possibly the control unit itself. A less likely problem might be a broken wire wherever there is movement or vibration. Make sure that the motor can be turned by hand when the power is off. Hope this helps!
Nov 18, 2009 | Washing Machines
PROBLEM WITH SONY WOOFER
This must be cable connection problem. There may be loose connection or cable is not working properly so change the cable and enjoy. Thanks
Aug 10, 2007 | Sony DAV-DX255 System
HP PSC 2410 All-In-One InkJet Printer Logo
125 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
