Question about Acoustic Research 900MHz Wireless Stereo Speakers with Auto Tuning
AR Wirells Speak Transmitter Stopped Working
The thing worked for a month but now it does no light up whe I plug it in.
  • Anonymous Mar 04, 2009
    it works when "it wants to work." I bought it about a year ago. Almost moody.
  • 19,396 Answers
Hi there ,
Let me know if you did the steps below, then we can proceed form there:
Try unplugging the transmitter from power adapter, if it also has batteries remove them. Also unplug transmitter audio cable.
Then remove batteries/unplug adapters from speakers.
Wait few minutes and reconnect the system.
This is a proper hard reset, and can fix minor problems.
If when you re connect the transmitter does not glow, or you do not have sound on one or both channels then there is a fault.
Check the transmitter audio cable, a short in there can cause troubles.
Posted on Feb 23, 2009
Over the Range Light Stopped Working
It is a good chance that the bulb (s) have burned out. I would think they would last longer than that but things are not as good as they used to be. Unplug the microwave before removing the bulbs. Especially if they are the screw in type. GE usually has two bulbs in there and they could be the halogen type that just plug in or the screw in type.
Mar 28, 2014 | GE Profile JTP18 Electric Single Oven
Acoustic Research Model AW871 wireless sterio speakers
Your connection between the AR transmitter and the ONKYO receiver sounds solid. I'd guess it's the wireless speakers that are the wrong point, or at least that's what I'd look at first. Doing a bit of research, I noticed a couple minor points. First, these seem prone to RF interference from other RF devices. Have to tried switching channels on them? Second, someone reported theirs would not work properly unless the speakers were turned on just before the transmitter, and turned off shortly after the transmitter. Apparently you have to hold the button on the front in for 5 seconds to turn the speakers on or off. I know that's rather basic, but it's been a few days and no one else has responded, so I figured we should start somewhere.
Aug 27, 2007 | Audio Players & Recorders
My Belkin F8Z441 has stopped working after a month. It's charging my iphone but the transmitter doesnt work at all. No display. Please help...
wrong... you need to open device to check the cable connections... due to the devices ability to turn this pulls out some of the connections.
Feb 21, 2011 | Belkin F8Z441 TuneBase FM with HandsFree...
My cordless logitech mouse just stopped working??
batteries?
press connect button on transmitter and mouse
verify that the transmitter is firmly plugged in mine falls out because of the usb to ps2 adapter
make sure windows is even detecting it through device manager
does it light up at all you may have to flip the mouse upside down to see a led light
the above is in no particular order
i wish you the best of luck
Dec 04, 2010 | Logitech Cordless Mouse
I have a Liftmaster Model 2500 opener. It is about seven years old, and worked great until recently. It has stopped working, including no lights at the Multi-function door control. If I unplug the...
THIS IS PROBABLY CAUSED BY A SHORTED WIRE.
OR A BAD WALL CONTROL.
DISCONNECT WALL CONTROL & TEST.
IF STILL NO RESULT DISCONNECT WALL CONTROL WIRES AT THE POWERHEAD & TEST AGAIN.
REPLACE WIRE OR WALL CONTROL.
HOPE THIS HELPS
Nov 15, 2010 | liftmaster Chamberlain Garage Door Opener...
I have a Dell Vostro and the wireless mouse justed stopped working. The funny thing is my Mom has the same computer and she called me to tell me hers wasn't working and that's how I found out niether was...
one of two things, the wireless trasmitter boxes could be faulty or they have been zapped with rf from a radio transmitter, { Iam a ham and have zapped mine when transmitting, }just unplug the mouse usb lead then plug in and it should restart working
Jul 01, 2010 | Dell Wireless Keyboard Optical Mouse w0147
I have wireless speakers and the transmitter stopped working. Nothing happens when you plug it in--??? It's only a month old. AW872
Hi I also post in here , so that you can let me know how it goes.
If you find no problems , then unit is defective, as it is under warranty contact Acoustic Research to validate the warranty here and get the transmitter or the whole set replaced.
http://www.acoustic-research.com/homedecor/HomeDecorInfo.do?ACTION_TYPE_ID=ACTION_TYPE_CONTACT_INFO
Feb 13, 2009 | Audio Players & Recorders
Fan and light not working
The receiver in the fan might be burnt out,it is at the ceiling in the large base or maybe the transmitter. Do you have fresh batteries in the transmitter?
Jan 01, 2009 | Minka F701-DRB 52'' Ceiling Fan
Logitech wireless headphones
Trying re-syncing the transmitter and the headphones. Hold down the power buttons on both until they alternate red and blue blinking, worked for me and now they work just fine. Got that from the Logitech FAQ website.
Feb 27, 2008 | Logitech (980361-0403) Headphones
Transmitter not working
You can 'pump up' the circuit on the transmitter by pumping the power connector in and out of of the back of the tranmitter to the beat of Beethoven's 5th: da duh duh duh, da duh duh duh, da Duh Duh.
It is a little awkward the first few times you try. You have to get the power connector in far enough each pump that the unit gets a pulse of power. It has to be pumped at the right pace, not too fast, not too slow, the beat of Beethoven's 5th is pretty quick and just right.
I have been powering our WSP155 transmitter unit on at work this way for several months. We originally had 4 sets of these, only using 1 transmitter at a time. 1 transmitter, 8 speakers. Over the course of a year or two, all of the tranmitters went bad the same way and now that I discovered how, I can make them all power on using this method, so I am pretty sure yours will power on this way too.
Nov 22, 2007 | RCA WSP155 Main / Stereo Speaker
Acoustic Research 900MHz Wireless Stereo Speakers with Auto Tuning Logo
727 people viewed this question
Top Acoustic Research Audio Players & Recorders Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you an Acoustic Research Audio Player and Recorder Expert? Answer questions, earn points and help others
