Question about Brother FAX-8070P Plain Paper Laser
Dark vertical lines
Hi, when we send a fax it is received with a dark vertical line. If we make a copy we have a vertical line too. However, received faxes from other people are clear. We have changed the toner cartridge. We have cleaned the machine. Any ideas?
  • 318 Answers
You have to clean the scanner.Open the dock feeder area,and make sure the scanner glass is clean sometimes the glass look clean but just a smaal dot on the glass can cause a line.Clean also the white area above the scanner.The white area above the scanner help for shading operation of the mchine.Make sure you clean with a sullotion that can remove ink but not damage plastic.
Posted on Feb 18, 2009
Faxing problems
Check the scanner glass for ink or lint residue. This is what normally causes lines on faxed and scanned documents and pictures. Here is a link to explains it and shows where to check for the residue.
http://www.ccl-la.com/blog/index.php/lines-on-scanned-or-copies-pages/
Jul 27, 2012 | Lexmark X6675 All-In-One InkJet Printer
Some lines are missing when receiving faxes
Horizontal or vertical? Or do you mean lines of text?
Did you try to copy a document? If the copy is fine, then the fault is on the sending side, or there are severe transmission errors.
If the copy exhibits the same faults as the received faxes, then something is wrong with the printing part of your fax, and solving the problem will depend on the printing technology used (inkjet - clogged heads, need cleaning, or empty ink, needs replacing etc.)
Feb 10, 2010 | Office Equipment & Supplies
I have a Brother Fax 2850. When I send a fax the receiver has advised me that there is a vertical black line approx 2'' thick which blocks out some wording. How do I fix this?? Many Thanks Heather
Something is jammed in or covering the optics.
Check the area where the original document is placed for faxing.
Open this area and clean any liquid paper, sticky tape or staples covering the optics.
Test by making a copy. When the black line on a copy goes away the unit is fixed.
If the receiver is still getting this black line then it is probably their machine and not yours.
Send a fax to this number. 1300 368 999 It will send you back a copy of what it receives.
Nov 17, 2009 | Computers & Internet
I get a dark line in the middle of the pages
Dust in the scanner, clean the scanner line inside the refill  compartment
Mar 06, 2009 | Brother IntelliFAX 1270E Plain Paper Fax
Poor fax printout quality
I would say you have a bad drum / toner cartridge.
Stuff you receive with vertical lines is probably the sender's dirty scanner.
Nov 04, 2008 | Canon LaserClass 2060P Plain Paper Fax
Transmitted pages are too dark, practically unreadable :
I suspect your scanner unit is going bad or it is extremely dirty.
Making a copy gets same result as when you send.
Nov 01, 2008 | Brother FAX-8360P Plain Paper Laser
Dark line
If the line is not on your recived faxes then you need to clean the area the paper passes over when sending. any marks could cause this.
Mar 19, 2008 | Brother IntelliFAX 2600 Fax
Copies here and recipients faxes: dark, lined
How long has the drum been in there?
try this:
1-take out toner, look and see if it is ok. do you see stripes on it?
2- look at the drum are there any black rings on it? ( you did not specify white or black lines)
3- where the glass is on the opposite side ( the part you lifted to clean the glass, look at it standing from the back. you will see a white metal plate with some springs in it if you touch it. this is the reference that the fax has if there is/are a black dot on it it will give you a black line clean carefully. if it is scratched use white out to cover and make white again.
For the darkness try making a copy in photo mode if it is still too dark change drum.
Dec 07, 2007 | Canon FAXPHONE B640 Plain Paper Bubblejet
Black vertical line appears on faxes i send and receive
Small slit of glass "scanner glass" needs to be spotlessly cleaned, open lid to left 2cm wide runs width of lid.
G'day from Oz
Dec 03, 2007 | Samsung CLX 3160fn All-In-One Printer
Brother FAX-8070P Plain Paper Laser Logo
406 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
