Question about FrancisFrancis! X1 - Stainless Steel Espresso Machine
I have a Francis X1 Trio. Has anyone ever tried to use ground coffee and can it work. I hate the pods and would love to try to use regular ground with a tamper, but I'm afraid of ruining the machine.
I would be interested in the same. Did you manage to order a ground coffee adapter for your Francis x1 Trio and if yes, does it work? Thanks
Posted on Jan 02, 2010
  • 9 Answers
You need a ground coffee adapter, these are available from various sites online. Do a web search for X1 ground coffee handle and you'll find one. Make sure it's the right one for your machine (check to see if you have the aluminium or brass boiler version)
Just found this site - It's in the UK and I'm not sure if you are but they will probably export to you.
http://tinyurl.com/lhxvg6
Regards
Richard
Posted on Sep 03, 2009
Ground Coffee Kit/Holder
There were two versions of the Francis Francis X1; one without the logo (older) and one with. I guess your only chance is ebay; but why would someone sell the holder without the machine?
May 27, 2014 | FrancisFrancis! X1 Espresso Machine
Francis francis x1
Take out the two screws on the front panel. There are other screws in the oval top section. When you find them and remove them you can slide off the sleeve and can then get at all the works.
Jan 03, 2014 | FrancisFrancis! X1 for Ground Espresso -...
Can I adapt a Francis francis x1 to take ese pods?
My X1 came with an ESE pod holder and a ground coffee holder so they are definitely available.
Dec 02, 2012 | FrancisFrancis! Coffee Makers & Espresso...
I have a Francis Francis X3 machine and would like the attachment to use ground coffee as at the moment I can only use pods.
If you have an X3 Trio you are out of luck.
If you have the older model, you can buy 'ground coffee conversion kits' or you can use a ground coffee portafilter from an Ascaso Dream/Arc etc.
See: http://coffee-stuff.blogspot.com/2009/11/thing-of-beauty.html
Oct 29, 2009 | FrancisFrancis! X3 Espresso Machine
I have a francis x1 coffee machine need a seal
Call 877-854-4141, which is Empire Fulfillment. If you are not sure if the part is exactly right, ask them to email you a diagram of the part.
Oct 12, 2009 | FrancisFrancis! X1 - Stainless Steel...
FF X3 vs. FF X3 Trio - We are not POD people!!!
The X5 has the same internals as the X3, so it really is a matter as to if you like the styling. The results from the X5 and X3 should be the same. Sadly you can't convert a Trio to ground coffee.
There is nothing about the X3 that should wear out in such a short time, so unless you have let the case get damaged - there is no reason it can't be brought back to as new condition. All internal parts can more or less be found though alternative suppliers, Lelit and Ascaso models share many components.
Oct 02, 2009 | FrancisFrancis! X3 Espresso Machine
Francis Francis X1 blowing thru ESE pod
Check the group head shower, make sure it does not have any defects(cracks, scratches or unusually large holes).
May 30, 2009 | FrancisFrancis! X1 - Stainless Steel...
I recentlty bought a Francis X1 (2000 model). I
There are two different handles made for this unit (I own an X1 and have both). Both of these handles have baskets.
First - The pod handle has a basket area that is very shallow, about 1/3 of an inch deep and the basket has very small holes.
Second - The handle for loose grounds came with two baskets, one for a single dose, and one for a double dose. Both removable baskets have the very small holes for the espresso to drip through.
You must have a basket in the handle in order to use the machine. If you try to make espresso without a basket, you'll just make a mess. Besides, the machine will never be able build enough pressure to extract espresso from the grounds.
Search the net (ebay?) for francis francis x1 handle.
Good luck
Feb 24, 2009 | FrancisFrancis! X1 - Stainless Steel...
Francis Francis X1
Some leaking from the group head of the machine is totally normal while the machine is heating. The reason for this is that the valve that sits above the shower screen is simply a spring and rubber ball. The spring expands, creating a seal with the rubber ball and the boiler, once the boiler reaches a specific temperature. Until the boiler temp is reached, leaking from the group head will occur.
Feb 26, 2008 | FrancisFrancis! X1 - Stainless Steel...
FrancisFrancis! X1 - Stainless Steel Espresso Machine Logo
638 people viewed this question
Top FrancisFrancis! Coffee Makers & Espresso Machines Experts
Mike Cairns
Mike Cairns
Kolbrun...
Are you a FrancisFrancis! Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
