Question about Audiovox D1210 Portable DVD Player with Screen
Audiovox D1210 DVD won't load to play. When we put in a DVD to play a movie, the screen displays "loading" for a while and then reads "no disc". Using a can of air (and sometimes jolting the player itself) it will occasionally read the DVD and begin to play a movie. If I press Stop, however, the screen freezes and I need to Eject the DVD and start over. Suggestions?
  • mistyf Apr 06, 2009
    Audiovox won't load (or shows loading but never gooes on past this screen) or will not load a CD/DVD at all. This is a new problem as we did not experience this before - and we have had the Audiovox about 3 years.
    President:
  • 814 Answers
Your DVD players may have slip out of calibration. You can try setting them back to factory specifications. To do this go to the set up menu main page. Highlight preferences and press enter.Next highlight defaults and press enter. This will reset the DVD player to the factory settings. This procedure is explained in the owners manual on page 26. If this does not solve your problem, you can try using a cleaning disc to clean the laser head and transport. This should restore the laser, and transport so that you can use it. If you are still experiencing problems with the DVD player, you can call Audiovox customer support at this telephone number. 1-800-645-4994. Give them the model number of you DVD player and tell them about the problem you are having with the DVD player. I hope this information helps you with your problem.
Posted on May 30, 2009
Audiovox D1708 does not play movies. I put the DVD into the player close the lid and the screen says loading but doesn't play the movie
Try clean the lense a pieces of cotton bud or can not read the disc because the motor is not spin bring it to elecronic technician for repair.
Oct 21, 2012 | Televison & Video
Can this be fixed?
i have an audiovox dvd player model D1718 . i put the disc in and it says it is loading but then comes up no disc . how can i fix this problem?
Sep 11, 2009 | Audiovox D1708 Portable DVD Player
Audiovox D1998 portable DVD player will no long read disc.
This of course may not be the exact same thing, but mine did the same thing. Sounding like it was loading, but in fact pressing the open button it I could see the disc not spining at all (normally you would.) With the power off of course. I took all the bottom screws out (where ever the arrow points to a screw) including to the display. There is one ribbon cable easily disconnected. I lifted the mount the DVD sits on and reseated it. I put a disc in it, turned on the power and the disc turned. Great I thought. I reconnect the cable, put the screws back in - and its working.
Apr 22, 2009 | Audiovox D1917
Audiovox D1020 DVD player won't read DVD anymore
I have the same problem! The only way to fix this is to replace the motor that spins the DVD. if you take it apart and spin the DVD the movie will play. The motor is just wore out and has no torque to start the play process. I am still looking for a replacement motor for it and haven't found anyone that carries the motor required. Only Audiovox so far and they want 180 to send in and fix.
Nov 16, 2008 | Audiovox D1020 Portable DVD Player
Audiovox fpe1506dv
The problem that I'm having is that when I put a dvd into the player it tries to load the disc but never does. Therefore I cannot watch any dvd.
Dec 31, 2007 | Audiovox FPE-1505 15 in. HD-Ready LCD...
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
Audiovox d1210
We bought this player almost 5 years ago, and have the same problem. When we called audiovox at the time they told us that it was because some of the dvd mnufacturers had changed the format/technology in which they recorded the dvd programs. The biggest problem was with the Disney dvd's. Also, that they did not have any software upgrades at that time to upgrade the player. We used it for a while with the hit and miss movies that it would play, and then finally shelved it and bought a minivan with a preinstalled dvd player. Very rarely use the audiovox now. I am surprised; however, that after 5 years they would still have the same problem and have still not yet upgraded the software in this player. Good luck.
Nov 10, 2007 | Audiovox D1210 Portable DVD Player with...
Screen reads NO DISC
I had the same problem but I solved buying "Laser Lens Cleaner " Philips Magnavox after 3 attempts the DVD starts to work fine again. First only 3 min, then 10 min and now the entire CD cleaner and after I left the CD cleaner for 15 min I tried to play the DVD and WORKS!!! perfect!!!
Nov 08, 2007 | Audiovox D1420 Portable DVD Player
Audiovox D1210
You should not need the remote code to simply insert a DVD, or eject it. My experience has taught me that once a CD/DVD player starts having insertion/ejection problems with the tray, you might as well bite the bullet and get a new one. I wouldn't recommend Audiovox. Get a good, solid player like Panasonic or Sony.
Aug 19, 2017 | Audiovox D1020 Car DVD Player
Audiovox D1210 Portable DVD Player with Screen Logo
367 people viewed this question
Top Audiovox Televison & Video Experts
Jaime Hernandez
Are you an Audiovox Televison and Video Expert? Answer questions, earn points and help others
