Question about Hitachi Televison & Video
Hitachi 32LD6600B problem no sound just buzzing please help thank you
  • 5 more comments
  • sheilabrown1 Feb 18, 2009
    More information. I have disconnected everything tv only plugged in. It is more a constant beep noise than a buzzing noise. Any help would be grateful.
  • sheilabrown1 Feb 19, 2009
    More information think it may be a problem with sound board but how do I check it and where can I buy. What does sound board look like. please please help.
    More information took back off had a look nothing jumping out saying im broke. But have noticed that beeeeeeeeeeep is coming from one side only could this be that it maybe the speaker. The picture is perfect but no sound just beeeeeeeeep like a fog horn on a ship.
  • sheilabrown1 Feb 21, 2009
    Well Im calling repairman tomorrow hope it dont cost too much but i will yet you all know what the problem was it may help someone else.
  • sheilabrown1 Feb 22, 2009
    sorry that should of been let not yet and i dont know how ive duplicated this comment sorry
    Well got another problem now just dropped the laptop ah i going to cry. Better go and post for help about laptop now
2 Suggested Answers
bbl242003
  • 1637 Answers
SOURCE: Hitachi model No 32LD6600B turned telly off at
1. YOUR flyback is going bad 2. Peform a removal and replacement 3. check your error codes first to ensue nothing else exists 4. Proceed to change out the required parts 5. Observe all electrical risks 6. Order replacements from jimmyparts.com 7. Ensure to always remove power 8. Ensure to always use electrostatic wrist strap
Generally what occurs is the units soldered connections on the main projection board warm up as the system warms up. Thus, the loose capacitors, resisters, and diodes are causing the CHANGE when the system warms up. When metal contracts, it expands thus losing the connection needed for a solid connection. This process is normal after the units have reached their service life. Keep in mind that you can repair this but at the expense of time if you have never performed this type of work.
Posted on Jan 29, 2011
Hitachi 42hds52 plasma no audio,but LOUD buzzing comming from rear.any suggestions?please help
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 24, 2015 | Hitachi 42HDT52 42 in. Plasma HDTV
HITACHI MODEL # 53UDX10B has a flashing red light and a buzzing sound
If it was transported likely the set was damaged--one of the three picture tubes used could have been damaged--the flashing light is the set trying to come on and the buzzing is related to whatever is bad.
It needs to be opened and inspected.
May 18, 2012 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi model No 32LD6600B turned telly off at plug last night last night now will not come on no standby light if you heat power board it will come on and stop on until turn of at plug again Thanks
Jan 29, 2011 | Hitachi Televison & Video
Buzzing sound in the background on lcd rear projection tv 42v715
flinx2000,
Your description sounds like you have a bad color wheel. The color wheels generally do not have bearings, only bronze bushings. Due to all the heat generated in the set the little grease in the bushings dry out and the unit begins to make noise. This is not a difficult repair but does require alot of work and dilligence. If you think that you can tackle this repair you should read my tip at http://www.fixya.com/support/r4160054-replace_color_wheel_in_dlp_projection_tv which will walk you through the repair and get your unit going.
Thanks for using FixYa and please consider a maximum rating. Maximum ratings and testimonials help to keep the experts helping everyone. Thank you.
hardrocko
Oct 29, 2010 | Hitachi 42V715 Rear Projection Television
My Hitachi hdtv won't turn on. The lights blink and it makes a buzzing sound then after about a minute it shuts off. Any ideas?
Possible fault either in the power supply SMPS unit or the main board of the set. please checck my link:
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
If not helpful in the SMPS then check the main board for dry points, possible short in the convergence section.
Sep 22, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi plasma buzzing noise
sounds like bad audio pcb if buzz comes thru
the speakers,
Aug 19, 2009 | Televison & Video
Hitachi c2114t loud buzz on bright screen
sounds like you have a gun or picture tube shorting. check the bottom of the tubes when you turn it on and see it one of them is lit up more then the other two if you find that then unplug the circut board thats pluged into the tube and turn on the tv again and see if you problem goes away minus that color.
Feb 23, 2008 | Televison & Video
No sound on hitachi 53sdx01b
The first thing to try is rescanning the Freeview channels as it may just be a software corruption...if you have the option of "1st time installation" pick that.Also let me know if there is any buzzing sound coming from the tv..
Oct 16, 2007 | Hitachi 53SDX01B 53" Rear Projection...
Televison & Video Logo
140 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
