Question about Dell Inspiron 530 Desktop Computer
Voltage limits On a Dell Inspiron 530 what is the normal voltage input along with the high and low voltage limits.
  • Dell Master
  • 13,433 Answers
Are you talking about the powersupply? open the case of the computer, the powersupply reads all this information on the side.
Posted on Feb 18, 2009
Apc fail on line beep click
If Line voltage normal and your is a smart UPS, you may need to change the "nominal voltage" and high and low limits settings correctly using Powerchute +.
Apr 19, 2014 | APC Computers & Internet
My x type 3.0 has fault readingP1647 could you tell me what this means please
OBDII DTC
P1001 Key on engine running unable to complete; key on engine running aborted
P1100 Mass air flow sensor intermittent
P1101 Mass air flow sensor out of self test range
P1104 Mass Airflow (MAF) Sensor Ground Circuit Malfunction
P1107 Left MAP Sensor Circuit
P1108 Right MAP Sensor Circuit
P1112 IATS Circuit High Voltage
P1113 IATS Circuit Low Voltage
P1121 Pedal Position Sensor Circuit A Range/Performance
P1122 Pedal Position Sensor Circuit A Low Voltage
P1123 Pedal Position Sensor Circuit A High Voltage
P1137 No Rear HO2S Response
P1138 No Rear HO3S Response
P1157 No Rear HO2S Response
P1158 No Rear HO3S Response
P1171 All Cylinders Too Lean
P1172 All Cylinders Too Rich
P1176 Adaptive Fuel Metering Trim Too Lean
P1177 Adaptive Fuel Metering Trim Too Rich
P1178 Adaptive Fuel Metering Trim Too Lean
P1179 Adaptive Fuel Metering Trim Too Rich
P1187 Both Front HO2S Heater Circuits (High Resistance)
P1188 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1190 Both Front HO2S Heater Circuits (High Battery Voltage Short to Voltage)
P1193 Both Front HO2S Heater Circuits (High Resistance MAF Sensor Fault)
P1194 Both Front HO2S Heater Circuits (Open Short to Ground High Resistance)
P1196 Both Front HO2S Heater Circuits (High Battery Voltage Short to Ground)
P1198 Fuel Level Sensor (High Voltage)
P1199 Fuel Level Sensor (Low Voltage)
P1201 No. 1 Fuel Injector
P1202 No. 2 Fuel Injector
P1203 No. 3 Fuel Injector
P1204 No. 4 Fuel Injector
P1205 No. 5 Fuel Injector
P1206 No. 6 Fuel Injector
P1221 Pedal Position Sensor Circuit B Range/Performance
P1222 Pedal Position Sensor Circuit B Low Voltage
P1223 Pedal Position Sensor Circuit B High Voltage
P1224 Electronic Throttle Control Position Error
P1226 Mechanical Guard Circuit Range Performance
P1227 Mechanical Guard Circuit Low Input
P1228 Mechanical Guard Circuit High Input
P1229 Throttle Control Circuit Malfunction
P1230 Fuel Pump Relay Malfunction
P1235 VSV 1 Circuit Range/Performance
P1236 VSV 1 Vacuum Circuit Failure
P1237 VSV 2 Atmosphere Circuit Failure
P1238 VSV 3 Release Circuit Failure
P1240 Throttle Position Sensor Voltage Malfunction//Sensor Reference Voltage Low (Throttle
Fuel Tank Pressure)
P1241 Throttle Position Sensor Voltage Low Input//Reference Voltage Low (Throttle Fuel
Tank Pressure)
P1242 Throttle Position Sensor Voltage High Input
P1243 Throttle Position Sensor Ground Malfunction
P1245 Crank Signal Low Input
P1246 Crank Signal High Input
P1313 Misfire Catalyst Damage Bank No. 1
P1314 Misfire Catalyst Damage Bank No. 2
P1315 Misfire Excess Emissions
P1316 Misfire Rate Above Limit
P1335 Crankshaft Position Sensor Circuit
P1336 Camshaft Position Sensor (CMP) Circuit Performance
P1361 Ignition Coil Primary Circuit (Cylinder No. 1)
P1362 Ignition Coil Primary Circuit (Cylinder No. 2)
P1363 Ignition Coil Primary Circuit (Cylinder No. 3)
P1364 Ignition Coil Primary Circuit (Cylinder No. 4)
P1365 Ignition Coil Primary Circuit (Cylinder No. 5)
P1366 Ignition Coil Primary Circuit (Cylinder No. 6)
P1367 Ignition Monitor (Bank A)//Ignition System Failure Group 1
P1368 Ignition Monitor (Bank B)//Ignition System Failure Group 2
P1371 Early Activation Ignition Coil (Cylinder No. 1)
P1372 Early Activation Ignition Coil (Cylinder No. 2)
P1373 Early Activation Ignition Coil (Cylinder No. 3)
P1374 Early Activation Ignition Coil (Cylinder No. 4)
P1375 Early Activation Ignition Coil (Cylinder No. 5)
P1376 Early Activation Ignition Coil (Cylinder No. 6)
P1392 Variable Valve Timing Solenoid A Low Input
P1393 Variable Valve Timing Solenoid A High Input
P1396 Variable Valve Timing Solenoid B Malfunction
P1397 Variable Valve Timing Solenoid B Low Input
P1398 Variable Valve Timing Solenoid B High Input
P1400 EGR Valve Position Circuit (Valve Sticking Open or Short)
P1401 EGR Valve Position Circuit (Open Short to Ground)
P1408 EGR Temperature Sensor Circuit
P1409 EGR Valve Circuit
P1440 EVAP Purge Valve Open
P1441 EVAP Valve Circuit
P1443 EVAP Valve Circuit
P1447 EVAP Valve Circuit
P1448 EVAP Valve Circuit
P1454 EVAP System
P1474 Charge Air Coolant Pump Relay
P1475 Radiator Fans Slow Malfunction
P1476 Radiator Fans Fast Parallel Circuit Malfunction
P1506 Idle Speed Control Circuit (Low RPM; Bank B)
P1507 Idle Speed Control Circuit (High RPM; Bank B)
P1508 Idle Speed Control Circuit
P1509 Idle Speed Control Circuit
P1512 Throttle Position Sensor Idle Switch Sense Circuit
P1513 Throttle Position Sensor Idle Switch Sense Circuit
P1514 Park/Neutral Position Switch High Load Neutral/Drive
P1516 Gear Change Park/Neutral Malfunction
P1517 Engine Cranking Park/Neutral Malfunction
P1607 MIL Output Circuit
P1608 Automatic Transmission
P1609 Internal ECM Error
P1641 Fuel Pump Relay No. 1
P1646 Fuel Pump Relay No. 2
P1739 Automatic Transmission
P1775 Transmission Control Module MIL Circuit
P1776 Torque Reduction Request Signal
P1777 Torque Reduction Circuit
P1780 Automatic Transmission
P1781 Automatic Transmission
P1782 Automatic Transmission
P1783 Automatic Transmission
P1785 Automatic Transmission
P1790 Automatic Transmission
P1791 Automatic Transmission
P1792 Automatic Transmission
P1794 Automatic Transmission
Mar 22, 2013 | Jaguar Cars & Trucks
1995 dodge ram 1500 318 motor it wont get fire where is the logic module located
Under hood,passenger side mounted on the firewall,but ...
Could be something else ,crank sensor or cam,or ign.rotor ect.
The module like 3 hundred bucks.Try this ,turn the key
on-off-on-off-on( without out hitting the starter) the check
engine light should begin to flash.
Here is a code list,may narrow down the problem.
Diagnostic Trouble Code Descriptions and service hints. Fault Code DRB Display Code Description. Service hints. 11 No Crank reference signal at PCM No Distributor reference signal detected during engine cranking. Check the circuit between the distributor and PCM. 12 Battery Disconnect Direct Battery input to PCM disconnected within last 50 ignition key-on cycles. Normal if battery has been disconnected, otherwise check battery power and ground connections. 13** No change in MAP from start to run No difference seen between the engine MAP reading and the barometric (atmospheric) pressure reading at startup. Indicates a problem with the MAP sensor vacuum system. 14** MAP sensor voltage too low or too high MAP sensor voltage output is outside the acceptable range. 15** No Vehicle speed sensor signal No signal received from the vehicle speed sensor during road load operation. 17* Engine is cold too long Engine temperature too high or too low while traveling. Check coolant level, radiator cap, temperature sensor, and thermostat. 21** O2S Stays at center O2S shorted to voltage O2 sensor does not detect rich or lean condition, or O2 sensor input voltage too high. DRB will indicate which side with dual sensors. The O2 sensor signal should fluctuate under normal conditions. 22** ECT sensor voltage too high or too low Engine Coolant temperature sensor input out of normal range. Check engine temperature sensor. 23** Intake air temp sensor voltage too high or low Intake air manifold temperature sensor is out of range. Check sensor. 24** Throttle position sensor voltage too high or low TPS sensor is out of normal range. 25** Idle air control motor circuits A short is detected in one or more of the idle air motor circuits. 27* Injector # control circuit Injector number # output driver circuit does not respond to the control signal. Check the affected circuit. 31** EVAP Solenoid Circuit Short or open in the EVAP solenoid circuit. Check for loose, broken, or shorted wire in the charcoal canister purge solenoid wiring and connectors. 32** EGR Solenoid circuit Short or open in the EGR solenoid circuit. Check for loose, broken, or shorted wire in the EGR valve wiring and connectors. Possible air fuel ratio imbalance not detected during diagnosis. 33* AC clutch relay circuit Short or open in the AC clutch circuit. 34* Speed control circuit or speed control switch always low or high An open or short in the speed control vacuum or vent circuits. Speed control switch input above or below normal range. 35 Radiator Fan low speed relay circuit Open or short in the radiator fan relay wiring. 37** Torque converter clutch solenoid CKT or Trans temp sensor too high or low Open or short in CKT wiring or connectors. Voltage out of range at transmission temperature sensor input. See NOTE #1 below 41** Generator field not switching properly Open or short in the generator (alternator) field control (regulator) circuit. This indicates a problem with the charging circuit and the fault is set when the battery voltage from the ASD relay falls below 11.75 volts. Wiring, connectors, fuses, and the ASD relay should be checked. A shorted battery cell can also trigger this fault. 42* Auto shutdown relay circuit Open or short in the ASD relay wiring or connectors. 43** Ignition coil circuit # Open or short in number # coil circuit. Indicates that the ignition coil's peak primary circuit current is not achieved with the maximum dwell time. 44* Battery temp sensor volts out of range An open or short in the engine coolant temperature sensor circuit or a problem in the PCM's battery temperature circuit. 45* Trans OD solenoid circuit Transmission OD solenoid circuit failure. Open or short in the transmission overdrive solenoid circuit. 46** Charging system voltage too high Battery voltage sense input above target charging voltage during engine operation. Computer is indicating that the battery voltage is not being regulated. 47** Charging system voltage too low Battery voltage sense input above target charging voltage during engine operation. Also, no significant change in battery voltage was detected during a test of the generator output. 51** System lean L-Idle Adap at rich limit or lean R-Idle Adap at rich limit O2 sensor signal indicates lean air/fuel ratio during engine operation. The computer ran the mixture to the rich limit of programming, but the O2 sensor still indicated a lean condition. L or R indicate left or right side O2 sensor. Fuel pressure problems can lean the mixture and set this fault. 52** System rich L-Idle Adap at lean limit or rich R-Idle Adap at lean limit O2 sensor signal indicates rich air/fuel ratio during engine operation. The computer ran the mixture to the lean limit of programming, but the O2 sensor still indicated a rich condition. L or R indicate left or right side O2 sensor. Faulty ignition components, high or low fuel pressure, or leaking injectors can set this fault. 53* Internal PCM failure or PCM SPI comm failure An internal PCM failure or PCM communications failure has been detected. 54* No cam sync signal at PCM No fuel sync (camshaft signal) detected during engine crank. No camshaft position sensor signal was received from the distributor. Problem with the distributor synchronization circuit. 55 N/A End of message code. A DTC 55 is used to end all DTC messages. This code does not show on the DRB tool and indicates a completion of the stored codes on the Malfunction Indicator Lamp (check engine lamp). 62* PCM failure SRI miles not stored Unsuccessful attempt to update Service Reminder Indicator miles in the PCM EEPROM (memory). 63* PCM Failure EEPROM write denied Unsuccessful attempt to write and EEPROM location by the PCM. Controller failure, check the PCM. This code can be set when attempting an unauthorized reprogram of the PCM. 71** Aux 5V signal voltage low The auxiliary 5 volt supply output voltage is low. The 5 volt output signal is not reaching the required voltage level. 72** Catalytic Converter efficiency failure The catalytic converter is not converting emissions in the proper ratio.
Feb 22, 2013 | Cars & Trucks
Inspiron 1501 inverter voltage
500 to 1800 volts, but low current. Depending on the make and model.
Feb 07, 2012 | Dell Inspiron 1501 Notebook
Where could I find a list of Fault Codes for my 3.3 Litre Voyager?
CHRYSLER OBDII DTC
P1101 HCM/PCM Communication Performance
P1103 Turbocharger Waste Gate Actuator Malfunction
P1104 Turbocharger Waste Gate Solenoid Malfunction
P1105 Fuel Pressure Solenoid Malfunction
P1195 Slow Switching O2 Sensor Bank One Sensor One During catalyst monitoring
P1196 Slow Switching O2 Sensor Bank two Sensor one During catalyst monitoring
P1197 Slow Switching O2 Sensor Bank One Sensor two During catalyst monitoring
P1198 Radiator Temperature Sensor Input voltage too high
P1199 Radiator Temperature Sensor Input voltage too low
P1281 Engine is cold too long
P1282 Fuel Pump Relay control circuit
P1283 Idle select signal invalid
P1284 Fuel Injection pump battery voltage sensor out of range
P1285 Fuel Injection pump controller always on
P1286 Accelerator Position Sensor (APPS) supply voltage too high
P1287 Fuel Injection pump Controller Supply voltage low
P1288 Intake manifold short runner tuning valve solenoid circuit
P1289 Manifold tune valve solenoid circuit
P1290 CNG Fuel system pressure too high
P1291 No Temp rise seen from intake heaters
P1292 CNG Pressure sensor voltage too high
P1293 CNG Pressure sensor voltage too low
P1294 Target idle not reached
P1295 No 5 volts to TP sensor
P1296 No 5 volts to MAP sensor
P1297 No change in MAP sensor from start to run
P1298 lean operation at wide open throttle
P1299 Vacuum Leak detected (IAC fully seated)
P1300 Ignition timing adjustment circuit failure
P1388 Auto shutdown relay control circuit
P1389 No ASD relay output voltage at PCM
P1390 Timing belt skipped one tooth or more
P1391 Intermittent loss of CMP or CKP
P1398 Mis-Fire Adaptive Numerator at Limit (PCM is unable to learn the crank sensors signal
for use in preparation for misfire diagnostics
P1399 Wait to start lamp circuit
P1403 No 5 volt feed to EGR
P1475 Auxiliary 5 volt supply is too high
P1476 Too little secondary air
P1477 Too much secondary air
P1478 Battery Temp Sensor Volts out of limit
P1479 Transmission Fan Relay Circuit
P1480 PCV Solenoid Circuit
P1481 EATX (Electronic Automatic Transaxle) RPM pulse generator performance
P1482 Catalyst Temperature Sensor Circuit shorted low
P1483 Catalyst Temperature Sensor Circuit shorted high
P1484 Catalytic Converter overheat detected
P1485 Air injection solenoid circuit
P1486 EVAP Leak Monitor found a pinched hose
P1487 Hi Speed Fan #2 Circuit
P1488 Auxiliary 5 volt supply output is too low
P1489 High speed fan control relay circuit
P1490 Low speed fan control relay circuit
P1491 Radiator fan relay control circuit
P1492 Ambient/ Battery Temp sensor input voltage too high
P1493 Ambient/ Battery Temp sensor input voltage too low
P1494 Leak detection pump pressure switch or mechanical fault
P1495 Leak detection pump solenoid circuit
P1496 5 volt supply, output too low
P1498 High speed radiator fan ground control relay circuit
P1500 General alternator 'FR' Terminal circuit fault
P1594 Charging system voltage too high
P1595 Speed control solenoid circuits
P1596 Speed control switch always high
P1597 Speed control switch always low
P1598 A/C pressure sensor input voltage too high
P1599 A/C pressure sensor input voltage too low
P1680 Clutch released switch circuit
P1681 No I/P Cluster CCD/ J1850 messages received
P1682 Charging system voltage too low
P1683 Speed control servo power control circuit
P1684 The battery has been disconnected within the last 50 starts
P1685 The SKIM (Smart Key Immobilizer Module) has received an invalid key
P1686 No SKIM (Smart Key Immobilizer Module) bus message received
P1687 No Mechanical Instrument cluster bus message
P1688 Internal Fuel injection pump controller failure
P1689 No communication between the ECM and injection pump module
P1690 Fuel injection pump CKP sensor does not agree with the ECM CKP sensor
P1691 Fuel injection pump controller calibration error
P1692 Fault in companion Engine control module
P1693 A companion DTC was set in both the ECM and PCM
P1694 No CCD message from PCM- Aisin transmission
P1695 No CCD message from body control module
P1696 PCM failure EEPROM write denied
P1697 PCM Failure SRI (Service Reminder Indicator) mileage not stored
P1698 No CCD message from TCM
P1719 Skip shift solenoid circuit
P1740 TCC solenoid or overdrive solenoid performance
P1756 Governor pressure not equal to target at 15-20 psi
P1757 Governor pressure is above 3 PSI when 0 PSI is requested
P1762 Governor pressure sensor offset improper voltage
P1763 Governor pressure sensor voltage to high
P1764 Governor pressure sensor voltage to low
P1765 Transmission 12 volt supply relay control circuit
Oct 03, 2010 | 1998 Plymouth Voyager
My screen comes up black, but when i hook up another monitor, it displays normally. Is my screen bad?
Try attaching an external monitor to the laptop & see if you could get any display on it. If this is successful, then you might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp
Sep 16, 2010 | Dell Inspiron B130 Notebook
I have a Dell inspiron 1721. The screen is dim ... when I try to adjust the brightness it won't adjust any brighter than it already is and makes some type of humming noise at the settings in the middle. ...
Sep 06, 2010 | Dell Inspiron 1721 Notebook
I have a Dell Inspiron Mini. When i turn it on the desktop wont show. All i get is a black screen.
This might be a sign of a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
Test with an external monitor attached to the laptop. If you get display on the external monitor, then this confirms the case.
Aug 22, 2010 | Dell Inspiron Mini 10 Notebook
Frecquent shut downs on both computer s with vista home premium
check your ac power voltage input maybe low. chek the cpu fan. scan all your pc virus causing pc to reboot by it self.
Jun 03, 2009 | Dell Inspiron 530 Desktop Computer
2500 dell inspiron fails to boot when new fan comes on
You are drawing too much current from the power supply with the current hungry fan.Try using a different fan that draws less power on start up. Or use a limiter to lower the input voltage draw on start up. These are usually found in fan speed controls You could also use a voltage dropping adaptor like the one use to quite fans down . They drop the 12 volt voltage to 7 volts by connecting the two voltages usually found on the power connector 12v and 5v and and adding them together getting a 7 volt output. You can also try connecting the fan directly to the power supply and avoid using the motherboard connector.The problem with this is you will not get use of the speed controling sensors used in the motherboard connections. Hope this helps you with your problem.
Apr 29, 2009 | Dell (6F858) Cooling Fan
Dell Inspiron 530 Desktop Computer   Logo
116 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
