Question about Goodman GMS90703BXA Heater
When my Goodman Gun125-5b furnace fires up the draft inducer whines.Is there a fix or does it need replaced? How hard is it to replace it?
  • Anonymous Mar 31, 2014
    I need to replace the inducer motor but I can not find the manual. Can I get a replacement manual or at least the instructions regarding replacing the inducer motor?
  • 1,420 Answers
Try and spray some mystery oil on the shaft. It may help. If not, you will be needing a replacement inducer.
Posted on Feb 18, 2009
Need to find a replacement part
Here you go Angela
1149097 Draft Inducer Assembly - AllParts Heating
www.allpartsheating.com/1149097.html
  1. Cached
  2. Similar
Draft Inducer. 1149097 draft inducer for Heil, Tempstar, Arcoaire, Whirlpool & Comfortmaker brand model furnaces. This part replaces old part number 1008416.
Arcoaire Furnace Motor Parts: Fast Shipping RepairClinic.com
www.repairclinic.com/Shop-For-Parts/a36b389c53/Arcoaire-Furnace-Motor-Parts
  1. Cached
  2. Similar
Furnace draft inducer assembly. The draft inducer motor draws air into the burner and exhausts it out the flue. If the draft inducer motor is defective, the furnace ...
Arcoaire Furnace Parts: Fast Shipping RepairClinic.com
https://www.repairclinic.com/Shop-For-Parts/a36b389/Arcoaire-Furnace-Parts
  1. Cached
Direct Factory Replacement Inducer Blower Motor Used in 90 ...
www.americanhvacparts.com > ... > Oem Direct Replacement Models > Arco Aire
  1. Cached
  2. Similar
Direct Factory Replacement Inducer Blower Motor Used in 90% Furnaces. ... Comfortmaker, Intercity Products Snyder-General, Heil, Tempstar, Arcoaire Draft Inducer Blower Motor. ... Used in ICP Equipment Models: ... GUH125A016CIN
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor ...
https://www.amazon.com/1149097-Arcoaire-Furnace-Inducer.../dp/B00FFBQRGA
  1. Cached
1149097 - Arcoaire Furnace Draft Inducer / Exhaust Vent Venter Motor - Fasco Replacement: Replacement Household Furnace Motors: Amazon.com: Industrial ... Draft inducer motor for arcoaire model guh125a016cin Google Search
Nov 27, 2016 | Heating & Cooling
Furnace won't start after replacing filter
check for disconnected wires . There may be a sensor in or near the unit you touched that is causing the problem
Feb 18, 2013 | Goodman Furnace Draft Inducer Blower ...
1999 goodman furnace draft inducer working 50% of the time
All the symptoms point to a stack blower that needs replacement
Feb 09, 2013 | Heating & Cooling
I have a goodman model#GMH80703ANAA SERIAL#0607148632 -I HAVE NO MANUAL AND WAS WONDERING WHAT THE LOW FIRE ON GAS VALVE IWC SUPPOST TO BE SET AT. AND WHAT THE HIGH FIRE IWC PRESSURE SHOULD BE SET TO.I do...
I have done this 34 years and never need to know this . simply replace the $15 part to see if it works, labors not cheap and its better value to the customer for you to sawp it out on a call even if its not bad yet as they are 1 of the weak links that you know will fail . if it doesnt work, which i never saw except when the orifice on the induced draft housing was carboned up! or 1 time the induced draft squirrel cage was disintegrated with the motors shaft left spinning nothing and doing nothing as toinducing any draft! threw mw as the motor was working! and orifice clear and new switch but still not working!!! had to be the cage or poltergeist lol!
Feb 24, 2012 | Goodman Heating & Cooling
I replaced the ignitor on my goodman furnace, but it still isn't turning red and the fire still doesn't come on. what is the problem?
Is your induced draft motor coming on first and if so have you checked the voltage to ignitor when it's calling for heat. If you are not getting voltage to ignitor then you probably need to replace the control board. Thank you.
Dec 30, 2010 | Heating & Cooling
It seems the bearings on my Induced Draft Blower Motor are going out. The furnace runs for a bit then I can hear the motor seizing. It has been making whining noise for awhile but has gotten...
While you may be able to get just a motor it will not save you much. You will also run the risk of damage to the housing or fan(s) when you take the old one apart and try to install a new motor. Unless the new blower unit is several hundred dollars I would recommend you replace the whole assembly.
John
Dec 02, 2010 | Goodman B1859005 Induced Draft Blower...
What is the model number for the Draft Inducer Motor Goodman GNP075-2REVB Furnace
I think you must mean GMP075-2rev8 check this link for parts listing:
http://site.famousparts.com/goodman/PDF/RP-169C.pdf
Johnstone supply which has many locations in many cities sells Goodman and stocks parts, and available mailorder http://www.johnstonesupply.com/corp/Default.aspx
Feb 18, 2010 | Goodman Furnace Draft Inducer Blower ...
Need help with a goodman gmt070 furnace...error code flashes three times, i have replaced pressure switch, still flashed, replaced board, still flashes three times...flue is clear, draft inducer motor is...
it may be clogged at the barbed fitting on the induced draft motor where the pressuer switch tubing connects. take a paper clip and **** it out make sure you can stick it thru freely till you can feel the Inducer wheel then reconnect and try again.
Nov 04, 2009 | Heating & Cooling
Goodman GMS90703BXA Heater Logo
271 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
