Question about Dryers
I can hear the timer run but the push button switch will not start the dryer
  • Anonymous Feb 18, 2009
    This is the model number from inside the door
    Kenmore Dryer
    Type 122-00
    Serial # MH2734541
    Model/Stock # 110. 66512694 66512
  • 188 Answers
Check your home's fuse panel or reset the breaker (even if it looks like it's not tripped).
Check the door switch and make sure there is a click when you press it. If your model has a light inside, make sure it turns off when you press the door switch.
Check the belt to make sure it's not broken. Either turn the drum by hand from the inside, you should feel resistance from the motor or lift the cabinet top by removing the 2 screws under the lint trap (in the lint trap is on top) and pry the top forward and up.
If these don't work, can you provide the model number. I may be able to help you better.
Posted on Feb 18, 2009
  • willie4u Dec 28, 2010
    serial no. MH1901230
    type no. 122-00
    model no. 8840293
Does any one know what the resistance reading should be for the start button on a Kenmore elite dryer.
look for the safety switch at the Door. Dryer wont run if it thinks the door is open
May 25, 2015 | Kenmore Dryers
Dryer start button doesn't work
door switch or possibly the motor. if you hold the door switch in and push the start button have someone turn the drum by hand if it starts running it is the motor
Jul 04, 2010 | Frigidaire FEX831CS Top Load Stacked...
Whirlpool dryer will not start, used to start if I turned timer
whirlpool electric dryer will not start when you push start button. Model No. LER5634AW0. There is power to the dryer. The door switch appears to be working,(didn't check it with a meter). I push the start button, run it through all the cycles and still nothing. Are there any resets or circuit breakers that I could check? Where do I go from here?
Mar 06, 2010 | Dryers
The dryer will not start, you can hear timer.
your problem could be : Door switch, Motor, Thermal Fuse, Timer.
I would start with Door switch and Thermal Fuse.
Jan 07, 2010 | Dryers
My 1987 GE Dryer, Model # DDE5300GALWH,will not run all the time.
sounds like you need a new timer you can actually take the timer apart to check for a burnt connection
Jan 07, 2010 | GE Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
My whirlpool dryer wont start.
check the door switch and also the push to start button. Timers will advance even if the unit is not on
Mar 30, 2009 | Dryers
Dryer will not run
ck thermal fuse located on blower housing at rear should be white object with 2 blue wires ..if cks ok ck door switch
Sep 26, 2008 | Kenmore 63012 Electric Dryer
Dryers Logo
Top Dryers Experts
