Question about LG CHOCOLATE VX8500 Cellular Phone
Can somebody explain what does warranty date code means in the LG VX8500 phone? I tried flashing it with a latest SW version and the warranty date code appeared 'Not set''. How can I bring it back?
5 Suggested Answers
  • 6 Answers
SOURCE: I FORGOT MY CODE TO UNLOCK MY PHONE
Dial *4357*4357 and then that should give you the phone number and then just use the last 4 digits to unlock it
Posted on May 27, 2008
  • 16 Answers
SOURCE: Updateing My Lg VX3500
You should be able to take it to your wireless provider's nearest store and have them "flash" the phone to update the software. Bear in mind that in most cases, updating software versions results in complete removal of all personal data/phone settings, so make sure to back up anything you don't want to lose.
Posted on Dec 15, 2008
  • 221 Answers
SOURCE: Unlock Codes for LG VX8500
in general you cannot unlock a CDMA phone.
if you are talking about the KG800, then you can go to a site such as gsmliberty.com and get an unlock code there
Posted on Jan 05, 2009
SOURCE: i have reset my lg kf700, afterthat only picture is visible
hi
I have an LG KF700 and when I turn on my lg is the written and does nothing
how can I do?
thanks
Posted on Apr 04, 2010
SOURCE: how to upgrade the lg
how can i upgrade my lg cookie pep
Posted on Jan 22, 2011
I CANT FIGURE OUT THE CODE
What Code You cannot able to Figure Out....If you need Unlock Code means..Don't search anywhere,You can get the Unlock code at reliable cost and Unlock the mobile......
You can get the LG CHOCOLATE VX8500 Model Unlock code here
http://www.mobileunlocksolutions.com/lg-vx8500-chocolate/rs1wp9/
Nov 10, 2010 | LG CHOCOLATE VX8500 Cellular Phone
Tip
All codes Secrets for LG Cell phone
<span> <span>LG all models test mode: Type 2945#*# on the main screen.<br />2945*#01*# Secret menu for LG<br />IMEI (ALL): *#06#<br />IMEI and SW (LG 510): *#07#<br />Software version (LG B1200): *8375#<br />Recount cheksum (LG B1200): *6861#<br />Factory test (B1200): #PWR 668<br />Simlock menu (LG B1200): 1945#*5101#<br />Simlock menu (LG 510W, 5200): 2945#*5101#<br />Simlock menu (LG 7020, 7010): 2945#*70001#<br />Simlock menu (LG 500, 600): 2947#*<br />LG-U81XX SPECIAL CODES</span> <span></span>Code to read phone version :<br /><span><span>- Phone without SIM<br />- Enter 277634#*# or 47328545454#<br />- Select 'SW Ver.info'<br /> Code to reset phone :- Phone without SIM<br />- Enter 277634#*# or 47328545454#<br />- Select 'Factory Reset'<br /> Code to enter UNLOCK MENU :- Phone wit SIM inside<br />- Enter 2945#*88110#<br />Test Menu 8330 : 637664#*#<br />Test Menu 8180 V10a: 49857465454#<br />Test Menu 8180 V11a: 492662464663#<br />Test Menu 8130-8138: 47328545454#<br />Test Menu 8110-8120: 277634#*#</span> <p><br /></span></span> <span><span><span><br /></span></span></span>
on Jan 11, 2011 | Cell Phones
LG VZ8500 UNLOCK CODE
It should be the last 4 numbers of your cell phone (unless somebody changed it). When your phone gets programmed, that's the default lock code.
or
try this
Feb 25, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Dec 12, 2008 | LG VX5300 Cellular Phone
LG Chocolate vx8500
you have to ask dang technical support
Apr 19, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Programing
Visit the following link select your country model etc..
http://www.lgservice.com/
Mar 09, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Flashed to cricket a lg vx8500 but the programing code 000000 dont work pls help n cricket didnt know how to do it either
you should reach a nearby mobile shop which is an autherised dealer of lg phones.they will tell u the code
Mar 02, 2008 | LG CHOCOLATE VX8500 Cellular Phone
Music
Sounds like he has the older version of software for the 8300
go to settings and tools , phone info ,SW version and see if your sw version ends with vo2, vo3 or vo4 .vo4 cripples some functions , v03 is the best in my opinion and vo2 is limited version also . unless it is vo3 take it to your verizon service center and talk to someone real nice and get then to flash it back or up to v03 , will take them about an hour to finish it.
you can also
Try pressing
OK
then the service code
0000000
then scroll to music setting click ok and see if the option to turn on mp3 playback is listed.
Dec 26, 2007 | LG VX8300 Cellular Phone
LG CHOCOLATE VX8500 Cellular Phone Logo
628 people viewed this question
Top LG Cell Phones Experts
IT Solution
IT Solution
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
