Question about Compaq Presario M2000 Notebook
Shutdowns automatically at random times... - Compaq Presario M2000 Notebook
  • 1 more comment
  • binulal Feb 19, 2009
    do u get a blue screen? if so did u change something recently like ram? same problem has been seen with many comps...mine too...soon probably your motherboard is going to die, happened to me too..
  • Roscoe2008 Feb 27, 2009
    I have the exact same problem with mine. No matter what i'm doing when it decides to shut off it shuts off!
  • Lee Hodgson
    Lee Hodgson May 11, 2010
    Hi there
    Does the PC shutdown properly of does it go into sleep mode?
  • 29 Answers
This could b an over heating issue. make sure u dont have ur laptop sitting on r couch or bed or anything soft that will block the fan and prevent cooling. also make sure ur fan is clean. gat a can of air and blow it out. u would b surprised how much dust gets in there. good luck!
Posted on Feb 27, 2009
Random shut down
Clean the cooling sistem and change the thermal paste
Feb 03, 2014 | HEWLETT-PACKARD HP Pavilion dm4-1165dx...
01 & 03 Bonneville randomly cuts off
check the automatic shutdown relay
Nov 17, 2013 | Cars & Trucks
Automatic shut down
http://www.tomsguide.com/answers/id-1900947/asus-laptop-shuts-randomly.html
Oct 23, 2017 | ASUS Computers & Internet
Bios 500
Shutdowns can be caused by many things. If you have your pc setup for automatic updates, some updates require a reboot and will do that automatically. Normally you can prevent that from happening by changing the settings from automatically updating to notify me first before updating.
The shutdown can also be caused by the cpu overheating. Your computer will automatically shut down to protect itself.
Shutdowns can also be created by a infected computer. Malware can cause this.
With out further details, such as what you were doing at the time of the shutdown it's difficult to say why your system is shutting down.
I can say that normally if its a update your system will shut down and reboot, not always, but usually.
Not a lot of help but additional information is really needed. What you are doing, brand of pc, if you have loaded new software or hardware, as much information as you can provide would help.
Sometimes, just goggling you problem on line with the make of the pc will help you find the answer you are having. Many times the problem you are having has already been addressed and a solution provided.
Aug 02, 2012 | HEWLETT-PACKARD Hewlett Packard COMPAQ...
I use hp nx9010, i want to re-install windows xp but any time i try, the machine shutdown. sometimes is able to move up to copping files sometimes not then shutdown; i don't understand why is only windows...
If you can't keep your laptop stable and on for longer period, and you're experiencing random shutdowns I'd say you're facing a motherboard problem. This failure is actually well known and hapens a lot with Toshiba and HP. You'll most probably need to repair the motherboard that suffers from the Maxim 1987 or Maxim 1532 power chip failure.
The repair process is fairly straightforward, but it isn't for the faint hearted. It requires a resolder of the tiny Maxim 1987 chip that should get your motherboard up and running again in no time. The other alternative is to go for a new motherboard, or just get a new laptop alltogether.
If however your laptop experiences random freezeups, and you notice that the DVD is slow at reading data, and especially if you experienced some random mouse and keyboard freezeups, then you'll need to repair the motherboard from a FSB chip failur, which causes these random freezeups, which is a bit easier to do but still a challenge.
Hope this helps
Jan 17, 2011 | Computers & Internet
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
My acer extensa 5620 laptop is not shutdown auto matically
if you want to shutdown your laptop automatically go to power option from control panel and from there you can schedule the time after using how many minute or hour you would like to automatically shutdown your laptop. Try it !! Good luck.
Aug 25, 2009 | Acer Extensa 5620-4020 Notebook PC
Shut down with no reason
It could be a overheating problem.Check the power supply.Or it could be a hardware problem may be the motherboard.I think you require a PC Tech to check the system completely.
Regards
Aug 08, 2009 | Computers & Internet
Random Shutdown Syndrome
The Random Shutdown Syndrome (RSS) is caused due to the heating of the heatsink.
When the heatsink warmed up it expends, and causes the system to trip. Apple replaced the defected parts and fixed the problem, i guess not for all macs...
Aug 11, 2008 | Apple MacBook Mac Notebook
Automatic shutdown
Probablemente esten comenzando a fallar los amplificadores de audio.
Mar 23, 2008 | Onkyo TX-SR604 Receiver
Compaq Presario M2000 Notebook Logo
139 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
