Question about HP Pavilion dv9000z Notebook
Laptop display issue
Actually, last two days the displayt is not continous, after ten minutes it goes off, but the machine in running condition. But now, it is boot there is a long beep but there is dim light and nothing in screen. I check with external monitor, there is full of vertical lines in external monitor. where did the problem else in motherboard or displaypanel. What is the solution.
  • 77 Answers
On this model laptop, it is not uncommon for the video chipset to die. When it does, it is very much in the fashion you have described.
Unfortunately the solution is to replace the motherboard, as this video chipset is integrated into the board, not a separate card. You will need to either contact HP... $800ish dollars for a board, or look on Ebay for a new board for your laptop.
Posted on Feb 18, 2009
Codes sy ce refrigerator display
Good Afternoon Johnny, thank you for your inquiry! Error code SY CE, commonly refers to a communication error at power up. Let's try resetting the refrigerator by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn on the unit. If resetting the power does not correct the issue, than the unit could possibly be experiencing a communication problem with the control board or a faulty user interface board. In this regard, I would recommend reaching out to an expert technician to ensure the appropriate replacement part is ordered.
Jul 27, 2013 | Frigidaire FGHB2844L (27.8 cu. ft.) French...
Display Collapse
it is repairable but for the cost of parts and labor you would be better of getting a new 22" LCD monitor
for the problem I would suspect the fly-back transformer or power supply
thanks for rating
Jan 09, 2008 | NEC MultiSync FE1250 22" CRT Monitor
What should I put in my hiking pack for a one day hike in the sun?
From my past experience I would suggest lots of water, snacks (trail mix or anything that will give you energy and doesn't spoil), sunscreen, a hat, and anything you might need in case something goes wrong and your day hike lasts longer than planned (even over night).
There is actually a list of "Ten Hiking Essestials" published by a mountaineering organization in the 1930s. The list has been updated since then, but you can find them both below. REI also has a great article that goes into detail on all the items on the list: The Ten Essentials
Updated Ten Essential "Systems"
  1. Navigation (map and compass)
  2. Sun protection (sunglasses and sunscreen)
  3. Insulation (extra clothing)
  4. Illumination (headlamp/flashlight)
  5. First-aid supplies
  6. Fire (waterproof matches/lighter/candles)
  7. Repair kit and tools
  8. Nutrition (extra food)
  9. Hydration (extra water)
  10. Emergency shelter
Classic Ten Essentials
  1. Map
  2. Compass
  3. Sunglasses and sunscreen
  4. Extra clothing
  5. Headlamp/flashlight
  6. First-aid supplies
  7. Firestarter
  8. Matches
  9. Knife
  10. Extra food
Jul 10, 2012 | Camping, Backpacking & Hiking
On my Cabrio, the washer goes through all of the cycles fine until it gets to the final spin. No matter the size of the load, I get a "ul" code. I can move the items in the washer around but it contines...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 29, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
Run cycle goes for 2 hrs or more
In the last ten years the machines have been using a water heat feature. The water will heat roughly 1 degree a minute so depending on the installation and temperature of the incoming water, a complete cycle can be 90 min to over 4 hours.
Eric
Jan 12, 2010 | Kenmore Dishwashers
Laptop will not start
It's possible the video card is burnt out from over heating.If it is you need a new motherboard.
Jun 01, 2009 | HP Compaq Presario F730US Notebook
Screen save stops displaying
If you go to Start Menu --> Control Panel --> Power Options --> then look the option that allows you to change the amount of time that the system turns off the monitor because of inactivity.
Apr 15, 2009 | Toshiba Satellite A215-S7422 Notebook
Viewsonic N3000w LCD TV randomly shuts off...
It seems that the power fails quite often with this one burning the Inverter boards transformers. OZ960G chip may not be broken, so try getting a new power from somewhere. Measure the transformers. suppose to be somewhat 5 ohms. tolerance is +-1.5 ohm. of more, replace.
Nov 21, 2007 | ViewSonic N3000W 30 in. HD-Ready LCD...
HP Pavilion dv9000z Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
