Question about Plantronics - Bluetooth Headset Plus Base & Headset
Plantronics 510 - blue light will not turn off, it stays a steady light. I have reset the headset, turned it off (at least the phone shows that it is not paired) and it seems to work just fine. how can I get the light to turn off?
Peter Denton
  • 16 Answers
SOURCE: plantronics voyager 510 headset
Make sure the headpiece is charged. Turn the headpiece off by pressing the little black button on top of the earpiece and holding for about 5 seconds. Turn the earpiece back on again the same way. You should have a slow flashing blue light on the mic boom. The base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
If this doesn't work you may need to manually pair the earpiece to the base by pressing and holding the Listen Volume Adjust + Button and headset Call Control Button on the earpiece until the light on the mic boom flashes red and blue repeatedly. As above, the base station will now try to find the earpiece and within about 20 seconds the red light on the base should be steady and blue light on top should be on.
Posted on Nov 05, 2008
randomgirl7
SOURCE: 925 Plantronics will not pair with cell phone.
To force start the pair press the + volume and the talk button in the middle simultaneously.
Finally found the solution after 20 minutes of searching, and I was about to tell my boss his bluetooth didnt work anymore
google <3
Posted on Jul 23, 2009
SOURCE: pair plantronics voyager 510 with mac book os x
1. Turn Bluetooth On in Macbook 2. Turn the headset On 3. Press the Up volume and the conversation On/Off key at the same time until the blinking blue lights blinking Blue and Red alternatively 4. In a couple of seconds the Mac will ask for the Authorization Key 5. The Auth key is "0000" (4 zeros) 5. Pairing should now be successful and you should be able to use the PLT510 headset with your Mac. I can
Posted on Oct 02, 2009
SOURCE: My Plantronics Voyager 510 will not go into pairing mode.
i actually got this to work with my iphone 3G S. i pressed the little black button then saw a blue light flash, and then i pressed and held the + volume button and the call control button until it started blinking blue and red and my iphone picked it up instantly. it did take a couple of times to get the headset to go into pairing though
Posted on Oct 19, 2009
  • 5 Answers
SOURCE: Motorola bluetooth H270 solid blue light after pairing
I had the same problem. I plugged a USB charger into the headset and turned the power switch off. It worked as normal after that. I think it does not like to be "on" when the USB is disconnected. Anyway it seems the plugging/unplugging kick-started it.
Posted on Feb 12, 2010
How do i connect my plantronics 510 voyager headset to my blackberry
Once you make your BlackBerry discoverable, then put the Plantronics Voyager 510 into pairing mode by holding the call control and volume up buttons at the same time until the headset flashes red and blue. Here is the link below for the 510 pairing instructions.
Plantronics Voyager 510 Pairing Instructions
Good luck from Headsets Direct!
Oct 19, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Tip
How to Pair or Connect the Plantronics 510 Bluetooth Headset to your Bluetooth...
1. Turn on Bluetooth within your phone - Consult phone instruction booklet
2. Put phone into pairing mode - Consult phone instruction booklet
3. Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
4. Select "Add new device" on your phone.
5. Select the Plantronics headset when prompted. Enter "0000" as passcode.
6. Your 510 headset will now have a continuous blue light blinking.
7. Choose "Yes" if your phones asks if you want to bond to the 510 bluetooth headset.
8. Your phone is now paired with the Plantronics 510 headset and ready for use.
on Jul 14, 2010 | Cell Phones
When trying to pair my plantronics voyager 50 to my iphone, i am attempting to get the blue and red light to flash by pushing the up volume and the call button. but no flashes occur, even after 60 seconds...
  1. Turn on Bluetooth within your phone. Put phone into pairing mode.Put headset into pairing mode - With headset on, press and hold call button and the volume up simultaneously until the headset begins to flash red and blue.
  2. Pick the headset for Plantronics when prompted. Enter "0000" (four zeros)
  3. you should now have a continuous blue light blinking.
  4. Choose "Yes" if your phones asks if you want to bond to the Voyager 510 bluetooth headset.
Good luck from Headsets Direct - 800-914-7996.
Aug 13, 2011 | Plantronics 510 Voyager Headset - PLN-510...
How do I put the unit in discover mode
Putting the Plantronics Voyager 510 into pairing mode:
With headset on, press and hold the call button and the volume up simultaneously until the headset begins to flash red and blue.
Select the Plantronics 510 headset in your phone when prompted and enter 0000 (4 zeros) as the PIN/passcode if prompted. When paired, the Voyager 510 headset should now have a continuous blinking blue light. Here is a link below for the step by step pairing instructions.
http://www.headsetsdirect.com/plantronics-voyager-510-bluetooth-pairing-instructions
Aug 12, 2011 | Plantronics 510 Voyager Headset - PLN-510...
Blue light blinks all the time its on
Plantronics 510 Voyager Headset - PLN-510 Headset - Light blinking blue.
Good! You'll be happy to know, this is normal.
The Status Indicator flashes blue when the headset is on. When the battery becomes low, the indicator will flash red.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!
Feb 06, 2010 | Plantronics 510 Voyager Headset - PLN-510...
How to set it up with new phone how do i set up discoverable mode
  1. Turn on both the phone and the headset
  2. To put the headset into pairing mode, at the same time press the Call Control button (side of the headset) AND the volume button marked "+". When the status indicator light flashes between blue and red, you are in pairing mode.
  3. Now use your phones menu to search for bluetooth devices, you should see it say "PLT 510" on the screen. Note, this can take up to 2 minutes.
  4. When it asks for the passkey, enter "0000" (zeros). When the light on the headset turns blue you are successful.
  5. If this fails, try again
  6. If this fails again...reset the headset. To reset, do a long press of the MUTE and volume down buttons simultaneously for about 3 seconds, then try the procedure again.
Oct 16, 2009 | Plantronics 510 Voyager Headset - PLN-510...
How to put my headset in pairing mode
Do not use the power button to sync.
To sync device, Press + button (volume) and Silver button (on boom) at simultaneously. LED Light will blink RED & BLUE. Device ID should appear on your screen.
sometimes it is tricky and you do have to turn on the power
so try it both ways and if the power is on hold the 2 buttons for about 30 seconds to 1 minute if the light stays blue turn off and try again they are not easy to sync the code for pairing if they ask you for 1 is 0000
Dec 03, 2008 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics voyager 510 headset
Nov 05, 2008 | Plantronics - Bluetooth Headset Plus Base...
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Dec 19, 2007 | Plantronics 510 Voyager Headset - PLN-510...
Plantronics - Bluetooth Headset Plus Base & Headset Logo
854 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
