Question about Canon PIXMA MP830 All-In-One InkJet Printer
Document in adf
A have a canon mp530 its give me a message document in adf so i cant use any more my machine
  • Canon Master
  • 419 Answers
It's indicating that the sensor in the top of the scanner has been triggered.
Try opening the document feeder tray on top of the printer lid and them gently open the grey cover that covers the scanner workings.
You will probably find some paper or something holding the sensor in the "document loaded" position
Posted on Feb 18, 2009
PIXMA MX330 Error message "Document in
The sensor may be dirty even if it looks like there is no paper jam. Take a bottle of compressed air and give it a once over. Make sure you don't shake or tip the compressed air as you don't want to fast freeze anything.
If this does nothing, you probably have a failed sensor which will need replacing.
Chris
Aug 18, 2011 | Canon Office Equipment & Supplies
Trying to fax, scan or copy and anytime I try the erro message Document in ADF press OK to discharge document
Hi sdrnjen977,
Here's what you can do to address the issue and clear error message: Document in ADF.
If you press the Stop button during scanning, Document in ADF. Redo operation after checking document in ADF and pressing OK. appears on the LCD. Press OK button so that the remaining document is automatically fed out.
Removing the jammed document from the Document Tray:
1. If printing is in progress, press the Stop button.
2. Turn off the machine.
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF, then open the Document Feeder Cover.
4. Raise the Paper Release Lever, then remove the jammed page from under the roller to the Document Feeder Cver side.
5. Pull out the jammed document from the ADF.
6. Press down the Paper Release Lever, close the Document Feeder Cover, then turn on the machine.
Removing the jammed document from the inner side of the Document Cover:
3. If a multi-page document is loaded, remove any pages other than the jammed page from the ADF.
4. Open the Document Output Slot.
5.Open the Document Cover.
6. Insert your hand into the Document Output Slot, then while pushing up the paper output rollers inside the Document Output Slot with your fingers, pull out the document from the inner side of the Document Cover.
7.Close the Document Cover.
8. Close the Document Output Slot, then turn on the machine.
Hope this helps.
Thank you for using FixYa.
Jun 30, 2011 | Canon PIXMA MX860 OFFICE AIO-2.5IN LCD...
My Canon MP530 indicates that I have a paper jam. There is no paper jam - I have checked and re-checked and turned it off and on several times and it is still reading that there is a paper jam. How do I...
Hello there You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Also clean The purge unit, called a spittoon assembly in an HP, Lexmark, Caonon and other inkjet printers, is where the print head assembly parks when not in use, also its other job is to clean and make sure the print head is clean and open for printing.
That is where you'll find the print head assembly parked on top of it.
It also has an electrical pump to milk the print heads and test for ink flow.
So clean all under where the heads are parked and on IP6600D models you can take out the heads just by clipping them out, and then clean well.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 25, 2010 | Canon PIXMA MP530 All-In-One InkJet...
I have a Canon Pixma MP780, keep getting "clear ADF" messages. changed the settings to off. Also, scanner is giving me some error messages #2, #178
Try Canon support. Type your query. Click "Search"
Example: Type "clear ADF" (You may have paper or some obstruction in the Auto Document Feeder).
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=238&modelid=10444#SupportDetailAct
Nov 30, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon MX330 - trying to use ADF. No doc inside on
Canon Pixma MX330, ADF error, Code : 2,103,0
Here's what I found. There were no stuck gears or pieces of plastic caught anywhere.
The ****** can still feed paper, except for (consistently) the last page -->error/stuck.
1) In order to CLEAR THE ERROR you need to do two things
a) & b):
a) Press OK, WITH THE HOOD OPEN, with a piece of paper loaded in the ADF, being careful to grab the paper manually as it comes out of the bottom of the hood.
b) Windex the strip of glass surface which sits under the ADF next to the platen. This needs to be done with attention to minute detail, and a bright LED flashlight; since ink smudges off of documents and collects on the glass with alarming frequency. The machine may think these smudges are caught/jammed paper.
2) In order to SCAN a stack of paper, add one blank sheet to the bottom of your document. This page will be the one that
fails to clear the ADF, generates an error, and must be manually cleared before the next job.
The rest of your pages will have already scanned.
Repeat Every Time You Use it
Sep 11, 2009 | Canon PIXMA MX310 All-In-One Printer
Documents will not feed from the ADF
Is there a more permanent fix in the meantime? I'm just tired of fiddling each time that I use the ADF
Jul 03, 2009 | Canon PIXMA MP530 All-In-One InkJet...
My CANON PIXMA MP530 is showing the alarm, "Document in ADF."
Open the top cover of the ADF and look for a rectangular hole with a lever stuck down. That lever should only go down when a paper is placed in the feeder, and sometimes they get stuck in the down position. A bent paper clip might help you lift it gently...
Jun 30, 2009 | Canon PIXMA MP530 All-In-One InkJet...
Canon PC 1061 ADF Error
Hello, you should open the ADF and try cleaning pick-up rollers + separation pad with alcohol ( some chemicals products works best but i can t remmember what kind of product it is ).
Regards, Mug
Oct 06, 2008 | Canon PC1061 Copier
Canon PIXMA MP830 All-In-One InkJet Printer Logo
345 people viewed this question
old marine
old marine
