Question about Panasonic KX-P1695 Matrix Printer
Panasonic kx-p1694 printer drivers for windows 2003
I hav installed panasonic kx-p1694 printer drivers for windows 2003.but, that drivers are for windows 2000.character set is not printing properly.
4 Suggested Answers
PABLOCSA
  • 1124 Answers
SOURCE: hp laserjet 3330 printer printing junk characters
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Posted on Nov 18, 2008
  • 53 Answers
SOURCE: Panasonic KX-P 1180 cannot print properly with win XP Pro SP2
when you loaded the driver did you select the correct port? many times I get calls where they hooked upto a certain plug in but chose the wrong port parallel needs the lpt1 port and if there are more then one listed it could be a higher number..lpt2...lpt3. goto the driver in printers and faxes and right click the chose properties then the ports tab and pick the port.
Posted on Jul 10, 2009
SOURCE: i lost my panasonic printer driver software
i lost my panasonic kx-mb772 driver cd
Posted on Mar 05, 2010
Can't find printer driver for panasonic kx-p1121 windows xp
HI.................... NEED Panasonic KX KX-P1121 Printer Drivers???
panasonic_091012_021220_128.png NOTICE: Panasonic's current KX KX-P1121 driver release resolves driver conflicts, improves your computer's stability and restores communication with all KX Printers. The newly released KX KX-P1121 drivers are a high priority update recommended for all Panasonic users.
Description Version Estimated Download Time KX KX-P1121 Driver
(Includes, WHQL certified drivers)
Current as of
(Sep 26 2011) 56K: ~9m
512K: < 1m download.pngDownload
Installation Instructions:
  1. Click above Download link or Click here to begin installer download.
  2. Click "Run" ("Save As") if using Firefox
  3. Click "Run" Again
  4. Follow on-screen prompts to complete installation.
Important: If you are using Firefox or Netscape as your browser, you will be directed to save the application "to disk" (we recommend that you save the application to your desktop).
We recommend that you save it to your desktop and initiate the free scan using the desktop icon. Should you choose not to save the application, you may simply initiate the free scan by clicking the "Run" button on the File Download Window.
You can also search for a specific driver below:
Locating updated drivers is easy! driver_manufacturer_123.png driver_select_4.png Download Drivers New Version Of Windows? No Problem!
Upgrade smoothly by finding the correct drivers for your KX KX-P1121 printer for Windows XP, Windows Vista or Windows 7. For the first time, users can upgrade with confidence knowing that their computer will run smoothly thanks to the latest drivers and updates required for a perfect upgrade.
Why Updating Drivers Is Important
Usually the only reason we look to install or update drivers is because something is malfunctioning. This is not the only reason you should keep your drivers up to date however. Panasonic is constantly tuning and improving performance of their KX KX-P1121 printers and the only way to make use of this is by having the latest drivers. Going online and checking for new drivers all the time can be frustrating and is not an effective use of your time, and a simple tool like the driver installer above can keep all of your hardware running on the optimal drivers with top performance.
Sometimes when new hardware is installed, although it works correctly, other hardware which interacts with it may not be, because the other hardware actually needs its own drivers updated. This kind of co-dependency is another common problem and a reason why it's a great idea to have a tool that is constantly monitoring the state of all of your drivers and updating appropriately so you can upgrade and add or remove components in your computer while continuing to run without a hitch.
When your KX printer is relatively new, it may be possible to download individual drivers directly from Panasonic without incurring additional charges. If you are having problems locating the correct drivers for your Printer printer, or are unsure of the exact model, we suggest you run a system KX scan first. It's very important you know the exact model of your Panasonic KX KX-P1121 printer you would like to update to ensure that it will function properly and to prevent possible damage to your system. Click here to download an installer that will automatically scan and identify your Panasonic to make sure you are installing the correct update and will also locate and download any additional driver and bios updates your pc may need.
recommended.png Install the latest KX driver updates now.
  • Automatically Updates Panasonic KX Printer drivers and all orther missing or out of date drivers using advanced scan technology.
  • Instant access to unlimited device drivers.
  • Starightfoward and intuitive interface
  • Better PC performance and improved stability
  • Access to the largest drivers database in the industry
  • Continous updates for the latest manufacturer drivers
  • Unlimited free technical supports with our 24x7 technicians
HERE IS THE LINK OF DOWNLOADED FILE.....................
http://xpdrivers.com/printer/panasonic/kx/kx-p1121/_5_5908.cfm
GOOD LUCK..................
Sep 26, 2011 | Office Equipment & Supplies
Hi, I'm trying to install a Panasonic Printer KX-MB771 but I have no disc, can you help please. Thanks Corinne
Hey Corinne, to install a printer on your computer all you need is the driver for your according printer, since you have lost the Installation disk you can always download these drivers from the internet. After you've downloaded the drivers plug in the printer into your computer and run the installation. Follow the instructions and you should be good to go.
Here is a link where you can download the drivers for KX-MB771 for all Windows Operating Systems: http://drivers.downloadatoz.com/8128,panasonic-kx-mb771-mb773-mb781-mb783-driver-multi-function-station-1-11-windows-9x-me-nt4-2000-xp%28x32-x64%29-vista%28x32-x64%29-english/downloading.html
Have fun :)
Aug 19, 2011 | Panasonic Office Equipment & Supplies
I want to download Panasonic Printer Model NO. KX-P1131 for windows 7
For your "Panasonic KX-P1131 Matrix Printer" just use the "EPSON LQ Series 1(80) INBOX Driver" for Win 7(X86 or X64) from your Win 7 CD. Select the LQ 850 Epson driver from add printer and & install the drivers and it will print just fine.
Reference link @
http://panasonic.net/pcc/products/printer/windows_compliance/windows_7.html
Hope it helps.
Jun 13, 2011 | Panasonic KX-P1131 Matrix Printer
Have just installed Windows 7 Ultimate and downloaded/installed the driver for Panasonic DP-C322. After successfully installing, I printed a test page that consisted of 100's of pages, some blank and...
The "test" output should have been one page.
If the printer properly interpreted the data-stream that it received, it _would_ have generated just that one page. However, if the printer is not "interpreting" the data-stream, but instead is printing it, character-for-character, then you could have gotten the mountain of output that you got.
Turn the printer off. Turn the printer on. Try again to print your own, small, "test" page.
May 05, 2011 | Panasonic WORKiO DP-C322 Printer
Panasonic kx-p1695 multi-mode printer (136 col)
I am having the panasonic printer,the model no.is kx-p1694 but the problem is the head of this printer is damage.I need new head of this printer .If u find the head of this printer then email me . My email id is vishalbhavna@yahoo.co.in
Nov 03, 2008 | Panasonic KX-P1695 Matrix Printer
Installation Driver not available
http://www.printer-drivers.com/companies/790.htm
have to look hard
Dec 08, 2007 | Panasonic KX-P3626 Matrix Printer
305 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
