Question about LG 24" Built-In Dishwasher - Black
LE on front panel of LG dishwasher after it quit wroking
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 113 Answers
Here is text of very helpful email from LG
When you receive the LE error code, unplug the machine for approximately 15 - 20
minutes. This will reset the microprocessor.
The LE error code can be an indication of several different issues.
The most common cause is over-sudsing in the machine. Many times owners
experiencing the LE error code are using regular detergent. It is recommended to
use a high efficiency or low sudsing detergent. Many of the leading detergent
manufacturers have a high-efficiency (HE) selection. The HE detergents are
designed for lower suds levels and enhanced cleaning performance in
front-loading washers.
Overloading the wash with too much laundry may also cause the LE error code. A
good rule is to load the washer until the clothes in the drum are no more than
three-fourths of the way up the window of the door. This will allow them
sufficient room for tumbling. The clothing having sufficient room to tumble is
more important than either the weight or the number of items in the washer. It
is the tumbling action that provides the washing effect.
Lastly, a breakdown in the signal between the microprocessor and the motor may
cause the error code. This can occur if there is a loose wire, dislodged ball
sensor, or if the shipping bolts are removed prior to situating the washer. . In
this case, a servicer would need to take a look at the unit. In this case, you
will need a service center to look at your unit. For service assistance, please
visit our website at us.lgservice.com Click on "Service Center". Enter your
zipcode and product type. Click search.
In the event that you cannot find a service center, please call 1-800-243-0000
for assistance. There, an agent will be able to provide you with an Authorized
LG Service Center in your area.
Please have your model and serial number available along with your zip code when
you call. If you have a customer service issue, please let the agent know and
they will set up a customer service file for you. If your unit is under the
factory warranty, your purchase receipt will validate the warranty.
Business hours are 24 hours a day, 7 days a week.
I have taken the liberty of providing some hints and additional information that
may be helpful concerning your LG washer.
If you must use a regular detergent, you will only need to use 1/2-1/3 the
amount you would normally use in a conventional top-loading machine. However,
the HE and the conventional detergents are different formulae, and your machine
will not perform as efficiently or effectively. Using half the required amount
of regular detergent will
give half the cleaning performance. As the new LG washers accept a larger than
usual load, the cleaning performance could be further reduced. In addition to
the reduced cleaning, there will be oversudsing. The excess suds will cause the
washer to stop and rid itself of the suds before continuing its cycle. Getting
rid of the detergent will further reduce cleaning performance.
Using too much detergent can cause a build-up on the outer drum over time, which
can result in mold and even mildew growth in your washer. Should this occur, do
a load of whites on the SANITARY cycle. Use the extra rinse and stain options.
Use NO detergent and use a liquid bleach. This will remove the build-up and any
odors accompanying it. This procedure may need to be repeated a couple of times
depending on the degree of build-up.
The washing time may vary by the amount of laundry, water pressure, water
temperature, and other using conditions.
The 'SenseClean Washing System' has a built-in turbidity sensor that measures
the detergent/suds residue in the water during the rinse and then makes an
adjustment of time and water usage based on the detected residue level.
The machine will detect an imbalance and attempt to correct it. If the imbalance
is detected or if the suds removing program operates, the wash time will be
increased.
A built-in water heater in the washer assures that incoming water is the correct
temperature to optimize cleaning performance. Most laundry detergents must be
activated at certain temperatures to work correctly. We use thermisters
(electronic thermostats that have a high degree of accuracy) to detect incoming
water temperatures. Our 1000-watt heater adjusts the incoming water to ensure
superior thermal action performance.
You won't see a "visible" water level in the window of the unit. The water is
pooled in the inner drum. RollerJets are built into the baffles of the washer.
The holes in the baffle collect water and re-circulate it during the wash. This
increases the mechanical action to achieve best cleaning performance. The
rollers gently move fabrics
along in the wash cycle.
This action aids in reducing the amount of water required for thorough
cleansing. In contrast with a top-loading machine, which always fills the
machine to a precise measured level of water, depending on the size of load you
select (small, medium, large), the LG machine will "sense" the size of the load
and only recirculate a minimal amount of water, thus making it very energy
efficient, efficient in the use of detergents, and extremely efficient in its
water usage.
Forced Water Circulation in the washer pumps water during the wash. It
recirculates it back up and over the laundry to further increase mechanical
action and cleaning performance.
With front loading washers, the door seals so very tightly unlike a conventional
machine, that it is recommended to dry the seal when you are done with your
laundry for the day to prevent an atmosphere where mold and mildew can grow.
To get the best results, sort clothes into loads that can be washed with the
same wash cycle. Different fabrics need to be washed in different ways. Always
sort dark colors from pale colors and whites. Wash separately as dye and lint
transfer can occur causing discoloration of white clothing. If possible, do not
wash heavily soiled items with lightly soiled ones.
Combine large and small items in a load. Load large items first. Large items
should not be more than half the total wash load. Do not wash single items. This
may cause an out-of-balance load. Add one or two similar items.
Hope This help
Good Luck!!!
neo
Posted on Feb 27, 2009
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Why is my dishwasher flashing LE
This is very common problem with LG dishwashers. The LE error code (locked engine) is not allways indicative of a motor problem.
Simply unscrew the front door panel from the retaining screws on the inside of the perimiter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thouroghly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape and you're back in buisiness!
Jul 08, 2010 | LG Dishwashers
MY LG DISHWASHER AND DRYER ARE DUDS
Hello,Sounds like a mechanical obstruction somewhere :->. Possible bad rollers or idler pulley. This could have snapped belt. Need to removed front door panel and lid to get at it. Open the door and rotate the inside drum by hand and see if it moves freely. If it does, you may rollers are probably good. Turn on power and listen for the motor turning on. If you hear a low hum then possible idler pulley or belt issue.LE error on DW - no quick fix here. I heard of wiring issues on the LG's, broken wires, that go from the control panel down to the motor/sensors/etc that result in this error code. I'm not up to speed on the LG dishwashers yet so maybe someone else can contribute.Rich
Apr 28, 2010 | LG DLE5955 Dryer
LE error message on the panel
Depending on the serial # of the dishwasher it may need a new wire harness and inner door liner.
LE is a motor circuit error.
Contact LG @ 1 800 243-0000 they may help you out.
Jan 15, 2010 | LG Washing Machines
LE error message
Well LE means locked motor, this seems to be a very common problem withe these dishwashers.
Anyway the LE error code is not all-ways indicative of a motor problem. There are also strong chances of any lose connection (wire), so first you can simply unscrew the front door panel from the retaining screws on the inside of the perimeter of the door. Once the screws are removed pull down and out to remove the door panel. Remove the sound insulating material and you will see several wires routed from the contol panel the length of the door to underneath the unit. Inspect the wires thoroughly. Near the bottom is where the pinching can take place. There are two gray wires and if you have been getting the "LE" error code, one of those wires is most likely broken or pinched. Splice, reconnect, solder or tape.......
Please follow the below link for more information (the link contain service manual, you can check the page number 25) -
http://136.166.4.200/contents/Dishwasher/LDS5811/LDS5811_Service_Manual.pdf
Good Luck!!
Dec 11, 2009 | LG Dishwashers
Repair code LE and bottom is flooded
I don't know if this thread will help, but you can have a look here: http://www.howtomendit.com/answers.php?id=28214
If not try the LG website which has support and fault codes to assist you.
Jun 18, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LE error
The first thing to check with an LE error on an LG LDFxxxx dishwasher is the drain hose. Start at the point where the drain hose connects to the drain pipe or garbage disposal. Make certain that the hose rises as high as it can. That will form a high point that will prevent the natural siphon effect from draining the water before it should.
Please report back here with what you find. OK?
Good Luck!
May 02, 2009 | LG 24 in. LDF7810 Built-in Dishwasher
LE code is on control panel
This is a motor issue. It will require service. LG = ****. We purchased all LG appliances for our new kitchen. The french door refrigerator has its ice maker go out twice. Our dishwasher also has had the LE code on it several times. The over-the-range microwave also clunked out.
Want some advise? Dump that LG ****. Give it to an enemy.
Oct 03, 2008 | LG 24" Built-In Dishwasher - Black
Model No- LD-12AW2 LE Error showing what does this mean
LE error code means that there is a problem with the motor.  One thing to check is to remove the front door panel and check the wiring harness to see if there are any broken wires.  If there is, repair the wire connections and see if the dishwasher returns to normal.  If not, then the motor assembly will need to be replaced.
Apr 20, 2008 | LG 24 in. LD-12BW5 Free-standing...
LG 24" Built-In Dishwasher - Black Logo
314 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
