Question about Canon imageCLASS D680 Laser Printer
Our Canon D860 Copier has an system error code E003, how can I fix this?
  • Anonymous Feb 21, 2009
    My Canon D860 Copier has an system error code E000 and Alarm light is on
  • 4 Answers
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Posted on Apr 24, 2009
How do i solve an error e000-0000 canon ir 2202 please
Dear
Its related to the fixing temp. do the error clear on service mode. then check the fixing film assy. heater circuit contact points for corrosion. Replace it.
Thanks.
Dec 12, 2014 | Canon Office Equipment & Supplies
System error E000
A E000 coeds means the error history has detected any one of the following error codes 4 times :E001;E002;E003.
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Please let me know if you need any further help
Apr 06, 2008 | Canon imageCLASS D860 All-In-One Laser...
Canon Image Class D860 - Error message E003. How do we correct?
Under service mode ( MENU and # ) find CLEAR, and select ERR ( if you cant find err, select ALL ), and OK.
Restart machine.
If that does not help change the whole fixing assy.
E003 means that you have temperature problems in fixing assy.
If clear does not help, that means that you have bad thermistor or fixing ceramics.
Jun 29, 2010 | Canon imageRUNNER 400S Copier
System error E000 cannon imageclass D860 copier will not operate even after turning the power off overnight
Here's the definitive reset. It will work on the following models: ImageRunner 1200/1300/1310,1330,1370,1630,1670, PC1060/1061/1080F, ImageClass D620/D660/D661/D680/D681/D880
Press #
Press Set
Press Set
Press <
i hope this will work if not then
if You are not out of warranty, this unit has a three year warranty.
The machine was introduced in September 2004.
best of luck
Oct 29, 2009 | Canon imageCLASS D860 All-In-One Laser...
CANON D860 copier display error message E0000
...usually the problem is in the fixing unit...
Jun 26, 2009 | Canon Office Equipment & Supplies
Canon Imageclas D860 Error Code E000 Have tried unplugging the unit and then restarting to no avail
E000
The error history indicates any of the following error codes 4 times: E001, E002, E003.
Action 1) Clear the error.
Execute '#4 PRINTER RESET" under '#7 PRINTER' in service mode to clear the
error.; then, turn back on the power.
Apr 14, 2009 | Canon imageCLASS D860 All-In-One Laser...
Canon Imageclass D860 - I have a System Error E000 code on the LDC display. No paper jam or other problems evident. Disconnected power for 10 minutes and that didn't help. For this error code I am to...
This is a reprint from another tech, he was right on with this...
okay lets shed some light on the E000 error code on the D680, D880, IR1300 family ( including the 1310,1330,1370,1630,1670)
The error code E00 is a memory threshold error what it means is your machine has logged 4 of the following errors, E001,E002, or E003. It is a lockout error and the machine cannot be used until the problem has been repaired or the errors cleared. First lets look at the errors:
E001 fuser over temp means the fixing assy has exceeded the manufactures maximum temp limits
E002 fuser temp dropout means the fixing assy has cooled below a set point during a copy session
E003 fuser no response means the fixing assy didn't even attempt to warm up at power on
How to fix, most common problem is bad power setting 4 E002's either brown outs of brief power failures.
To clear the error, Enter service mode by pressing additional functions then the # button, use the left or right arrow buttons to scroll to #7 printer press set. again use the arrow buttons to scroll to #4 printer reset press set. press the appropriate arrow key under the YES to clear the error. unplug the copier and reboot. At this time normal function should return if not and it resets a E00 the you can assume either the fixing assy is bad or either the power supply PCB or DC controller is bad and it is getting E001,E003 errors. At that point id call a qualified tech to research the problem to avoid spending money on excess parts
Hope that helps...
Lbcoaster
Aug 08, 2008 | Canon Office Equipment & Supplies
E003
problème d'installation d'une imprimante canon lbp 1000 laser son driver ne fonctinne pas
Feb 09, 2008 | Canon imageCLASS D860 All-In-One Laser...
Copier canon ir 1600
Problem with fixing Unit, simple simulation will help. otherwise need to change fixing unit,, contact ur service engineer
Nov 03, 2007 | Canon imageCLASS D860 All-In-One Laser...
Canon imageCLASS D680 Laser Printer Logo
1,095 people viewed this question
old marine
old marine
