Question about Maytag PYE2300AY Electric Dryer
Dryer takes a long time to warm up. It drys in 2 hours and does not shut off automatically. Maytag series 200
  • Maytag Master
  • 19,396 Answers
To make things properly, voltages to heating element should be tested, but that is a job that must be done by a technician.
Test first the heating fan. If it is not working replace the fan assembly.
Replace the heating element if that does not solve the problem replace the control board.
You can find schematics and diagrams by entering model number here.
Posted on Feb 18, 2009
My Maytag Bravos dryer is shutting off after running 10-20 minutes. Will not restart for an hour. Feels very warm
Have you considered calling a repairman .. sounds like you have a thermal overload malfunction .
Mar 16, 2016 | Maytag Dryers
Maytag ldg26cs gas commercial dryer never shuts off, runs normally and drys clothes but never stops or goes into cooldown mode.
Sounds like timer is stuck in one place and not counting down, can it be done manually? If so replace timer.
Dec 15, 2013 | Maytag MDG7600AW Gas Dryer
The dryer turns on, then drys for a few minutes,then shuts down
this is either a fuse ,relay or heater problem your best to call for a technician unless you can measure continuity between each of these with the power off .90 % of the time this is due to a build up of lint inside the dryer
Apr 28, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
The dryer takes three hours to dry a large load. It is almost one year old and it seems to take longer than it used to and the clothes don't actually get that hot anymore
is your dryer getting hot if so disconnect your dryer vent and run a normal load and if it drys that load in a normal ammount of time it is your vent pipe in the wall clogged
Mar 16, 2010 | Maytag Dryers
Maytag ensignia electric dryer makes alot if
I had a squirrel(?) stuck in mine! I removed the lint pipe and it was really nasty. Something had chewed through the screen and climbed down the pipe to stay warm?? We live in Minnesota and it was cold as heck. Anyway, Have a shop vac ready, I hope this helps. Remove pipe at the dryer, push start a couple of times and see if anything blows out. K.J.
Jan 21, 2010 | Maytag Dryers
Maytag Performa Electric dryer timer is bad
Look up an appliance parts store in your area. If there is no appliance store, try www.searspartsdirect.com.
If it does not turn off during timed dry then it for sure has gone bad. If it takes a while on timed dry then it is most likely that your thermal fuse/ valve coils are going bad.
Jan 14, 2010 | Dryers
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Maytag Quiet Series 200 Electric Dryer
I also had a similar problem with my maytag dryer which is 3 1/2 years old. It was the idler lever assembly with pulley. The part number is 11222607JG and the cost is about $20.00. Hope this helps.
Apr 04, 2009 | Maytag Dryers
Machine drys fine on timed cycles but shuts off before clothes are dry on automatic cycle.
First try cleaning the moisture sensors with rubbing alcohol, these are two silver colored strips located inside the drier just below the lint cleanout
Oct 31, 2008 | Whirlpool GEW9250 Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
89 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
