Question about LG LSC121PMA Split System Air Conditioner
I am looking for a wire diagram to make sure the wires are in the right place. i took the unit apart to clean it and forgot what colour wires went where.. the model is a LG LST244H-2 split system. please help i cant get it to work properly and need it with the hot weather for my kids..
  • luke bussenschutt May 11, 2010
    which wires did you remove, did they have numbers 1,2,3 written above them
  • Danny Clark
    Danny Clark May 11, 2010
    Which wires are you talking about?
  • 400 Answers
Open the indoor unit and write down which color is attached to what number, they should be wired exactly the same on the outdoor unit and visa versa.
Posted on Mar 12, 2009
I would like a wiring diagram for a Merc 190E right-hand front door window
Hi,if its that you have taken it apart and forgot how to put it back together,if so,take the opposit door card off and copy it.
have a good day.
Jan 04, 2015 | Mercedes-Benz 190-Class Cars & Trucks
I need help wiring my 1987 tlr200
start again and lay out the wire loom on the frame , follow each wire and offer up each part with wires and mate colour to colour wires , do the same for all other wires etc etc ! should run out of wires , the odd wire mite have a change of colour connection but not lots so if you get 80% correct then you should see where they go after a couple of tries ! make sure youve cleaned all earths on the frame also ! P...
Dec 27, 2013 | Yamaha Agusta F4 SPR Motorcycles
Im not sure how to wire the front buttons to the motherboard.
normally the wires black connectors are marked with white text like PWR SW and PWR LED and stuff and the colors of the wires normally correspondes to the color on the motherboard.....ill look it up and see what i can do for you!
Aug 13, 2009 | Intel Desktop Board D845GERG2 Motherboard
Have it taken apart to replace gaskets, forgot to take photos of where the wires reconnect, any idea where I can get a wiring diagram?
http://www.partsguru.com/user/Barista%2005.01.pdf
Try here, I took mine apart and now the press holder where the coffee goes is loose. Do you remember any other gasket other then the one the screen holds in place?
Jun 27, 2009 | Saeco RIO Vapore
Wire diagram for pull chain on ceiling fan hunter original
if you indeed have a 23852 hunter original...
Black goes to L, High is Red, Gray is medium and yellow is low. Make sure you have the right switch.
Mar 21, 2009 | Hunter 23852 Classic Original Ceiling Fan
Heater won't come on
its difficult to make a homeowner an expert in troubleshooting his/her equipment if he/she has no technical background - but - I will try. First check the cord to plug connection. Is it tight? Does it look melted? Next, take the unit apart where the cord goes into the unit. Check the wiring path. Look at each connection. Look for burnt off wires at connections. Most connectors are the push on type and are mechanically fastened to the wires. if they are burned off you'll need replacement spade terminals and a crimping tool. (radio shack) has these. one wire will go through a thermostat and out to an element terminal. one wire may go through a thermodisc overload, then to the thermostat and then to the element. the other wire will definitely go straight to the element. there may be some extra connections for lights etc. if you have to take apart the heater make a diagram of which wires go where. use some masking tape with numbers written on it to make sure the wires go back to the same place you took them off.
Nov 28, 2007 | Honeywell HZ519 Baseboard Heater
When i plug the heater in it does not work.
Nov 21, 2007 | Honeywell HZ614 QuickHeat Baseboard Heater
Heating & Cooling Logo
240 people viewed this question
Top LG Heating & Cooling Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
