Question about Thermador PSC486GLZS Gas Cooktop
Thermador Cooktop psc486glzs low burners not working
Technician came out three times says thta he needs 24 volt valves but Thermador does not make them anymore. Now they say that they can retrofit 110V valves to the unit? Is this correct and will it work?
  • 63 Answers
Hi my name is mark, i called thermador and the correct they have switched to 110v valves. thanks for your question.
Posted on Mar 13, 2009
Both extra low burners don't light
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
May 15, 2010 | Thermador Cooktops
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
The cooktop igniter wont stop firing even when turned off
one of your burner switches either got wet or shorted out. These switches are located on the burner valve itself. Sometimes you can take a hair dryer, pull the knobs of the control valve and dry out the switch. If this doesn't work, more than likley one of the switches gone bad.
Jan 13, 2010 | Cooktops
One burner on gas cooktop fires up but goes tick, tick tick.
There may well be water in the burner. It will evaporate in a day or two. Then it will work fine again.
please mark this answer as a fixya
Mar 18, 2009 | Thermador SGS36GS Gas Cooktop
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Electric coils for old Thermador cooktop Model #TMH45
I have a thermador 45 cooktop with all the parts. Do you want to by the whole unit for $50.00.
Jul 20, 2008 | Cooktops
Thermador 30" gas cooktop SGCS304RB
Do you hear gas? If so, take a needle and put it through each one of the small holes where the gas comes out.... Also look for a little "white-dust" where the sparker makes the spark. (located probaly at back of burner). If there is a white dust build-up scrape it off with something (needle) and give her another go...
Jan 21, 2008 | Thermador SGS36GS Gas Cooktop
Thermador Gas Cooktop Won't Stop Clicking : SGC304RS
theres a part in the cooktop called a spark modual. replace it. when i goes bad the problem your having is what it causes
Nov 29, 2007 | Cooktops
Thermador SGCS456R 36' gas cooktop
Take apart the cooktop and it is the potentior on the valve for the simmer burner that is usually the issue.
Aug 15, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Thermador PSC486GLZS Gas Cooktop Logo
300 people viewed this question
Top Thermador Cooktops Experts
Dan Webster
Dan Webster
Justin Duby
Justin Duby
tom wright
tom wright
Are you a Thermador Cooktop Expert? Answer questions, earn points and help others
