Question about Hitachi 53UDX10B 53" Rear Projection Television
Hitachi Television My Hitachi TV has rainbow like colours across the screen. Faces are blue further down the screen goes from red to green. Can anyone help or do I need a new TV.
  • vincegil39 Feb 24, 2009
    my mod# is 53FDX20B, this has happen befor and was fixed under warranty.it has done the same thing again ,not under warranty now!
    problem :its like you have doubles at the top of screen and colour is apparent ,ie see green ,blue some red
  • dfranzen70 May 11, 2010
    Is that the 110 or the 110/O? It's the latter that's $14 each, for a total of around $30. The former is only $6. Just want to make sure I'm getting the right one.
  • Hitachi Master
  • 3,459 Answers
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Solution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluiHitachi Television - 578ba6c.jpgbr />
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from
www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Apr 24, 2009
    Genius:
  • 1,550 Answers
You have convergence problem in your tv . You need to replace convergence IC . YOu can get from the link below .
http://www.electronix.com/catalog/default.php/cPath/6
You need to replace both convergence ICs .It will cost you around $30 .
The IC number is STK392-110 .
Posted on Feb 18, 2009
Where is the picture tube on my hitachi projection tv
If you have a Hitachi projection set there are three crt's red ,green and blue respectively . They are mounted three across behind the lenticular and fresnel screens.
Dec 20, 2009 | Hitachi 53FDX20B 53" Rear Projection...
I have a bush colour tv and there is a blue,green,red colour wash right across the picture so people''s faces look half blue,green red....sort of as if there is a rainbow across the screen.. i do not have...
It sounds like your TV may need degausing.
Is your TV situated near to any loudspeakers or other devices with large magnets inside them? Or has anyone been near your TV screen with a magnet???
You need to try to get the screen demagnetised (degaussed). Many TV engineers have a degausing coil that could do this. It only takes around 20 seconds at most.
Some TV's like Mitsubishi have a DG button on the remote, that does this function without the need to call out an engineer! It only needs one press of the button every few years!
Nov 17, 2009 | Televison & Video
Problem with a colour display on Hisense tv
If your picures are all purple it means that the green colour is missing. TV colour is made up by mixing Red, Green & Blue. Removing Green leaving Red & Blue makes purple. Study the green colour circuit for a fault and confirm that the green gun inside the tube is working.
Aug 31, 2009 | Hitachi 60SBX78B 60" Rear Projection...
Red, green and blue colours diveded on my TV
ok well "tube" tellys as they are called use an electro magnet to keep the picture stable and colours correct its called gaussing now if you have a speaker or something magnetic nearby it will stuff up the colors but only normally producing colors like purple,green, or white
if you have colors across the screen (that aren't caused by magnetic force) then you need to take it to a repairer or decide wether or not to buy a new one this issue can turn out to be quite hard to fix and can be expensive the different colored electron guns may be burning or burnt out causing pale color or it could be as simple as a power transistor in the H.V supply has shorted out..and causing power issues to the tube.
hope this helps,ben
Aug 13, 2009 | RCA 20F512T 20" TV
The screen has a rainbow of red blue and green on bottom
The specs say this is a CRT type projection system, so it could be related to the display or to the TV. Since this has an SD card, it might be good to plug in the memory card with some pictures on it, and see if the problem persists with a source other than the tuner. That might at least narrow down whether you have a display failure/adjustment issue or something else.
Jul 04, 2009 | Panasonic PT-56TWD63 56 in. Rear...
Red,green and blue lines across screen
I f these lines are slightly diagonal and they all showed up at the same time. you probaly have an open resistor in the ABL circuit. since your set is 13 yrs old, I would not put a penny into it.
You might take the front grill cover off and the panel behind it and find the little black box with 6 little controls 3 are for focus 3 are for screen turn the screen ones ever so slightly counter clock wise. the control in the middle is the green screen adjustment. If the green line goes away try the one labeled r for red and b for blue.
Mar 31, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
Sony KP-46WT500 Red, green and blue lines appearing on screen
your convergence IC;s are out, they cost about $40, if you know how to solder, you can do it your self, if not , I would try to find somone that can, service centers charge about 4 or 5 hundred, after you get the new ones, there easy to find on the board in the back of the tv
Nov 26, 2008 | Sony KP-46WT500 46" Rear Projection...
Green cruve line
Good Day;
Suspect Convergence IC's STK4274, part Number 2003191. Replace all three IK04(red), IK05(green), IK06(blue).
Good Luck, big IRISH.
Aug 30, 2008 | Hitachi 50UX26B/27K 50" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
199 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
