Question about Poulan Garden
I have a 36cc poulan chainsaw and it runs but not very good when u hold wide open or just a little it sounds like it surging
  • 2,176 Answers
I would go to Poulanpro.com with your model number and take a look at the manual for this tool and it gives you some troubleshooting hints on carb adjustments and other items to look for.
Posted on Feb 18, 2009
Where is Reid valve on 36cc Poulan chainsaw
I don't know but an intake reed valve is usually fitted directly to the intake port at the base of the cylinder barrel or crankcase and is revealed when the carburettor and any adaptor is removed.
Oct 27, 2016 | Poulan Garden
Poulan 40cc 18". Not starting. Muffler full of liquid (gas?). Very hard to pull with plug installed, easy with it removed. New plug, good spark.
You might have a hydraulic lock in the engine if you squirted too much fuel in the engine while trying to start it. take the plug out, hold the throttle wide open and pull starter rope 5-6 times to clear it. Put plug back in and try to start it.
Feb 21, 2015 | Poulan Garden
Poulan chain saw 2050 2.0CL
The Poulan Chainsaw 2050 is a 36cc model with a 14" bar and chain.
Sep 02, 2014 | Poulan Garden
I have a poulan 4218 it starts but has to be wide open to run there is no mid range or idle just wide open.
The carb might need adjusting the adjustment screws my be turned in to far witch is causing it to run wide open and not having slow idle or mid idle
Jan 22, 2013 | Garden
I just bought a new Poulan Model P3416 chaisaw (34cc) and I have followed the starting instructions and have not been able to start the saw. I have even varied the instructions but no luck. Any thoughts...
see if your switch is in run position and then pull your spark plug out see if it is wet, then see if it is sparking when you ground it and pull cord to roll over, if all is good hold throttle wide open and crank over without choke on, probably flooded, good luck
Aug 19, 2011 | Poulan P3416 16Inch 34cc 2Cycle Gas...
36cc poulan chainsaw carb settings
Poulan does not give the settings but they do give a toll free number to contact if you need help and that is 1-800-554-6723. Sorry I couldnt get more but that is all I saw
Feb 17, 2009 | Poulan Garden
Runs but not wide open
Clean the carb jets, that should cure the issue.
Nov 20, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
HOW TO INSTALL A NEW CHAIN ON POULAN 16'' BLACKHAWK CHAINSAW
hi likniz
unlock the lock nuts,take off the chain cover,change the chain,adjust the screw tightening chain,back the cover and the lock nuts.
best wishes savumihai71
Nov 16, 2008 | Garden
Garden Logo
632 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Dwain Pippen
Roland W VanLue
Roland W VanLue
Are you a Poulan Garden Expert? Answer questions, earn points and help others
