Question about Mitsubishi WS-55859 55" Rear Projection Television
Tv wont turn on
Hi! My ws-55859 55 inch mitsubishi hdtv wont turn on - the power light blinks and then turns off. How do I find the fuses to see if thats the problem? I too have the WS-55859 that apparently powers on (timer LED anyway- no display) and then shuts off. Would you please send me the how to file to: robertstex@hotmail.com.
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Your described problem indicates that the TV is in auto protect mode. Its built-in diagnostics detected a fault and prevents the unit from turning on. This is normally brought about by a power failure/fluctuation. Often culprits are capacitors that has leaked or blistered due to electrical surge.
This page describes the repair procedure. It has also links to step by step images. If I may add, it would be to your advantage to have access to a Service Manual or at the very least, a schematic diagram.
Good luck and thank you for using FixYa.
Posted on Feb 18, 2009
  • Mitsubishi Master
  • 19,396 Answers
To start unplug the tv from main for five minutes , and tell me how many times the led blinks.
    Genius:
  • 1,550 Answers
Try reset .
Unplug the unit from power chord for 30 minutes and plug back the power chord to the unit .
This will reset your unit .
The fuses are around the power supply board
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Turning off when trying to turn tv on..
If power light comes on for a few seconds and then goes off: On the front of the set press and HOLD both the menu and input (device) buttons at the same time for at least five seconds and then release both.
The power light should blink a two digit error code: 2 blinks, a pause and 2 blinks is the most common.
Tell me model number and what error code you find and I will tell you what it means and if possible what needs to be done.
This is a self check feature all WS model numbers had.
SD TECH
Apr 27, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
May 19, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Tv wont turn on
ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Mar 30, 2008 | Mitsubishi WS-55859 55" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
24 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
