Question about Hussmann Freezer 12 Facing Straight Glass Front Ice Cream Dipping Cabinet - With Rear Storage Doors
Bed room door locked
My son locked my bed room door and I cant open it...any sugestions
  • 979 Answers
Take a credit card and slide it around the door latch. Slightly pull on the door as your are doing this and it should release itself. Gently push the card and work it into the latch at a slight angle. Let me know if this works.
Posted on Feb 18, 2009
Kenmore upright freezer. About 15yrs old. For the last 5yrs we are have big build up of ice where the basket is we cant put anything in the basket, or it gets frozen in.model number is.C675-28732-1L
You mean it build up full of ice and no room for any thing...?
If so. Unplug it and let the door open for 24 hours then clean it up and plug back into power. You should be good for a while.
Good luck
Mai
Jul 20, 2017 | Kenmore Freezers
Hi, got a fridge freezer, the freezer door is not closing -please help
check if noting broke in the door locking mechanic. Or check if not too much ice is pressing the door open.
But if you don't hear the click, check the lock.
Feb 26, 2015 | Bosch Kge Series Fridge Freezer Door...
Viking professional defrost cycles
Check the rubber seal inside/around the door. I bet you have a tear or piece of seal that isn't making a solid fit and it's allowing (warm) room air into you freezer. This moist room air will either turn to water droplets and builds up to enough droplets to form puddles in the bottom of the freezer, or it freezes into a blob of ice around the door seal and this allows warm room air into the freezer. Otherwise you need an Appliance Tech to check the Freon refrigerant level. Most times its the door seal causing this problem.
Jun 08, 2014 | Frigidaire 14.1 cu. ft. Upright Freezer...
Kenmore freezer freezes up
By the movie you have an upright freezer. The worst type any body can own. Every time you open the door cold air flows out onto the floor and is replaced by room temp air that is heavy in humidity (water vapour). This freezes into ice and the more you open the door the more ice you will get. Also if the door gaskets(seals) are not perfect you will get the same result.
May 05, 2013 | Freezers
Son punched new samsung fridge door ,son gone, now I need a new door
Call the mfr. and see if they have one available. Then try looking for one on eBay. Next try to see if someone is trying to sell one .
Mar 06, 2013 | Samsung RF217ACPN - 20 cu. ft. French Door...
Exterior door presents condensation (a vertical line in the middle)
Normally when there is insufficient air flow in the room the freezer door will condensate and show wet spots.Have that often when testing a fridge in the workshop. Once the door is wide open, the wetness on the door goes away.
Dec 14, 2012 | Whirlpool 19.6 cu. ft. Upright Freezer...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Freezer very cold, no air going into fridge it warm ANY SUGESTION
hi there,
check the blower fan inside evaporator,there is fuse on the back side of your refrigerator for cooling fan,check on this using multi tester if busted replace fuse.
Jul 06, 2009 | Maytag 15 cu. ft. / 425 liter Upright...
Can't open bedroom door
Check to see if the wood or the lock is binding. Try this:
Leave door open and turn on heat. After a few hours, try to close door and see if it's catching on the frame. If it is, plane the door where it is binding. You can check for binding by using chalk on the door and after closing it, see where the scrub marks are.
If it's the lock, take out the striker plate and using a chisel, make the cut out deeper. Install the striker plate and test it again.
Oct 22, 2008 | Hussmann Freezer 12 Facing Straight Glass...
Freezers Logo
85 people viewed this question
Top Hussmann Freezers Experts
Dennis Boxerman
jasbo
jasbo
John Tripp
John Tripp
Are you a Hussmann Freezer Expert? Answer questions, earn points and help others
