Question about Ricoh Aficio 2022 Black and White Copier
Toner can be wiped off after copying - smudges
The copy looks OK when it comes off the machine but toner is not fixed and can be wiped off some areas.
Is this the toner?
  • steve843 Feb 18, 2009
    Is it easy to get at or is it a job for a service engineer?
  • E Eason Eason
    E Eason Eason Apr 01, 2013
    check if fuser unit problems ..
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; This problem caused by fuser roller and presure roller in heating unit, you have to take apart check it out, may be bushing broken.
Posted on Feb 18, 2009
  • Everett Lin Feb 19, 2009
    Hi sir; You better looking for technecian in your local area to take care of you.
Leaves black marks on copies
It could be leaking toner from the recovery area that sis on top of the dum, it removes any toner that was not transfered to the paper. You would have to remove it and empty out the toner.
Dec 11, 2012 | Toshiba e-Studio 232 Black and White...
Sharp Al1655cs copier black smudge down center of page about as wide as a pencil
Hi
Sounds like a fusing error . If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit).
Also clean the copier's paper rollers. Marks on copies will occasionally be the result of a dirty paper-rolling mechanism. Simply access these rollers (your photocopier will likely have a plaque or series of signs indicating the locations of these areas) and wipe them off.
Clean the copier bed's glass plate. One of the most common causes of blemishes in photocopies is a dirty glass plate. In some cases a permanent mark, such as a scratch, will be present on the plate, showing up in every copy as a dark line or spot. However, most problems attributed to the glass plate can be fixed by wiping the plate with a soft towel and common household glass cleaner.
Clear any excess toner that has spilled or overflowed in the toner cartridge chamber. Excess toner will almost always result in blemishes on your copies. The most effective means of cleanup is to remove the toner cartridge and set it aside, thoroughly cleaning up any spilled toner in the compartment before putting the cartridge back in place.
Check for low toner levels. Low toner levels can actually contribute to unsightly lines and blotches on a photocopy. Most photocopiers will automatically indicate the need to replace an empty or low toner cartridge; while the toner is low, these models will permit continued copying. Consult your photocopier's instruction manual or key to warning lights and indicators for how to tell if the toner is low or empty.
Aug 03, 2011 | Office Equipment & Supplies
Brother MFC8660dn, all copies are smudged, bought new toner and still doing this, what can I do to fix this
If they are smudged and the toner is set when the print comes out, there is something catching on the paper before the heated roller. If the toner smudges after the print comes out there is a fault with the heater and it is not setting the toner.
Jan 26, 2011 | Office Equipment & Supplies
After changing toner on my sharp, SF-2022 copy machine, the copies are coming out with black smudge marks across the paper? how/where should i clean?
This means the machine is over-toning ie using more toner than required caused by either improper toner or different brand of toner. The correct toner is sf 222T1. Replace developer and use the right toner and clean the drum and its blade. You may need to clean fuser rollers for cleaner copies.
Nov 13, 2009 | Sharp Office Equipment & Supplies
Dirty copies on Canon PC1060
First replace drum cartridge
Nov 04, 2009 | Canon PC1061 Copier
"shadow" copies
is the shadow off set from the original image?
if so it could be the cleaning unit for the fuser (heater) may have to be changed. If the cleaner does not clean the fuser rollers a residual image will be passed onto the page.
Apr 15, 2009 | Sharp AR-M237 Copier
Smudging when copy comes out
There are several reasons, all of which will require a technician.
Do you mean the toner will wipe of page (unfused)? This is the Fusing pressure roller.
Do you mean smudge marks that don't wipe off? This is most likely either a drum (photoconductor) problem, or the Upper fuser roller - could possibly be dirty optics as well. But like I say, only a technician can help you here.
Feb 25, 2009 | Canon NP 6050 Copier
Light and streaky copies, and a powder residue.
make sure that the machine is level first. then you will have to change both the drum unit and toner cart with new units not just change the drum in the drum unit.
Nov 25, 2008 | Sharp AL-1641CS Laser Digital Copier
Dirty Edges
I'm sorry to tell you, this is likely a drum issue.
You probably need to have a certified engineer examine the machine.
Have you tried speaking with the local service center to see if they have experienced similar issues? It might be free information.
Erik.
May 13, 2008 | Xerox WorkCentre XD120F Laser Printer
Black smudges on copies
Hi, try to pull out complete process unit(cartridge) with toner box .You have cleaner(blue or green color) move this cleaner from right to left side 4 or 5 times.Note that cleaner MUST be in home position-right side when you finish.Check print.
If problem still persists, you must do following:take away small grey plastic cap on left side of cartridge,then push complete charge corona(part with cleaner on top of it) to left side just enough to lift right side of corona from cartridge.Pull out that corona and you can see drum and developer roller. Turn the gear on drum,and look for smudges on black developer roller.Try to clean smudges with brush or with dry cloth.Toner will again attract to that area,but regular.
Dec 11, 2007 | Kyocera Mita KM-1815 All-In-One Laser...
Ricoh Aficio 2022 Black and White Copier Logo
138 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
