Question about Sony VAIO RA710G (VGCRA710GWITH17LCDDISPLAY) PC Desktop
1 Answer does.notwork.
  • skyhawk2235 Feb 21, 2009
    it is working fine now after the cleaning solution dried out.....thanks for all your suggestions.
    Problem Solver:
I have already posted the solution to my problem.....but i will tell you in more specifics what transpired.........after removing my spacebar.....i used electric pre-shave (an alcohol based solutions with a slight amount of lubrication).......with a few drops of that and a q-tip i cleaned the black tarry mass that had accumulated underneath the space bar most likely from spilled pop,coffee,pancake syrup,cat hairs,and only god knows what else...........after replacing it it worked fine mechanically and physically but did not work on the screen......after a day or two it started working .....i guess the alcohol needed to dry out .....i did put two drops down the tube that had a pad at the bottom (contacts underneath it ).........everything working better than new now .......thanks for being here to help.........
Posted on Feb 21, 2009
Is it possible to adjust the sensitivity of the keyboard? My spacebar doesn't work unless I press it uber-hard!
no there is not a sensitivity setting for the spacebars, however, some people have eaten or trimmed their fingernails and so on by their computers and in turn have gunk stuck up underneith the keys.
So check to make sure something has not landed up underneith it and clean it out if it has.
and make sure the keyboard is seated correctly. (if other keys dont work or don't work well this is a sign that the keyboard connectors are not seated correctly, but if all other keys work fine it is not a seating issiue and your cables are connected just fine.) If under warranty call the HP techs first!
Page 70 will get you to the techs maual on keyboard removal, cleaning and so on. a dry toothbrush and a vacume will go a long way though....
Apr 30, 2011 | HP Pavilion dv7-1130us laptop
You may have some small item underneath the spacebar. The spacebar will "pop up" if you use a screwdriver or something to pry it up from the keyboard. Insert it near the B on the top side of the spacebar and pry up towards you. Clean out from underneath and reattach it.
Apr 16, 2011 | HP D8597A Keyboard
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
How do I reseat the space bar on the mx 3200 . the logitech keyboard accummulates cat hair behind the keys, easily removed. But the space bar has a spring and white gunk and does not reseat easily. Mine...
Use a credit card or plastic Id, insert it and bend it gently. If it fails, you can use 2 cards, one on each side of the spacebar.
If after all you are unable to remove the spacebar, try removing the keys around it, just remember their distribution.
Beware, the spacebar is a little more complicated to put back in place compared to the other keys, as you said, there is a spring.
Sep 04, 2009 | Computers & Internet
Problemwith spacebar
If you take all those tiny screws out of the bottom of the keyboard you'll see a circuitboard with three copper "design" spots(usually 3) under the spacebar..........the ones NOT in the center of the spacebar are dirty. You could use some alcohol or acetone to clean the outside "designs".....(warning) Acetone will damage plastic!!!!!!!!
there are a lot of rubber caps that WILL fall out of place when you turn it over) (the actual keys could fall out too) (Be careful when you take off the bottom of the keyboard!!!!) Clean the ones that align with the SPACEBAR!!!! Dont touch or clean anything else that wasn't working....... Gently place the bottom back on and screw down the bottom cover with a cross pattern.....(left>>bottom).....If this dosn't work....the best part is that a new fairly cheap....mtg
Apr 14, 2009 | Computers & Internet
The pad has slipped.. open KB and reset.
Feb 18, 2009 | Sony VAIO RA710G...
Try to reseat the space bar again.
Spacebar-quit-working-after-cleaning-the-gunk-underneath-----now-it-does-not-work-at-all? it-is-a-vaio-keyboard-with-media-center-controls-at-the-top...........
Have you tried applying pressure gently until it snaps back in place? That could be the issue, is that the spacebar unsnapped itself when you were cleaning it. If you were using compressed air (canned air) then you may have blown something underneath it and it jammed itself in there. Trying turning the keyboard upside down and gently tapping it on a hard surface to see if anything else comes out.
Feb 18, 2009 | Logitech 967437-0403 Keyboard
411 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
