Question about Compaq Evo Notebook Keyboard N610C/N600c
Some one please help me. Some of my lenove laptop keys are not working for example left ctlr, left alt, g, h, F4, F5, upper errow key.
JUST U HAVE TO CHECK OUT YOUR SCROLL KEY LIGHT IS NOT ON.
CAPS LOCK , NUM LOCK ETC
ANDTT RY TO SWITCH OFF
Posted on Feb 18, 2009
My screen lights are at half strength. The F4 and F5 buttons do not work
Maybe you have to press and hold the FN function key at the lower left side of the keyboard, then hit F4 or F5. Most times just pressing F4 or F5 will not work.
May 15, 2012 | Computers & Internet
How do I check my screen lighting. It is at half strength and the F4 and F5 buttons dont work?
I have a pc HP Pavilion dv9000 what key do i use to play on t.v
Connect your Notebook with the TV and use Fn+F4 key combination to switch the signal output to TV.
Dec 19, 2011 | HP Computers & Internet
Hi i have the asus n53jg laptop. absolutly amazing laptop cant nock it i just have a little problem that i want to get sorted see the laptops function keys that run along the top have shortcuts on them...
The function keys that you have works alone and in combinations. You can press and hold Fn key then tap on any of those keys to get the short cuts. You can also press and hold Alt key and any of those to get another short cut. It actually depends on what you want to do.
For example:
Using single key:
F5 - it will refresh a window
F11 - try it in internet explorer to see the result
Using Combination:
Alt + F4 - it will close an open window
Fn + F3 - it will lock or disable your touchpad
I hope I understood your concern and helped. Goodluck
Jul 17, 2011 | ASUS Computers & Internet
I need instructions on how to use the hot keys and function buttons
F1
  • Almost always used as the help key, almost every program will open the help screen when this key is pressed.
  • Windows Key + F1 would open the Microsoft Windows help and support center.
  • Open the Task Pane.
F2
  • In Windows commonly used to rename a highlighted icon or file.
  • Alt + Ctrl + F2 opens a new document in Microsoft Word.
  • Ctrl + F2 displays the print preview window in Microsoft Word.
F3
  • Often opens a search feature for many programs including Microsoft Windows.
  • Shift + F3 will change the text in Microsoft Word from upper to lower case or a capital letter at the beginning of every word.
F4
  • Open find window.
  • Repeat the last action performed (Word 2000+)
  • Alt + F4 will close the program currently active in Microsoft Windows.
  • Ctrl + F4 will close the open window within the current active window in Microsoft Windows.
F5
  • In all modern Internet browsers pressing F5 will refresh or reload the page or document window.
  • Open the find, replace, and go to window in Microsoft Word.
  • Starts a slideshow in PowerPoint.
Jan 15, 2011 | Computers & Internet
The fn key seems to be stuck on in order to get regular results, example f5 refresh, I have to press fn-f5, otherwise I get the below results abcdefghijklmnopqrstuvwxyz normal esc ok f1 monitor options...
Boot To BIOS and ensure you reset factory Defaults.
If no change try this:
http://www.fixya.com/support/r4510515-when_try_type_ampersand_get_quotation
Oct 05, 2010 | Dell Inspiron 1501 Notebook
Advise uses of all F Keys.?.
F1
Open the Task Pane.
F2
F3
F4
Open find window.
F5
Sep 30, 2010 | Logitech EX110 Mouse
DVD video shows on laptop, but black on projector.
Assuming you are connected to the projector via the VGA port On the laptop, you will need to select the VGA output to work - there will be a picture of a screen on one of the F keys at the top of the keyboard, F4, F5 normally on laptops, but can be any of the F keys ----- (assuming F5 as an example ) use the FN key and the F5 key together it will then toggle between the following <laptop only><laptop and VGA output><VGA output only>
Mar 22, 2010 | IBM ThinkPad R52: R52 P M 760(2.0GHz),...
How do i turn off the lenovo n500 screen and use external only
There are a couple of possible key combinations (I don't own a Lenovo but all laptops are basically the same).
On my laptop, you have to press fn-F5. On some, it is fn-F4, alt-F4, alt-F5, or alt-F8. It is generally one of these, you'll have to experiment with them and see.
Also, take a look on your function keys - there may be one that shows a picture of two monitors. If you find this, that is the key (most likely F4 or F5).
Dec 19, 2009 | Computers & Internet
External monitor for amilo pro v2030
hi
when the external monitor is connected hold down the function key " f n " ( which is located 2nd on left of lowest row ) and then press either the F4 or F5 function keys on top line....the one that has a small icon like a rectangle or tv screen on it ....it has usually 3 toggle positions so if it dosent work first time then just press the same key again (still holding fn key) until it allows the monitor to get the signal.....if F4 dosent work then go thru the same sequence with F5 but depending on the laptop model it could be any one ...F3/F4/F5/F6 the usual suspects....
hope this helps
Jan 04, 2008 | Fujitsu Siemens AMILO Pro V2000 Notebook
Computers & Internet Logo
189 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
