Question about Compaq Presario 1800 Notebook
External microphone jack wont work
I am trying to get my microphone to work at the headphone / microphone jack..even tried to use hooked up to USB port with logitech pigtail connector and wouldnt work... sound is - ESS 1969 ,,, windows XP pro,,, compaq presario 1827 laptop
HAve you tried going into your mixer, by clicking on the sound icon at the bottom right of your screen, selecting microphone, and making sure its not on mute. it is on mute by default, you may also find a switch to apply more dB to the signal, you should try this and see if this corrects your problem
Posted on Feb 18, 2009
Front 4 usb ports and microphone and headphone jacks don't work but the rear usb and speaker jacks do work. I've had the computer new since 2009 and they have never worked.
it sounds to me like the wires from the front panel connectors are not connected to the motherboard inside the computer case, open the case up find the front connectors wires inside and find out if there are any connectors on the motherboard to plug them into.
the reason the rear ones work is because they are soldered directly to the motherboard.
good luck.
Jun 28, 2014 | Acer Aspire E380 ASE380-UD500A PC Desktop
I have intalled skype on my CF-52 Model . I can clearly hear the person i am callin, but the person i am calling can not here me. What drivers am I missing?
Most Panasonic ToughBook Models do NOT have a
built-in microphone. There is usually a microphone jack
located on the left side (The headphone jack is on the right).
On some PC's this is a "pink" connector. Headphone is green.
Simply purchase an external microphone even at a local
"Dollar" Store and it will work. You do not need to spend
$30-$40 on a fancy microphone, the cheap one works just as well.
Good Luck,
Richard, Montreal Based
Panasonic Toughbook Authorized Dealer since 1989
May 14, 2014 | Panasonic Toughbook 50 Notebook
Logitech mic 600 wont work computer dont even show its plugged in
Manually install it or if you have a disk with it load that and choose where its hooked up at or try another plug in if its usb capable. Your mic jack might be messed up also if it doesn't plug into your usb. Plug and Play usually picks up on whatever you plug in. If all else fails press F2 before boot and under the BOOT tab make sure its plug and play accessible Press F10 and continue with bootup and see if works
Mar 02, 2011 | Logitech (980240-0403) Microphone
Where is the sound in./out for hooking up external speakers
Look at the front and sides of the laptop for the headphone and microphone jack ports.
Some of them are coloured Pink for the microphone and green for headphone (audio out). some of them are also black.
Good luck.
Sep 30, 2009 | Dell Latitude D600 Notebook
TRYING TO HOOK UP HEADPHONES,IS IT CAPABLE.
Hello, IF your tv is capable of using headphones it will have a little jack with a head phone symbol over it or under it most likely. IF not you can buy a home theater system which would hook up to your tv and some of these have an option to hook up headphones or even ipods and usb devices.
the greek
May 31, 2009 | Sanyo DP19648 19 in. LCD TV
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
My external microphone jack and USB's doesn't work on Toshiba Satellite
hi, double click on the speaker icon on the bottom right corner, go to options, recording and select the microphone and adjust the level suitable.. thats it.. let me know
Feb 12, 2008 | Toshiba Satellite A135 Notebook
Headphone jack not working.
If you have a headphone jack at the front and the back, it may be a wire to the front panel is not connected properly on the Motherboard.
Aug 03, 2007 | RaidMax Samurai 908 Yellow Mid Tower ATX...
Jack for the external microphone
There is an error in the MobilePro 900 manual (Pages 2-2 and 2-3). The jack on the front of the MobilePro 900 is a stereo headphone jack only. The MobilePro 900 has a built in microphone. There is no jack for attaching an external microphone.
Sep 14, 2005 | NEC MobilePro 900 Handheld
Compaq Presario 1800 Notebook Logo
207 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
