Question about HP Wireless Optical Mouse
Cordless mouse? Hi my cordless mouse is not working the usb thing is currently staying blue but the actuall mouse is red nothing is flashing, do i need to get a new one please advise thanks Carol.
  • nieves4747 Apr 18, 2009
    tryed all usb ports the receiver will not light up and i press the both botton to connect on the mouse and the reciver what do u think is wrong ?
  • 152 Answers
Try pushing the connect button on the bottom of the mouse. Also check to see if there is a button on the reciever. If so, you should press that button first. Make sur there is no tab sticking out from the moust that needs to be removed. If this doesn't work, reply with the brand, and model of the mouse.
Posted on Mar 20, 2009
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
I have a Microsoft Wireless Notebook Optical Mouse 3000 which was working yesterday but is now not responding. The red LED on the bottom of the mouse is flashing, but the green LED on the USB receiver only...
you might have to uninstall the mouse then restart your computer then reinstall the mouse and its drivers
make sure the battery is good (has full charge)also you might test the usb device for the mouse is inserted correctly into the usb port (if applicable)
click start control panel mouse you should see 4 tabs buttons,pointers,pointer options and hardware under hardware you can troubleshoot also you can select properties under driver you will have options to update driver,rollback driver or uninstall and under hardware you can troubleshoot
in xp
hope this helps
Feb 01, 2011 | Microsoft Wireless Notebook Optical Mouse...
Hi, I have M-RAA93 logitech cordless optical mouse for Notebooks. But i dont have any CD to install, what to do? I have Toshiba Satellite L455 S5975, Windows 7 Thank you
Push the black button on the usb transever (part that plugs into the computer) .
Green light on transever will flash repeatedly.
Push and hold the button on the bottom of mouse (light gray, oval button on bottom of mouse) for five seconds, let go.
Light on the transceiver will flash a few times and then go out.
Win7 will notify (or not) that it is ready to use.
Use mouse norma-ly.
Note: Make sure gray slider switch is moved to the right and that you see a red light coming from the bottom of the mouse. If no red light replace batteries. Best not to use rechargeable batteries but if you do us the best Ni-Me (high ma 1000 or better).
Aug 25, 2010 | Logitech Cordless Mouse
Red light on mouse stays on and mouse will not work
Try moving the usb receivers plug in to another port.
Still not working..... might want to uninstall it and restart computer and then reinstall it.
Also check if the batteries are installed in the correct direction.
Mar 08, 2010 | Logitech Cordless Mouse
Mouse has stopped working. Batteries renewed -no
two thing with this mouse
1. Flashing red usually means its not connecting to the base
2. rare case the mouse has gone bad needs replacement
Aug 10, 2009 | Logitech Cordless Mouse
Blue light flashing on my wireless mouse but it will not work and does not recognize my laptop
is the wireless function on laptop on??the mouse is trying to communicate with laptop.
Apr 05, 2009 | Computers & Internet
Optical wireless mouse doesn't work
Hi
Check the battery...Replace the battery and then try
thank you
Dec 04, 2008 | Logitech Cordless Mouse
Buzz wireless buzzers
i tried several times to fix the problem by syncing the buzzers. it never solved the problem. finally i removed the dongle and blew on it very hard. i plugged it back in and retried. THIS ACTUALLY WORKED. i have played several times with no problem.
hope this is helpful.
Jul 11, 2008 | Sony Playstation 3 (PS3) Console
Wireless Mouse gets stuck
Take a eraser and use it to rub the contact points on your batteries clean. This seems to be the issue where your sensiativity will change by it self the the mouse has a 20 - 30 pause to reset it's self as if you just stuck a different battery in it.
Apr 16, 2007 | Logitech Inc G7 Cordless Laser Gaming...
HP Wireless Optical Mouse Logo
310 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
