Question about Canon Pixma iP4500 InkJet Printer
Canon ip1000 not printing even after replacing a new ink catridge
I didn't use my canon ip 1000 for a few months. after that when i tried, it won't print black. i tried nozzle cleaning ( it showed only blue and yellow bars) . i changed the ink catridge (both colour & black) with a new one. but this time the printer won't print. i tried cleaning, deep cleaning. then i removed the printer head and put it in hot water (as told) for half an hour. again i tried cleaning a couple of times before trying to print, but still the printer won't print........what could be the problem.....is it repairable or i have to buy a new one?..........help me please
    Problem Solver:
  • 6 Answers
This might seem a dumb answer, but have you removed the PULL tab over the breathing hole. I had a similar problem until I realised my error.
Posted on Jan 25, 2011
Canon pixma ip1000 print black colour with gaps.
Sounds like printing nozzle problems, or the waste ink absorber is saturated. There is step by step guide to cleaning it at
http://www.wikihow.com/Clean-the-Canon-Pixma-IP1000-Printer-Waste-Ink-Absorber
Jan 23, 2014 | Computers & Internet
Canon pixma ip 1000 black ink not print
Change black ink. If no result, then the printhead is dried. You need to run clean printhead from the printer driver, but in most cases without success
Jan 15, 2011 | Canon PIXMA iP1000
I have canon pixma ip1000. The first problem was that when I try to print out, the black document showed white lines every 1cm. And it was getting vaguer. After few weeks, I used the funtion cartridge...
This printer is quite old now and has a limited life on the print head. The fault you are describing sounds like blocked nozzles and can be as a result of either the print head starting to fail, or ink clogging the front of the nozzles. The most likely culprit will be the purge unit/capping station as it may have old ink and dirt/dust over time caked on it which could be making the problem worse by redepositing the junk into the nozzles instead of cleaning the head! I would suggest that if you are not too technical or hands on, then a new printer would be a better route to take as the cost of a print head is not worth the expense if cleaning the print head and purge unit with an old soft cloth and warm water doesn't help. I hope this info is useful.
Mar 19, 2017 | Canon PIXMA iP1000
Color ink for ip1000 does not flow..??
Now put out u color cartridge and take one tissue paper or toilet paper then put ink color head to paper(soft pressure).after that see u paper are inside show three color appear in paper????(red,yellow and blue).if all have means you cartridge ok if only same or no any coming out means u color ink problem need to replaced new unit.
if got all color out better u open u printer body and check are all cable u plug in back is correct or wrong position??.second u can try go to printer preferences go to find print out in color or in gray-color and change their setting to print out in color
Sep 01, 2009 | Canon PIXMA iP1600 Printer
Need to remove ink in full waste tank
Re: Canon IP1000. I followed Step 1,2,3,4, from page 4 of 9 and so far my printer has got out of trouble - starts to print the Test Page good!
Thank you FixYa for the advice to Canon iP 1500 which also work for Canon PIXMA IP 1000
Lydia A. Brown
CAFAG, Inc. (Sleep Apnoea Support Group since 1986
Bankstown Australia
Sep 04, 2008 | Canon Office Equipment & Supplies
Canon pixma ip1000 ink
dear claire
if your use that, it;s no problem ( you refill this with ink)
it's compatible for your catridge
oke well
thanks
cropp
Mar 16, 2008 | Office Equipment & Supplies
Hii..please help ..i have a problem with printer canon pixma ip1000
hi nana,
for this problem try uninstall the software printer and clear the catridge.after install plug the cabel printer and follow intruction.
Mar 03, 2008 | Canon PIXMA iP1600 Printer
Question for canon pixma iP 1000
folow these steps to reset it..
Step 1: Manual for Service mode
1. Unplug power and USB.
2. Open door and hold power button.
3. Connect power.
4. Close door, then release power button.
Nov 02, 2007 | Office Equipment & Supplies
Canon ip 1000 waste ink reset
want the software tool to reset the waste ink level for canon inkjet printers
Apr 20, 2006 | HP LaserJet 1020 Printer
Canon Pixma iP4500 InkJet Printer Logo
459 people viewed this question
old marine
old marine
