Question about Motorola Mobility H300 Wireless Headset
What is the passkey for nokia 3600 slide. Can it pair with Black Berry?
    Sniper:
  • 105 Answers
Passkey = 0000
Posted on Dec 18, 2009
    Problem Solver:
  • 9 Answers
No.sorry
Posted on Jul 03, 2009
Motorolla h500 no steady blue light
Starting with your headset turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash some times as if it was being turned on, but don't release the button at that phase). With the light steadily lit It is in pairing mode. Now make your phone's bluetooth application search for new devices. After a while, the H500 should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). If the pairing process is successful, the indicator light will flash rapidly, and then, it will enter the stand-by mode. Otherwise, turn your headset off, and go through the whole process again.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Hope you are able to sort your problems out.
Regards, Carlos
May 11, 2012 | Motorola Mobility H500 Wireless Headset
I have two bluetooth enabled phones that I would like to get paired. The first one is a Samsung Galaxy Tab and the other is Nokia 2630. I would like to use the SGT's A2DP / Call and have the Nokia on...
Sure! If your headset has never been paired to another device before, just by turning it on, it should enter the pairing mode, denoted by its indicator light steadily lit in blue. Otherwise, starting with it turned off, press and hold the answer/end key some seconds beyond the point to turn it on. Release the key only when you notice the indicator light steadily lit in blue. Now, first on your Galaxy Tab, go to 'Menu > Settings > Wireless & network > Bluetooth settings' and tick the 'Bluetooth' checkbox to turn it on. Then, tap 'Scan devices'. After a little while, your headset should appear in the list of paired devices. If needed, slide your finger to find your headset in that list. Tap it to start the pairing process. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros). You will be prompted to choose the bluetooth services you want, i.e. phone and media. Of course you can come back to these settings whenever you want, in order to activate or deactive these services. Now untick the 'Bluetooth' checkbox to turn it off, in order to pair your headset with your Nokia phone.
Then, turn your headset off and press and hold the answer/end button to put it in paring mode again. Now, on your Nokia, go to 'Menu > Settings > Connectivity > Bluetooth' and select 'Bluetooth > On'. Then, select 'Search for audio enhancements'. After a while, your headset should appear. Select it and make it connect. Again, if a pairing code (or PIN, or passkey) is requested, enter '0000' (four zenros).
Your headset will be able to handle both your Galaxy tab and your Nokia phone at the same time. it is already connected to your Nokia phone. Go back to your Galaxy tab, and tick the 'Bluetooth' checkbox again to turn it on. You should see the bluetooth icon light in blue in the notification area.
By the way, your headset's user guide can be found here, your Galaxy Tab's here, and your Nokia phone's here.
Hope you are able to sort your problems out soon.]
Anyway, please, let me know if I can help you any further.
Regards, Carlos
Apr 02, 2011 | Jabra BT3030 Wireless Headset
Is Nokia Bluetooth headset CE0560 Type BH-607 compatible with iPhone 4 as it does not find it when searching?
Hello thee you must first make sure your blue tooth device is in pairing mode,to do this it usually means when you turn it on you hold the power button on for 6 to 10 seconds and it puts the device into pairing mode once they have paired you will need a pairing or pin code most manufactures use a 4 digit code they are as follows 0000,1234,1111,9999 i hope this helps if not refur to your manufactures procedure
Feb 21, 2011 | Nokia Bluetooth Headset Headset
I need the passkey to install the bluetooth to my new phone, motorola H681
the default passkey for every bluetooth device is usually 1234. try it and let me know if it works. u have to pair it and enter the same passkey with your mobile/celfone.
Aug 07, 2010 | Motorola Mobility H550 - Bluetooth Headset...
Nokia BH-213 unable to Pired with Nokia E-63,it stopped suddenly
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
May 03, 2010 | Nokia Bluetooth-Headset BH-213 2600...
Pairing my H680 asks for passkey - ??
In most cases they passkey is 0000 or 1234
Dec 05, 2009 | Motorola Mobility H680 - Headset -...
Lost my plantronics 222 bluetooth passkey
trying to install my plantronics 222 blue tooth head-set to my nokia 7610,but it keeps asking for a pass code.
Oct 03, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Pairing problem
Before you use your Jabra BT130, you need to pair it with your mobile phone.
1. Put the headset in pairing2 mode Make sure that the headset is on. Press the answer/end button and press the volume up (+) button at the same time, until a solid blue light comes on.
2. Set your Bluetooth phone to ‘discover’ the Jabra BT130 Follow your phone’s instruction guide. This usually involves going to a ‘setup,’ ‘connect’ or ‘Bluetooth’ menu on your phone and selecting the option to ‘discover’ or ‘add’ a Bluetooth device.
3. Your phone will find the Jabra BT130 Your phone then asks if you want to pair with it. Accept by pressing ‘Yes’ or ‘OK’ on the phone and confirm with the passkey or PIN3 = 0000 (4 zeros). Your phone will confirm when pairing is complete. In case of unsuccessful pairing, repeat steps 1 to 3.
Dec 23, 2007 | Radio Communications
Motorola Mobility H300 Wireless Headset Logo
100 people viewed this question
Top Motorola Mobility Radio Communications Experts
Coss
Pierre Curtis
Level 1 Expert
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
