Question about Polaroid FLM-4234BH 42 in. LCD HDTV
Bad conncetion looses lumanace has croma and sound ok
I have a polaroid flm4234bh, had a tv man out said it was a bad contorl box which is NLA. if i hit the top of the tv picture come back ok. does that sound like the control box and if it is can it be taken apart and repaired. if yes where can i get the schmatics fir it.
  • 4,234 Answers
As far as I know the schematics are not available outside of authorized service centers. Since giving the set a whack appears to "fix" it, it suggests that there is a bad connection somewhere. I would look for poor solder connections. Resolder any that appear to be grainy or have cracks.
Let us know your progress.
Dan
Posted on Feb 18, 2009
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Jun 23, 2012 | Polaroid 4226TLMB 42 in. LCD TV
TV turns on...displays Polaroid then shuts off. Sometimes i can't even get it to the Polaroid point just turns on and turns off.
You have a bad power supply, call a local tv repair man 2 fix it for ya. Unless you think you can do it urself, but recommended a professional takes a look, dont want to damage anything else in the tv or hurt urself
Oct 07, 2009 | Polaroid Televison & Video
My polaroid tv remote isnt working
Get a new remote or try it again with new batteries.
Aug 17, 2017 | Polaroid 1720-7 Remote Control
No sound with HDMI connection.
COULD BE A BAD HDMI,,CHECK TO SEE IF ITS TURNED ON ON THE CABLE BOX
May 15, 2009 | Polaroid TDX-03211C LCD TV
Disc will not eject.
Common cause for a disc not to eject is the loose belt from the motor to the gear that closes or opens the disc tray. You need a repair man to open it and change the belt.
Jan 03, 2009 | Polaroid TDM-1421C TV
FLM-373B Polaroid tv will not come on. The blue light comes on and when you turn it off the red light shows up. The screen of the tv is black and no sound. Can you solve this problem without calling a...
Same problem here. Polaroid Tech Support says that it is the control box.
It is a little over a year old so it is out of warranty with Polaroid.
Except, I bought the two year plan when I bought it at Walmart. So I called them and they are sending me a box and a shipping label to mail it back for repair. I tried to tell tham that is a little big to mail but they insist. This should be fun.
May 02, 2008 | Televison & Video
Help
1)in side ur tv kit    there  sould be  loose connection  at circuit tracks     otherwise    check  EHT SECTION    means   check  ABL signal  from  EHT TO CROMA IC .
2)if ur tv is  stays on  for 5 minutes  only with sound and not with video    then    replace   vertical IC  with the same number
this will solve ur problem
thanks
Mar 02, 2008 | Symphonic SC309C 9 in. TV/VCR Combo
Help me pls1
ok two things here, if it a realy old tv, check and see if it has a vert control knob that you will use to adj the vertical rolling.
are you on a cable box? if so bypass the box and plug the cable directly into the tv bypassing the box, if this works box bad get exchanged.
2nd if it is a new tv, try this, when putting you cable to the tv do it slowley and watch the tv, as the cable gets close to rf imput on tv dose the pix get clearer untill to cable is pluged in all the way? if so you have agc overload and the simplest way to fix this is get a antenuator, this is a small screw on device that will cut the siginal streght down and will stable you picture.
Feb 06, 2008 | Televison & Video
Polaroid FLM-4234BH 42 in. LCD HDTV Logo
102 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
