Question about Logitech 967437-0403 Keyboard
Spacebar-quit-working-after-cleaning-the-gunk-underneath-----now-it-does-not-work-at-all? it-is-a-vaio-keyboard-with-media-center-controls-at-the-top...........
  • skyhawk2235 Feb 21, 2009
    after snapping the spacebar back in place after cleaning underneath it with alcolhol laden q-tip...it did not work on the screen while typing.....it worked fine mechanically,and physically,but did not space between words typed .......after a few days the alcolhol must've dried out because it works like new now.....thanks all for your help
    btw.....the cleaning solution i used was electric pre-shave....mostly alcolhol based with a little lubrication in it.
  • sieben Apr 15, 2009
    Took off spacebar on Dell Desktop keyboard (RT7D50) to clean underneath.  Made note of orientation of the little "swaybar" underneath.  Cleaned, reassembled.  Spacebar is loose and clunky, "swaybar" is loose and does not transfer force from side to side as is should.  Seems the answer should be simple but after 2 hours fooling with it, I cannot resolve the clunk.
    Any suggestions appreciated.
  • 34 Answers
Have you tried applying pressure gently until it snaps back in place? That could be the issue, is that the spacebar unsnapped itself when you were cleaning it. If you were using compressed air (canned air) then you may have blown something underneath it and it jammed itself in there. Trying turning the keyboard upside down and gently tapping it on a hard surface to see if anything else comes out.
Posted on Feb 19, 2009
Xps 15 spacebar not working properly
there might be some junk underneath the keyboard turn off computer
open the screen and lift the computer so that edge of keyboard is on table
GENTLY tap the computer and watch to see if something comes out
if not then you will need to clean keyboard or get a new one
May 17, 2012 | Dell Studio XPS 15 Notebook
Is it possible to adjust the sensitivity of the keyboard? My spacebar doesn't work unless I press it uber-hard!
no there is not a sensitivity setting for the spacebars, however, some people have eaten or trimmed their fingernails and so on by their computers and in turn have gunk stuck up underneith the keys.
So check to make sure something has not landed up underneith it and clean it out if it has.
and make sure the keyboard is seated correctly. (if other keys dont work or don't work well this is a sign that the keyboard connectors are not seated correctly, but if all other keys work fine it is not a seating issiue and your cables are connected just fine.) If under warranty call the HP techs first!
otherwise http://h10032.www1.hp.com/ctg/Manual/c01918142.pdf
Page 70 will get you to the techs maual on keyboard removal, cleaning and so on. a dry toothbrush and a vacume will go a long way though....
Apr 30, 2011 | HP Pavilion dv7-1130us laptop
Myspacebarisnotworking
Greetings,
You may have some small item underneath the spacebar. The spacebar will "pop up" if you use a screwdriver or something to pry it up from the keyboard. Insert it near the B on the top side of the spacebar and pry up towards you. Clean out from underneath and reattach it.
Apr 16, 2011 | HP D8597A Keyboard
IBM Wheelwriter 10 Series II Typewriter 6783. Spacebar suddenly does nothing. Everything else functions fine. Removed spacebar key and vacuumed dust underneath. When investigating possible problem we found...
you will need to replace the keyboard. we see this alot,keyboard starts to fall apart due to age. batteries are only used to hold tab and margin positions in memory. machine works fine without batteries.
Dec 15, 2009 | Televison & Video
Space bar is sticky du to liquid accident ( soft
Get a Electrical/Electronic solvent spray from RS, give it a good spray (with Power Off!) and operate it lots of times. The spray will evaporate naturally and may remove the gunk! Ian.
Sep 17, 2009 | Acer TravelMate 5530-5207 Notebook
Why.does.my.spacebar.not.work?
The pad has slipped.. open KB and reset.
Feb 18, 2009 | Sony VAIO RA710G...
Spacebar.quit.working.
Try to reseat the space bar again.
Media.center.keyboard.spacebar.does.not.work.after.cleaning
i have already posted the solution to my problem.....but i will tell you in more specifics what transpired.........after removing my spacebar.....i used electric pre-shave (an alcohol based solutions with a slight amount of lubrication).......with a few drops of that and a q-tip i cleaned the black tarry mass that had accumulated underneath the space bar most likely from spilled pop,coffee,pancake syrup,cat hairs,and only god knows what else...........after replacing it it worked fine mechanically and physically but did not work on the screen......after a day or two it started working .....i guess the alcohol needed to dry out .....i did put two drops down the tube that had a pad at the bottom (contacts underneath it ).........everything working better than new now .......thanks for being here to help.........
Mx3200 First the spacebar won't work andthenitworkstoowell.
did you check to make sure that the springs and bar under the spacebar are seated correclty?
Sep 30, 2008 | Logitech 967437-0403 Keyboard
Logitech 967437-0403 Keyboard Logo
639 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
