Question about Acer Aspire One PC Notebook
Hi,turned on my AA1 this morning and all i get is a black screen
I have a full charge and ac power cord is connected
I had the same problem, sent it in and got it back in 3 weeks. Works great now
Posted on Feb 19, 2009
    Problem Solver:
  • 10 Answers
Perform power drain and check it..
This might be the issue with static charges on the Mother board.
If this is the case, follow the steps and the issue will be resolved.
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Method 2: remove and reseat the RAM modules and check.
Method 3: remove the Battery which is on the mother board and restart the computer and check.
If the issue is still there, then connect the computer to any external desktop monitor and check. I hope the issue is related to the monitor or the Video card. In this case, please contact the nearest service center.
Posted on Feb 18, 2009
I turn the netbook on and the blue power button is on, but the screen is still remaining black
sounds like the common BIOS flash fix.
First format an USB stick with FAT.
Download the latest BIOS, and put both FLASHIT.EXE and the BIOS file in the root directory of the stick. Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove the USB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected. Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on. Release Fn+Esc after a few seconds, the power button will be blinking. Press the power button once. The AA1 will now initiate the BIOS flash, do not interrupt it under any circumstances. After a while the power button will stop blinking, and the AA1 will reboot shortly after. Wait patiently.
The BIOS has been flashed and all settings reset to default.
If for some reason you made a mistake during the procedure and it doesn't reboot by itself wait 5 minutes before turning it off, just to be safe that it isn't still flashing the BIOS.
Nov 29, 2010 | Acer Aspire One AOD150-1920 Netbook
My screen is black what shall I do?
Nov 28, 2010 | Acer Aspire One PC Notebook
My computer will not boot up
The AA1 has a built-in BIOS recovery routine, which makes it possible to flash the BIOS even if it doesn't POST and the system doesn't boot anymore. It's meant for emergencies and is also known as crisis disk mode. Use at your own risk.
First format an USB flash drive with FAT.
Download the latest BIOS, and extract all files from the zip file. Put both FLASHIT.EXE and the BIOS file with FD suffix in the root directory of the drive. The files must not be in a folder. Rename the BIOS file toZG5IA32.FD, that's important.
Turn the AA1 off, with the USB drive still connected, and make sure both battery and AC adapter are also connected.
Press Fn+Esc, keep it pressed and press the power button. Release Fn+Esc after a few seconds. The power button starts blinking at this point. Press the power button once. The AA1 will now initiate flashing the BIOS, do not interrupt it under any circumstances. After a while the power button stops blinking, and the AA1 reboots shortly after. Wait patiently.
The BIOS has been re-flashed and all settings are reset to default.
If the AA1 doesn't reboot by itself, but the power button still blinks, wait a few minutes before turning it off, and try again.
Jun 08, 2010 | Acer Aspire One PC Notebook
I tried to get computer back to factory settings and now i turn it on and the screen is black,it sounds like it is running though,and also the 2 lock buttons light up when turning it on..please help
Follow every step carefully!
Feb 02, 2010 | Acer Aspire One PC Notebook
Black screen acer aspire 4315, changed screen & inverter but still no joy any help please.
If the screen is black and the power light & fan still work....try this:
ASPIRE ONE BIOS FLASH RECOVERY
http://support.acer.com/drivers_download.aspx
Jan 19, 2010 | Acer Aspire 4315 Notebook
Power is on but i get nothing but a black screen
Jan 19, 2010 | Acer Aspire One Netbook 8.9" Notebook
My ACER netbook turns on but the screen remains
After switching off the aa1, when trying to turn it on again, it just shows blinking leds and the fan is turning. But the screen remains black.
If your aa1 does like this probably its BIOS has been damaged...
Luckily the Acer Aspire One has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore.
Please note that the process I'm about to describe is only meant for emergencies and may void your warranty, so use at your own risk.
1) Format a USB memory key with the FAT mode.
2) Download the latest version of the BIOS from Acer support website:
3) Extract the files from the zip and put both the FLASHIT.EXE and the BIOS file in the root directory of the memory key.
4) Rename the BIOS file to ZG5IA32.FD and then remove the disk.
5) Turn the AA1 off, insert the battery and connect the AC adapter.
6) Insert the USB Memory Key into one of the USB port of the Aspire One.
7) Press Fn+Esc, keep it pressed and press the power button to turn the AA1 on.
8) Release Fn+Esc after a few seconds, the power button will be blinking.
9) Press the power button once. The AA1 will start the BIOS flash, do not interrupt for any reason. After some minutes the power button will stop blinking, and then the AA1 will reboot. Wait till the AA1 has completed all this operations.
If everything has gone right, the BIOS is flashed and all settings are reset to default.
Nov 16, 2009 | Acer Aspire One Netbook 8.9" Notebook
Will not bootup....got a black screen
"Download the latest BIOS, and put bothFLASHIT.EXE and the BIOS file in the root directory of the stick.Rename the BIOS file to ZG5IA32.FD, that's important. Do not remove theUSB stick.
Turn the AA1 off, make sure both battery and AC adapter are connected.Press Fn+Esc, keep it pressed and press the power button to turn theAA1 on. Release Fn+Esc after a few seconds, the power button will beblinking. Press the power button once. The AA1 will now initiate theBIOS flash, do not interrupt it under any circumstances. After a whilethe power button will stop blinking, and the AA1 will reboot shortlyafter. Wait patiently.
The Bios can be found from the Acer site. Source(s): http://macles.blogspot.com/2008/08/acer-aspire-one-bios-recovery.html
Aug 26, 2009 | Acer Aspire One PC Notebook
Acer One pc notebook black screen?!
That is a problem of BIOS. U need to reset your BIOS.
Acer Aspire One BIOS Recovery
The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
May 07, 2009 | Acer Aspire One PC Notebook
My acer aspire one netbook was black screen but the power was lighted, i hear the fun was spinning and the hdd was spinning, please help me, when i powered on it lights up but no display at all a blac
Acer Aspire One BIOS Recovery The AA1 has a built-in BIOS recovery routine, making it possible to flash the BIOS even if the system doesn't boot anymore. It's only meant for emergencies and may void your warranty, so use at your own risk.
Download WIN98BOOT.ZIP and HPUSBFORMATTER from the internet normal bootable like a diskette won't work with a usb stick
I had mine 2 months it's a common problem with the notebook.
The onely thing that you have to do is download these programs with someone with a internet connection.
Good luck
May 04, 2009 | Acer Aspire One Netbook 8.9" Notebook
Acer Aspire One  PC Notebook Logo
82 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
