Question about Ricoh Aficio BP20 Laser Printer
I have a aficio bp 20 series pcl 6 printer its failing to print.
But power is there and it is initialising some 2-3 min.then a red light for error appears.but it is failing to print.
Is it only the 'red' light or is there another one also lit?
If it is on steadily, it should be related to a paper jam, if blinking, then related to Data in, and no paper.
Manual is here to check what the status lights mean (copy this link into your address bar):
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/bp20n/bp20nen.htm
** info is on page 6.21
Posted on Feb 20, 2009
Ricoh Aficio SP C430DN - Print Data Error
Its you, change drivers, postscript on the printer? PCL 5C is what your are using?
Mar 31, 2014 | Ricoh Office Equipment & Supplies
I`m using a PC with win7 and a network printer Aficio BP20 Series PCL 6 its only print in B/W not color why? Need help.
if you are using the proper driver there should be a setting if you click the properties button when you hit print on the computer. from there you can set it to print in color.
Aug 10, 2011 | Ricoh Aficio MP 1600L Black and White...
HP LaserJet 2015 printer series - PCL XL ERROR is reported during printing
First Solution :
1. Disconnect the Power Cor from back of Printer ( while printer is has power )
2. Wait for 10 seconds
3. While holding Power Button, Connect the Power cord and release the power button
2nd Solution :
This issue can be fixed by enabling the following option in Printer Preferences . To access Printer Preferences , follow these steps:
  1. Open the Control Panel .
  2. Open Printers and Faxes .
  3. Right-click HP Color LaserJet 2015 PCL, and select Printing Preferences .
  4. Under the Advanced tab, change the Print Data Optimization from Auto to Optimize for Text and Vector .
  5. Now try printing the document.
  6. If the document did not print then try turning the printer off then back on. Try printing the document again.
Jun 18, 2010 | HP LaserJet P2015 Printer
My hp color laserjet cp2025 has the pcl xl error subsystem: Kernel error: Illelgaloperatorsequence operator beginpage position: 14 What can I do to fix this?
A Hewlett-Packard LaserJet printing language, PCL 6 is optimized for printing from graphical user interfaces (GUIs) like Microsoft Windows.
The Enhanced PCL XL, or PCL 6, driver that is included with the HP LaserJet printers provides enhanced WYSIWYG and enhanced performance with application support over the Standard (PCL5e) driver. PCL XL is a new page description language by HP, that is part of PCL 6 and is closer to GDI, which many applications use. Less translation takes place by the driver, which means increased WYSIWYG capabilities, and better performance with applications that support escapes implemented by the Enhanced driver.
While printing using the PCL 6 driver it is possible to encounter a PCL XL error. This error will print out at the LaserJet device, and will look like something similar to the following:
PCL XL error
Subsystem: KERNEL
Error: IllegalOperatorSequence
Operator: EndSession
Position: 15
These type of errors can be PCL interpreter errors, firmware related, tied to communication, driver, driver dependency, and application specific. Additional troubleshooting will be required to further isolate to root cause.
Troubleshooting:
I. Verify printer functionality
To verify printer functionality, perform the following:
1.Power the printer Off.
2.Disconnect the parallel, USB, or network cable.
3.Power the printer On.
4.Once the printer display reports Ready, verify device functionality by printing a Configuration Page from the device.
Note: should the internal printer test not print as expected, and/or a PCL XL error occur, you have then isolated the issue to the printer device, and any network connectivity or driver / application troubleshooting can be ruled out.
II. Verify communication w/ the device
To verify communication with the device, perform the following:
2.Reconnect any communication device cable previously removed
4.Once the printer display reports Ready, perform the following:
a.From the client machine or print server that had previously encountered the PCL XL error open the Printers and Faxes folder.
b.Right click the PCL 6 driver in question and select Properties.
c.From the General Tab select Print Test Page
d.Verify the driver test page successfully printed
Should the test page successfully print, continue with the next troubleshooting section entitled Isolate user, application and/or file.
Should the PCL XL error manifest itself as a result of the driver test page, perform the following:
1.At the print server, or client machine, open the Printers and Faxes folder
2.Click on Add Printer
3.Go through the Window’s driver install process installing the appropriate PCL 6 driver for the device in question, with the following characteristics: printing directly to the device (IP_Address, USB, Parallel, etc), creating a new print queue, selecting to Replace Existing Driver.
4.If the issue persists see section entitled: Microsoft Unidrv driver dependencies.
Note: If using an HP LaserJet PCL 6 device specific driver (discrete), try installing the latest HP Universal Print Driver PCL 6. Available at the hp.com website under support & drivers. Select product cb534a and also select your operating system, download a universal print driver Post Script would be the best selection.
You can also adjust a few settings under printing preferences:
under the advanced tab:
Raster compression:
Set it to max
III. Isolate user, application and/or file
If in fact the printers internal test pages and driver test page have printed successfully, further fault isolation must be performed to correlate the PCL XL error with a specific user, application, and or file. This information is most often easily gathered by speaking with the customer, investigating which user is printing when the PCL XL error manifests itself. Once the user is identified, the application the client was printing from can be isolated, and quite possibly the application file itself.
If an application file consistently causes a PCL XL error when sent to the device, it could be a problem only with the file.
IV. Microsoft Unidrv driver dependencies
The issue was identified to be related to Microsoft unicore files: unidrv.dll, unires.dll, and unidrvui.dll, that were not compatible with the available PCL 6 drivers at that time. Microsoft has developed a hotfix to address the symptomatic PCL XL errors – the Microsoft Hotfix can be reviewed here:
Microsoft Windows 2003 and XP: http://support.microsoft.com/kb/948046/en-us
Microsoft Windows 2008 and Vista: http://support.microsoft.com/kb/948349/en-us
Microsoft Windows 2000: NA
HP LaserJet – PCL XL Error
If anything else let me know,
Al
eliteprintersolutions@gmail.com
May 27, 2010 | HP Laserjet Cp2025n Printer
PCL XL error problem
Try to update the latest firmware for your printer.
Aug 24, 2009 | Ricoh Aficio 450 Copier
Error message on Ricoh Aficio BP 20 PCL 6 printer
Flashing orange means low toner.....solid red should be a paper jam
Feb 20, 2009 | Ricoh Aficio CL2000N Laser Printer
Ricoh SP C410DN Will Only Print One Page
Hello sir; you need to set up your system from printer, go to manue ,roll down to system , roll down to auto continue,then press enter ,
Feb 13, 2009 | Ricoh Aficio CL3500N Laser Printer
PCL XL error
It is a driver error, try another printer driver version or use PCL 5 rather then PCL 6 driver,
Check your USB cable it must be HighSpeed or USB 2 cable.
Jul 28, 2008 | HP LaserJet 3050 All-In-One Printer
Printer wont do anything ricoh aficio 1515 pcl 6
The first thing to try is to turn the machine off, then back on at the red "main power" switch located on the left side of the machine. If the code returns it is indicative of firmware problems or a loose connection.
At this point I would seriously recommend getting a service tech to come out. However, if you want, you can take off the back cover (MAKE SURE THE POWER CORD IS UNPLUGED) and double check all of the connections by (GENTLY) pressing them into their connections. Hope this helps. Let me know.
Mar 31, 2008 | Ricoh Aficio 1515MF All-In-One Laser...
Ricoh Aficio BP20 Laser Printer Logo
1,257 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
fares
Level 1 Expert
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
