Question about Dayton (4LX51) Heater
Dayton 4lx51; pilot glows, intermitent pilot flame, either way the burners will not ignite, then fan turns on and blows cold air. green light on top of valve comes on solid, then flashes. Graingers tech line said to replace valve, i did, but same problem. I turn the heater on, turn the thermostat up full (in a 32 degree space). The burners light and run for a couple of minutes, then the fan comes on and runs for a couple of minutes and I think life is good. Then the burners go out (pilot still on) and the fan keeeps on running, even though the thermostat is still calling for heat. I shut everything off and start over, and the fan comes on but no burners. Oh yeah, the motor hums on startup and will not spin unless you give it a "kick" (I assume this is a bad starting capacitor?).
    Genius:
  • 1,550 Answers
Yes you are correct it is due to bad starting capacitor you have this problem ,
You need to replace the capacitor .
Also check thermocouple is working properly.
Posted on Feb 18, 2009
  • 744 Answers
Hi try to change the thermocouple unit.
  • 544 Answers
Thank you for using Fixya.com..
i strongly suggest you not to do any unusual thing that may caused a problem..
mam you need to go to a specialist who can fix it because the problem is some sort of electrical wiring inside the unit..
don't used it unless it is not seen by a technician.
it may caused a accident like fire or explosive...
hope you will follow my advice urgently.
thanks,
  • 19,396 Answers
Test the thermocouple connected to the burner with a multimeter.
  • Ginko
    Ginko Feb 18, 2009
    If the burner turn off after a couple of minutes, test the thermocouple connected to the burner with a multimeter.
    This problem should not be related to intermitent pilot flame, that is because the pilot flame valve is defective and has incorrect pressure.
  • Ginko
    Ginko Feb 18, 2009
    Ah yes, and regarding the motor, that is still another problem, there is a starter (capacitor) to start the motor or a motor control unit that can be cause for the fault.
No flame
Several steps here to check...
turn power off unit and back on
set thermostat to heat
watch for pilot to ignite..igniter should glow orange or cherry red or spark if its a spark type ignitor
Did you see a pilot light ignite?
If not you probably have a bad igniter.
If pilot lit....in a little bit you hear a click of the gas valve opening..then the main burners will ignite
If you see the pilot and the main burner lights but goes out in a few minutes or immediately you may have an issue of the "high limit" switch tripping.
Is the blower fan turning that blows air out of your vents?
are all your vents open in your house? too many times i see homes with almost all vents shut.
Jan 08, 2011 | Goodman GMS90703BXA Heater
No blinks normal running igniter glows gas comes on wont run
Check for 24 volts across the gas valve when Ignitor is glowing. If no, bad board. If yes, bad gas valve or blockage.
On a call for heat, the 24 volt thermostat sends a signal to the control module. The control module will indicate a call for heat with a light on the control either blinking or remain solid depending upon model. The inducer (exhaust) blower will purge all gasses from the furnace and pressurize a pressure switch. Once the pressure switch tells the module to continue, the electronic ignition will energize and send 120 volts to the igniter. The igniter will glow and you will be able to see it if viewed thru the small inspection port. Once the igniter gets hot enough, it sends a signal to the module opening up the gas valve (24 volts). Either a pilot will come on or the burner tube will ignite then spread the flame to all burners. Lastly a safety sensor will be looking for a certain temperature within a few seconds and the furnace will continue to operate and the room air blower will turn on in a minute or two.
What could go wrong? The unit will not run if there is no signal from the thermostat (bad thermostat or broken wire), the control module does not sense a signal from the thermostat (bad control), the inducer does not energize (bad motor), the pressure switch does not close (blocked vent piping, bad switch, plugged condensate hose), the igniter does not energize (bad control, bad igniter), the gas valve does not open or there is no gas (bad gas valve, broken wire, no gas), the pilot does not light (dirty pilot), the burner does not light (bad burner, plugged orifice, not enough combustion air), the flame does not spread to each burner (bad flame spreader, dirty flame spreader, more bad burners), the flame safety sensor does not detect flame (dirty or bad flame spreader, bad flame sensor, broken wire, bad control), or the room air blower does not energize (bad fan motor, bad control).
Mar 05, 2010 | Goodman GMS90703BXA Heater
Hi i hope you can help. I have a high effeciency furnace and the burners keep turning off.
Feb 16, 2010 | Dayton Gas Furnace Heater
Red light blinking continuosly meanig gas valve relay short how can I fix myself - furnance only blows cold air
You will need to check for 24 volts AC to the gas valve after the igniter starts sparking or glowing. If you have it but it does not open, bad gas valve and you will need to replace it. If you are not getting 24 volts after it starts glowing or sparking, you have a bad board.
Jan 16, 2010 | Heating & Cooling
Turn heat on, I hear it ignite and furnace runs and runs fine then usually there is a slight delay and blower turns on and blows heat, but now it does not, I put my hand up to a nearby vent to no heat and...
Jan 06, 2010 | Goodman GMS90703BXA Heater
Our furnace intermitantly turns off,and we have to flip a (light)switch next to the furnace and reset the thermostat. It usually happens on the coldest nights. We have had it serviced and it is in good...
Bad electrical connection? Check the ground wires. Is the furnace giving you any error codes?
Jan 03, 2010 | Goodman GMS90703BXA Heater
My heater blows cold air. any ideas?
Your unit has a diagnostic light on the circuit board. You need to look thru a small viewing port to see it. Once you count the number of b links, remove the lower panel and look at the wiring diagram for an error code chart. Then read the following to give you some ideas what to do.
Dec 01, 2009 | Goodman GMS90703BXA Heater
Furnace heats for a while then quits and blows cold air
Not much to go on like a make or model number so this will have to do.
Oct 23, 2009 | Heating & Cooling
Blower works but no heat
If in fact you have the above listed furnace, you do not have a pilot but electronic ignition. You will need to remove the front cover on the furnace, tape down the door safety switch and then have someone help you by turning up your thermostat to a very high setting. Watch and listen inside the furnace. There should be some blinking going on at the control board followed by a small blower fan starting up. Then after 10-15 seconds there should be a click followed by an orange glow viewed thru the viewing window to the burner section. In a few seconds the gas valve should click and the burners will ignite. There is a safety switch that will sense flame and then keep the gas going to the burners. If it does not sense it, it will shut it off within 10 seconds. If all is well so far, your blower will turn on in about 90 seconds after flame. There is a diagnostic code chart on the back side of the access door if you get an error code (blinking) on the control board.
Always check little things like air filter, condensate drain and broken or loose wires.
Nov 05, 2008 | Goodman GMS90703BXA Heater
Dayton (4LX51) Heater Logo
67 people viewed this question
Top Dayton Heating & Cooling Experts
paulcarew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
