Question about Jandy Aqualink Rs4 One Touch Control System Control System
Aux items come on by themself
My spa blower and pool lights which are on aux 2 and 3 come on by themself. they may go off after a few minutes or run all day. i have cleared the memory but this stills happens. it may happen every day or go days and work as it is supposed to. i have also noticed button three does not work on my spa side switch.
  • 22 Answers
Check wire going from out door panel to indoor panel.if this doesnt work tou need a new board.
Posted on Feb 18, 2009
Having trouble getting cleaner to activate. Should cleaner be the same AUX # inside and outside?
make sure dip switches on board ok filter pump must run when cleaner is on or will ruin pump
Jul 11, 2017 | Pool & Spa
My spa is draining into the pool when I put the blower and heater on.How do I stop it?
you have to go into set up sounds like your acuator for spa is highlighted with the aux that your blower is set on uncheck it from that aux also check jva assignment if you need more info please email me
Jun 19, 2014 | Jandy Aqualink Pda Ps4 Wireless Handheld...
What can I do to use a PCB#6474G to replace a broken PCB#8124A?
yes the G is just a newer board go to set up and reprogram all your auxs just re assign them
Jun 15, 2014 | Jandy Aqualink RS4 Pool/Spa Combo -...
What does the airblower do on my pool equipment? when should it come on and for how long?
air blower is used only on spa or if you have a autocover with a blower if more info is given i can help you better
May 23, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
RS 4 not one touch
Is there a different button that turns your cleaner on? Depending on the version you have, the aux that you have the blower attached to is the default aux for the booster pump. The auxiliaries may need to be cleared and relabeled, and the relays rewired to get the booster pump on its default relay, and the blower on one of the others.
Nov 10, 2013 | Jandy Aqualink Rs4 One Touch Control...
Jandy pool installation for RS8
1 check to see when you change from pool to spa the acuators are moving if not turn on or make sure wires not cut if not give me more info 2 make sure landscaping is on aux that is plugged in to relay if you need more info email me
Jun 21, 2012 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
How to wire the Aux 1,2 & 3 relays for Blower, spa light and pool light.
which ever you have wired to each relay connect the correct relay red and black connector then go to system setup and assign the aux and name them
Oct 24, 2011 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Jandy Aqualink Rs4 One Touch Control System Control System Logo
208 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Bill Jordan
Ian Kime
Ian Kime
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
