Question about Tools & Hardware - Others
Ryobi planer won't pull wood through, Sometimes pushing/pulling helps.
  • Anonymous May 06, 2009
    I have the same problem with my Ryobi 1300 planer. It doesn't seem to matter how much or how little I plane off, you have to push/pull the wood thru and when working by your self when you move from pushing to pulling the wood stops and you get a small cup where the blade is running against the stalled wood. We also have a Delta 12.5" planer setting beside the Ryobi that is used to do the "rough" planing and then we finish in the Ryobi. We have no problems with the Delta feeding with cuts as deep as 1/8" but the Ryobe won't even pull the wood thru at 1/64". Any Ideas on how to solve this problem? The feed speed on this planer has been changed to 18 fpm from the 26 fpm, and I would have thought that would have given it more power to the feed rollers to pull the wood thru.
I have this planer and what I have found is first clean the rollers with naptha on a rag be VERY CAREFUL plug machine in kick on and off un plug machine clean exposed part of roller then plug in and kick on again to move rollers, after that clean in feed and out feed tables then wax with hard wax and polish and wood should feed thru much better.
Posted on Dec 06, 2009
  • 10,865 Answers
These planers are a bit sensitive. Too much bite and too little both result in the problem you cite. The hardness and the dryness of the board also impacts it. Therefore, I would say for starters just experiment a bit with the amount you are trying to remove with each pass. I usually only remove 1/16th inch per pass.
Posted on Feb 19, 2009
Wood planer
Is the wood long enough to be pulled by front pinch rollers all the way until the next set of pinch rollers?
possibly the rear set has one of them misaligned.
Is the grip/rubber sleeve/knurling intact?
Good luck
Aug 01, 2016 | Crafts & Hobbies
Ryobi pcn 4040 chainsaw won't start What is the
1st add fuel/oil mix to fuel tank , then top off oil tank with bar oil , place saw down on flat surface , press 'ON" button above trigger handle to ON (its marked on case) then pull out blue choke handle till it clicks and stays out , press primer bulb with thumb 8 to 10 times bulb will become harder to press as it fills carb , push chain brake forward (on) ` place left hand on top of saw and right hand on start cord , hold saw down firmly and pull cord vigorsly several times till it sort of starts (sound) , squeeze trigger in and pull cord once more , saw should take off running , chain wont move ,walk to wood pile then disengage the chain brake and cut wood , if saw fails to start after this procedure then there must be a fault in saw , consult a exp small engine dealer for repairs
Sep 01, 2013 | Ryobi 18-inch Electric Chainsaw Chain Saws
Dw735 planner thickness
Is it cold in your shop? The rollers won't work if they're cold because the rubber gets stiff. Clean your rollers also with mineral spirits. Hope that helps.
Jul 11, 2013 | Dewalt DW735 13 Inch 2 Speed Planer With 3...
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
I am replacing one damaged roller on my AP13AK planer. I have an exploded view of the whole machine which shows numbers of all parts. A list and description of parts would be helpful. Where can this be...
HI I HAVE THE SAME MACHINE AND MY FEED ROLLERS HAVE JAMMED SO AN EXPLODED DIAGRAM MIGHT BE HANDY AS I PULL IT APART
COULD YOU PLEASE EMAIL ME A COPY OF IT TO
PETER BULLARD AT aj4bullard@bigpond.com
THANKS PETER
Mar 08, 2011 | Ryobi Thickness Planer Blades
Ryobi AP1301 planer. Suddenly started getting ripples in wood.parallel to blades. Tried reversing blades to unused side, made no difference.Only trying to take of about 1/16". Stock is...
CHECK THE ROLLERS THAT PULL THE WOOD THRU, I HAD TO REPLACE MINE FOR THE SAME REASON.
IF THEY HAVE A LOT OF USE YOU WILL SEE WORN FLAT SPOTS ON THE ROLLERS CAUSING THIS PROBLEM
Jan 16, 2011 | Ryobi Thickness Planer Blades
Uneaven thickness when planing. how do i adjust
You mean you're getting speed bumps? Do you have the blade setting tools that came with the planer? You need them, it will be hard to do without them. It is a little C shaped jig that rides on the drum over the knife, you have your knife sharpened and set in the drum, snug, not tight,under the knife are adj screws, you run the knife setter around the drum and just scrap the top of the knife, do not pull the knife, just go over it barely scraping it, then snug it up, do not tighten anything yet, move on to the next screw, do the same thing, then the last screw, then go back to the first, still good? second, third, now, tighten them up, the setter doesn't pull the knife, just barely scrapes it, but it does hit it. Now do the other side. Both knives will be set the same, no more speed bumps, or uneven cuts. To move the knife back in, if you brought it out too far, use a block of wood to tap it down, make sure you put the elevation screw down first. Do not answer the fone while doing this. It is serious stuff, when those knives start flying. Hope this helps.
Jul 07, 2010 | Ryobi Thickness Planer Blades
Need a Ryobi Model AP-10 wood planer owners manual
Here is a link to download the manual. Scroll down the page about half way and you'll see the Ryobi Manual download link. Hope this helps.
http://powertool.manualsonline.com/ex/thread/view/idThread/11678
Aug 19, 2009 | Tools & Hardware - Others
How to use Hand Power Planer?
Power planers are wonderful little devices that move work along quickly and easily when you’re working on such things as decks and remodeling jobs. Just like a manual planer, this planes or evens the wood by shaving off enough to make a uniformly flat and even surface. Think of it as a wood shaver or an effortless sanding tool. It can take a warped edge off of a door and make it functional again or it can straighten out a piece of wood so that sheetrock will go on flat. These are very handy tools for those who like to work around the house. Understand what power planers can do. You can use them to smooth the edges on all kinds of wood or to bevel (make a cut for a joint that isn’t 45 degrees) door edges. They will level framing lumber and chamfer (make a 45 degree angle in) handrails and scribe (mark or score) countertops or cabinets and taper and shape wood trim. They’re a very easy tool to use and they save a great deal of time but, as with any power tool, you do need to spend a little practice time before you use this on a real project. Know how power planers work. They have blades that are mounted on a cutter head that spins at about 20,000 rpm. The planer sits on a sole plate, also called a shoe, and the front and rear shoes can be adjusted. The difference between these shoes determines how much wood is taken off when it’s used. There is a front hand grip that adjusts the shoes and so determines the depth of the cut. A power planer can remove from a trace of wood 1/64 of an inch to 1/8 of an inch with each pass. Know how to use the power planer. As with many woodworking and power tools, the key to using this successfully lies in holding and propelling it along properly with the right amount of pressure. Pressure is the most important dynamic used. Stand in a position that you can stay in while you take a pass with the planer. If you shift your weight, you’ll shift the pressure. Set the front shoes of the planer on the wood before you turn it on. Start it up, give it a second to get up to full speed, and then push it steadily with even pressure along the wood. Keep the pressure even on the front knob and the handle so you don’t gouge the wood deeper in one place than another. Be careful to hold the pressure steady as the front shoe runs off the end of the wood. Change the blades when they start to seem dull. You don’t want to wait until they’re smoking or throwing up powder. If you sharpen or replace the blades, do them both together as they wear evenly and replacing only one would give you an uneven cut. Unplug the tool before you touch the blades. Make sure to mount them completely according to the gauge bases that come with them. These tell you exactly how to set them in the correct position. Know how to safely turn the planer off. When you shut off your planer set it down on a wooden block and wait for the cutter head to stop spinning. Every time you use this, check the mounting bolts to make sure they’re still nice and tight. Remember your safety goggles or glasses. Wood shavings can fly all over. Once you get the hang of this, you won’t ever go back to planning by hand.
Aug 27, 2008 | Sheffield Hangzhou #532606 3" Adjustable...
Tools & Hardware - Others Logo
752 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
