Input a number and then show the fibonacci sequence of the input number in a C++ program.
  • 4 Answers
I'm assuming one of two things, either
A) You need help for a programming class?
or
B) You're just curious?
Either way
#include <iostream>
#include <algorithm>
using std::swap;
using std::cout;
using std::endl;
// Function f returns n'th Fibonacci number
// It uses Algorithm 2C: non-recursive loop
unsigned int f(unsigned int x) {
unsigned int x1=1;
for(unsigned int i=1,x2=1;i<=x;i++) {
x1+=x2;
swap(x1,x2);
return x1;
// Function f_print prints out n'th Fibonacci number
void f_print(int n) {
cout << n << "th Fibonacci number is " << f(n) << endl;
// main is the entry point in C++
int main() {
f_print(46);
Posted on Feb 18, 2009
I need three numbers for lunchtime today please help me please
not a technical problem for fixya site
Nov 22, 2016 | Optics
Sample of how to create a python program that will input two numbers and will ask the user of operation to perform as to addition,subtraction,multiplication or division the program should perform the...
Assuming that the input numbers are given by the user:print "Menu"print "1. Addition"print "2. Subtraction"print "3. Multiplication"print "4. Division"print "0. Quit"
a = input("Please make a selection:")if a == 1: x = input("Please enter a number:") y = input("Please enter another number:") answer = x + yprint "%r plus %r = %r" % (x,y,answer)elif a == 2: x = input("Please enter a number:") y = input("Please enter another number:") answer = x - yprint "%r minus %r = %r" % (x,y,answer)
The same goes for everything else just with different signs. Don't forget that "*" is multiplication and "/" is division. Also, for 0. Just use:
elif a == 0: quit
Sep 28, 2011 | Computers & Internet
Wirte a pogram in java using for loop,that will print out the first 1 numbers of a fibonacii series that is:1 1 2 3 5 13 21 34 55
package com.gpt;
import javax.swing.JOptionPane;
This program computes Fibonacci numbers using a recursive
method.
public class Fibonacci
public static void main(String[] args)
String input = JOptionPane.showInputDialog("Enter n: ");
int n = Integer.parseInt(input);
for (int i = 1; i {
int f = fib(i);
System.out.println("fib(" + i + ") = " + f);
System.exit(0);
Computes a Fibonacci number.
@param n an integer
@return the nth Fibonacci number
public static int fib(int n)
if (n return 1;
else
return fib(n - 1) + fib(n - 2);
Feb 24, 2011 | Sun Java Programming Language (cdj-275)
Fibonacci formula won't graph, but will show table
Fibonacci sequence is the series of numbers 0, 1, 1, 2, 3, 5, 8, 13, 21, 34, ...
At first type Fibonacci equation in Y editor with condition x>=0 and then graphing it. See captured images with enlarged form of graph
Apr 11, 2010 | Texas Instruments TI-84 Plus Silver...
Write algorithm that displays the first N numbers in Fibonacci
Try this site, I think it gives you the best answer:
http://www.scribd.com/doc/10396888/Flowchart-of-Fibonacci-Number-Display-and-Summation
Feb 14, 2010 | Global Marketing Partners FLOWCHARTS AND...
Please Solve this C++ Program
Write a program to prompt the user to input several lines of input. A line of inputs is terminated by '*'. For each readline of input the program should output:(use pointer notation for the array) . The total # of words . The lenght of the longest word in the line At the end the program should output: . The total number of words read in all lines of input . The lenght of the longest word read in all lines of input
Jan 19, 2009 | Computers & Internet
Memory program ch no# on icom u or h16
I had the same problem. I solved it by going into program mode, then while holding down the function key, input one of the missing channel numbers. The channel should appear but is flashing. Now input a frequency for the channel and exit program mode. Repeat the sequence for the other missing channels. This procedure worked for me. Good luck.
Nov 19, 2008 | ICOM Informatique Icom Radio U16, IC2GAT,...
I need solve this type calulation is 0,1,1,2,3,5,8,13,21,34 etc. u send me the code of this type of calculation in c++ language
Ok! Here's a snippit from some code I wrote in beginning c++ classes. However, don't just cut and paste it. Know how it works since it's important in algorithm examination!
Just tested it, compiles and runs perfectly on GCC 4.0.1 on my mac, as well as my linux boxen. Windows may take some changes to output data.
* Steven Parker
* Calculating Fib Sequence
* after two starting values, each number is the
* sum of the two preceding numbers
#include <iostream>
using namespace std;
int main() {
int whentostop = 20; //How many values of sequence to calculate
int fib[whentostop]; //Hold fib numbers
for (int i=0; i < whentostop; i++) {
if (i == 0)
fib[0] = 0;
else if (i == 1)
fib[1] = 1;
else
fib[i] = fib[i-1] + fib[i-2];
cout << "Fibonacci[" << i << "]: " << fib[i] << endl;
return 0;
Nov 12, 2008 | Computers & Internet
Computers & Internet Logo
153 people viewed this question
David Payne
David Payne
