Question about Sunlight Supply 400 Watt Hps Sunsystem I Sun Gro Plant Grow Light
Hello...need help.. replaced 600mh bulb then
Hello...need help.. replaced 600mh bulb then switch on.bulb came on for 4-5 seconds then unit stoped working.. fuse is ok ...and had look inside ballast box and all wires are fine...no noise at all coming from unit....jhon..
  • Mark Willison
    Mark Willison May 11, 2010
    600W MH or HPS?
    Do you have any sort of meter to test if you have power coming out of the ballast? If not, it is a must have item in my opinion. Can get analog one from Home Depot for $13.99. See link below...
    http://contractorservices.homedepot.com/...
    Anyway, if there is indeed power coming out of the ballast, then you probably just have a bad light bulb.
    How old is the light bulb?
    Problem Solver:
  • 12 Answers
Have you tried the switch yet? The plastic switches inside some ballast boxes don't do well with the heat produced by the ballast. You can try to simply bypass the switch and hard wire the ballast to the plug to test whether or not that might be your issue. If you need a new switch, just call Sunlight Supply directly http://www.sunlightsupply.com/hort/contact.aspx they should be able to send you a replacement switch.
Posted on Mar 01, 2009
How to change a light bulb on my Frigidaire oven model RT 70 light bulb in the signal light area in the surface unit switch?
Hello Heidi, thanks you for your inquiry!
From the information you have provided you need to change the light bulb inside of your Frigidaire Imperial Electric Range. This appears to be an older model and I was unable to locate any direct information on how to change a bulb. Since your appliance is older than ten years old the manufacturer may not have any information for it. You may need to perform a generic search online for further help with the bulbs or speak with a local technician. I hope this information is helpful. -Matt
Jun 02, 2015 | Frigidaire Kitchen Ranges
How to replace bulb in heated seats switch on Mazda mx5 2004
Carefully prise out the plastic gear lever surround and unscrew the 2 screws which are exposed at the bottom of the centre console. Then carefully prise out the console fascia - this will remove the radio surround (perhaps easier to remove the stereo first) and also the cigarette lighter / light level adjuster / heated seat switch cluster. Now it's just a case of unclipping the plugs and pushing the switch unit through from the back.
After removing the switch unit, you'll see 4 plastic bulb holders on the underside - 2 for the switch backlights and 2 for the 'on' lights. These turn 1/4 and can be removed.
Apparently these bulbs are pretty expensive to buy from Mazda, and I have been unable to get a part number to source them elsewhere, but they certainly can be replaced.
Apr 24, 2012 | 2005 Mazda MX-5 1.9
What does the second switch about the door in the refrig control. we know one is for the light what is the other? we have a 550 sub zero
Typically the second switch is for the ice dispenser and fan,when the door is open the fan and the ice dispenser power is cut off via that second switch
GENE
Sep 24, 2011 | Sub-Zero 650 / O Bottom Freezer...
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
My drivers side turn signal stoped working. I replaced the bulb and it worked for a few days then stoped again. I checked the bulb and it didnt blow. Also checked the fuses and all seem to be good. Tried a...
You are going to have to check wiring. Many it is the socket. If you have a test light or meter you can measure the voltage.
There are several turn signal lights, front, rear, side, etc. Do any of them work on the drivers side? if not then it may be the column switch. If only one light is out, then it will be wiring somewhere. Chasing wiring problems is as hard as chasing hydraulic problems, requires patience and starting at one end and continuing till you find the problem.
Good luck, Jim
Feb 23, 2011 | 2005 Saturn ION
Television only has a flahing red light
Ur power supply board is dead, u know basic electronics’ and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your tv power stable,and work again.Or tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement. Hope this will help...
May 27, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
The dash lights in the radio and heater controls do not work. How do I change these bulbs?
Hello... These bulbs are not normally replaceable. Except when the units are replaced. Ex. The Heater Control Assembly replaced would replace the bulbs.
One thing could be causing this is, The brightness switch could be dirty. Try cleaning it with some electrical cleaner.
If this does not help you might consider taking it to a mechanic for further troubleshooting....
Good Luck....
Apr 27, 2010 | 2000 Chevrolet Silverado 1500
Sometimes during night several times try to start
it sounds like the fflame sensor needs to be replaced, however if the unit has fan assited combustion you may also have an issue with the pressure switch. hope this helps
Nov 02, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Tv stoped working - LIFI PT56LCZ70
This unit has a very complicated bulb replacement procedure. You would be much better off if you contact a panasonic service center and have them replace it. Bulb assy is pretty expensive as well. The part # is LFS4000PA1EB but you will have to go to panasonic to get it. Good luck. Thanks
Oct 27, 2009 | Panasonic PT-50LCZ70 50" HDTV
LEFT TURN LIGHTS WILL NOT WORK ON 1993 TROOPER
believe it or not, a 4 way flasher can cause this even if it itself is working properly, otherwise flasher, bulbs, or switch is bad .
Oct 06, 2009 | 1993 Isuzu Trooper
Sunlight Supply 400 Watt Hps Sunsystem I Sun Gro Plant Grow Light Logo
231 people viewed this question
Top Sunlight Supply Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Sunlight Supply Garden Expert? Answer questions, earn points and help others
