Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Picture Well my screen looks like it's 3d has a blue & red lines towards the sides of the screen (solid lines) . i think i might need a new bulb . help
  • Sony Master
  • 3,459 Answers
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
Solution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Posted on Feb 22, 2009
  • 4,234 Answers
This is a convergence problem. If you can solder and are comfoprtable working inside the set where there are potentially dangerous high voltages even when unplugged, you can fix this yourself. Locate the convergence ICs (STK392-560) and resolder the pins on those first. If that fails to resolve the problem, replace the ICs.
Keep us posted on your progress.
Dan
Posted on Feb 18, 2009
There is red and blue lines around screen and images. (Almost looks like it should be 3d). Does this mean it needs a new lamp/bulb? It is only 6 years old. What is the cost for the part? Thank you
If model number is as listed (46f500) it does not use a lamp or bulb but has three picture tubes.
3d means the two convergence chips in the set have failed.
It depends on if you can solder etc, not a very expensive parts cost (under 30 dollars)
Can you solder?
SD TECH
Sep 17, 2011 | Hitachi 46F500 46" Rear Projection...
THE PICTURE ON MY TV IS SHOWING A YELLOW SHADOW ON ON SIDE MORE & A BLUE SHADOW ON THE OTHER. IS THIS A BULB PROBLEM?
TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 28, 2011 | Panasonic PT-47WX49 47" Rear Projection...
I have a blue streak on the left side of my Hitachi ultravision digital TV. This streak is not solid but hazy and irregular in size.
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 19, 2011 | Hitachi Televison & Video
Picture very dark. I think I need to replace bulb. Can I do it myself. Where can I get bulb.
ll projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 14, 2011 | Hitachi 43UWX10B 43" Rear Projection...
Samsung model hl-s4266w.. I can see the TV programs but it has gotten really dark. i think it's the bulb, but when i look on the back, the bulb is still on. Could it still be the bulb that needs to be...
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 13, 2011 | Samsung HL-S4266W 42" HDTV
I own a philips hdtv dlp. yesterday, it seemed as if it might need new bulbs but today it won't even come on. the blue power light (in the front) is continually blinking. what does this mean? a new a tv? i...
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 25, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Picture has become distorted, especially towards the side of the television. The colour filters line up towards the middle of the television, but become distorted towards the sides.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
  • Screen looks 3D
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Using your original remote go-to the settings menu then goto the convergence section.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Apr 20, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
Picture looks like 3D without 3D glasses on???
The cost I don't know, but this can be fixed. I'd say shop around a bit. Make sure the repair person is certified for your TV's manufacturer. There are generally 3 lamps in projection T.V.'s, Red, Green, and Blue. They have to be aligned for the TV to project a clear picture. A credible TV repairman should be able to fix it. Depending on if it's new enough to be under warranty they may cover it as well. Really the only reason to get rid of it is if you want to get a new TV anyway. Depends on the cost of having the lamps aligned.
Dec 30, 2008 | RCA HD52W59 HDTV Projection Television
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
88 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
