No power When the tv (bush lcd27tv006hd) was working fine and all of a sudden went of. Now there is no power . Not even a red light at the bottom
  • david617 Feb 18, 2009
    Also when i remove the plug from the sockett i get a small shock.
    How much will it cost to fix the tv and where can i take it to ?
  • 19,396 Answers
Check the power cable and test a different power outlet.
If you are in UK also check the fuse inside the TV power plug.
If you do not find anything wrong , then either the fuse on power board, or one of the power board capacitors had blown, and the TV must be disassembled and tested to fix the problem.
Posted on Feb 18, 2009
  • Ginko
    Ginko Feb 18, 2009
    Re: "when i remove the plug from the sockett i get a small shock"
    That means that there is a short either on the power cable or plug or on the main AC socket.
    That is dangerous, have the power cord replaced and soldered properly onto TV power board.
I got a bush 24inch led smart tv few days ago and it was fine now the red standby light isnt on at all or wont come on at all how do I fix it or get it to work again
Hi Alex, Red stand by light is not coming on means the power has gone dead. Check the fuse if you can. Replace it with the same rating one. If the set starts working, enjoy watching and if the fuse blows again, consult the TV Tech. Good Luck.
But why all this trouble? Your TV must be in service guarentee. Call the company guys to fix it.
Aug 03, 2015 | Bush Televison & Video
BUSH 42" plasma no picture or sound?
You have a power supply problem, replace the Module.
What you ear is a click relay No juice to activate the relay
Some cups may be dried.
Nov 01, 2012 | Bush Furniture Bush My Space Rhea 42 in....
Bush lcd27tv006hd no power ,no stndby lights
Open the back cover of the monitor.. check the fuse at the power supply board... If the fuse is open, replace with same value.. at the power supply board check for any blown capacitor and replace it with same value. Check also the power cord for open connection.
Feb 04, 2010 | Bush 5693D 24" TV
No power. Died when turning on to watch TV.
unplug for a couple of minutes then plug back in and try
Oct 29, 2009 | Niko SV3206 32 in. LCD Television
HI I have a insignia model NS-32LCD tv and it stop working the only thing that would happen is the light on the bottom of the TV would change from blue to red. so I call the TV man and he look at it and...
This happend to me before with my LCD that I bought last year. It worked fine for a while and then, all of a sudden...nothing. The power supply was fine, fuses were fine BUT one of the chips or capacitor went bad on the process board and not being able to get the adiquate amount of power to be distibuted. I had my tv replaced and found out this was a defect rather than you or something done wrong to the tv.
Hope this helps you....
Jan 03, 2009 | Insignia IS-LCDTV32 32 in. Television
Bush 32" TV. desperate situation. T-T
The TV is in protection mode. An internal problem was detected and the set shutdown to prevent further damage. If the set is only 9 months old, it should still be under warranty. Call and request warranty service.
Dan
Sep 30, 2008 | Bush 5693D 24" TV
I have got bush lcd27tv006hd tv. When it is switched on the light on the bottom right just flashes and nothing happens no picture no sound.
I know this problem was a couple of years ago . . however, I bought a BUSH 27" 'factory refurbished' for my son and it lasted a couple of years and then this problem with the standby lamp,etc occured. I followed a couple of threads regarding 1000uF capacitors on the power supply board relating to the 6volt output side and now all is well. TV now working :-)
(Did change for higher voltage spec. as recommended!)
Many thanks to all who supply info on websites like this one.
Mar 30, 2008 | Televison & Video
Bush lcd 27006 standby flashing
Yeah your psu needs new capacitors.
Jan 06, 2008 | Bush 5693D 24" TV
Bush id tv
Dear Sir, unfortunately tonight you will not be able to watch this TV set. Please try with an alternative solution. This job definitely requires a professional technician Best regards, Arpi
Jun 17, 2007 | Bush 5693D 24" TV
Televison & Video Logo
243 people viewed this question
Top Televison & Video Experts
Electro Med Services...
